Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
Sony kdf55-wf655 after i changed the bulb i reset the lamp timer now the system status is on the screen . how do i get this display off? [has path a , path b , system info.] could anyone plese help?
  • 4,402 Answers
I hit the "display" on the remote for the Sony TV
Posted on Jan 28, 2008
The machine starts, eventhe vent, but no image appears. All the lights, except the POWER SAVING one remain lights on.
  • Plug the projector into the wall and put it into standby mode. You should have already replaced the projector's lamp with a new LMP-P200.
  • Press the "Reset," left arrow, right arrow and "Enter" keys on the projector's control panel. Press them in the exact order listed here, one after another, and press each key for less than five seconds.
  • Turn the projector on with the "Power" button. Press the "Menu" key to enter the projector's menu settings.
  • Press the down arrow to navigate to the "Install Setting" menu and press the right arrow to select it. You should see the lamp timer at the bottom of the screen. If you have correctly reset the lamp timer, it will indicate 0 or 1 hours.
  • Press the "Menu" key to exit the menu system.
  • Read more :
    How to Reset Sony Projector eHow
  • Turn on your Sony projector after replacing the lamp.
  • Press the "Menu" button, go to the "Lamp Setting" option and select "Lamp Timer Reset." The projector should display a confirmation window asking, "Has the Projection Lamp Been Replaced?"
  • Select "Yes." You will receive a message onscreen saying, "Lamp Timer Reset Complete!" Select "Yes" again, and press the "Enter" button to finish.
  • Read more :
    Jul 02, 2015 | Sony VPL CS4 Multimedia Projector
    Status light blinks seven times
    the lamp timer is failing
    lamp timer chip is on the lamp housing,is a little chip
    you need to reset the timer chip by using a Programmer
    select a date of 0 hour..
    Our company supply this chip with 0 hours USD15
    We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
    any questions, feel free to contact me
    have a nice day!
    Jerry,Lampdeng Limited
    Jan 31, 2014 | NEC MultiSync MT1065 Multimedia Projector
    Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
    The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    If PT-D3500U lamp won't strike (bulb has been changed with no effect), how can you reset the lamp timer to get the unit operational?
    Instructions are listed in the owners manual ( on pg. 46.
    Press the "POWER" button (or the POWER OFF ( I )
    button on the remote control) so that a picture is
    projected onto the screen.
    Press the "MENU" button to display the MENU screen,
    and then press the and buttons to move the
    cursor to select "OPTION2".
    Press the "ENTER" button to display the "OPTION2"
    screen, and select "SYSTEM INFORMATION" with the
    and buttons.
    Press the "ENTER" button.
    The SYSTEM INFORMATION screen will be displayed.
    Press and hold the "ENTER" button on the projector or
    the remote control for approximately 3 seconds.
    An item "LAMP TIME RESET" will be added.
    Press the ENTER button, and when the "LAMP TIME
    RESET" display flashes, press the ENTER button again.
    The used hours of the lamp unit will be reset to zero.
    Jan 14, 2011 | Panasonic PT-D3500U Multimedia Projector
    How do I reset the lamp timer on the Sony VPL-DS100?
    Yes, press RESET, <, >, ENTER keys on remote simultaneously to reset lamp timer. Display of lamp will also change to zero.
    Make sure projector is just plugged in and should not power On (in standby mode) to reset lamp timer.
    Jun 03, 2010 | Sony VPL-DS100 Multimedia Projector
    Still getting "Projection lamp is nearing end of life"
    KDF46E2000 - Change Lamp Warning - Reset
    Bulb is most likely OK. Original bulb in Sony TV is Philips, label on bulb usually says Philips. Sony don't make bulbs. Sony Cost is usually 1.5 times other sources. Many shopping cart operations sell condemned, reject or poor quality electronic service items because cost of return and fooling with them is excessive. This is obvious and widespread with convergence ICs and other parts.
    Lamp timer needs reset. This is usually an automatic function. TV detects Increased lamp current from previous failed bulb or weak bulb condition and resets automatically. TV must be unplugged for lamp replacement for this to work. Occasionally it must be reset manually, as below:
    1. TV must be in standby mode. (Power off).
    2. Press the following buttons on the Remote Commander within a
    second of each other:
    DISPLAY Channel 5 Volume + POWER .1. Access Service Adjustment Mode and select the Service Menu that
    contains the Category with the Adjustment Item you want to change.
    2. To change the Category, press 2 or 5 on the Remote Commander.
    Note: Pressing 2 or 5 only changes the categories within the
    Service Menu displayed. To change a Category on one of the other
    Service Menus, press the JUMP button until the correct Service
    Menu is displayed.
    3. To change the Adjustment Item, press 1 or 4 on the Remote
    4. To change the Data Value, press 3 or 6 on the Remote
    Note: To go back to the last saved Data Value, press 0 then ENT
    on the Remote Commander to read the memory.
    5. To save the changes, press MUTING then ENT to write into
    6. To exit service mode, turn the power off by pressing POWER .
    Wait 2 minutes before restarting the set to allow the fans to
    completely shut down or the Service Menu will appear on the screen.
    Feb 27, 2010 | Sony KDF46E2000 46" Projection HDTV
    After I reset kdf60xs955 lamp timer
    Typically, turning the set off and back on again should take you out of any of the Service Menus. If not, try turning of the set and unplugging it for 5 minutes or so.
    Dec 02, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
    How to reset the bulb timer for TOSHIBA TLP-XD2000
    The booklet that comes with a new lamp specifies the following for the TLP XD2000. While holding down
    Mar 12, 2009 | Toshiba Office Equipment & Supplies
    Sony kdf-55wf655
    Jan 23, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
    Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
    269 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
