Question about Sony SDM-HS73P 17" LCD Monitor
My sony has an issue
When i touched my computer to come out of sleep mode my monitor had lines running down it, it is a 5 year old sonyt lcd, in addition to that i hit a reset button in the menu of the monitors controls and it expanded the viewing area past the limits of the monitor, meaning that i can move an icon so far to the side that i can never see it, and top aswell, so how do i adjust the height and width of the viewing area because the menu on this sony doesnt have a control to do that at all. how can i fix this problem?
  • ChristianV Jan 23, 2008
    the lines have since gone away just in the time since i turned it on, and that is not the main issue it is just adjusting the viewing area, the height and width, because there is no menu for that in the on monitor buttons.
  • Fixitman67 Jan 25, 2008
    i have the exact problem. Have reloaded drivers,
    tuned monitor. all looks ok untill i come out of
    sleep mode. If I restart it goes away. Sometimes
    it goes away by doing a refresh.
    Noise? I isolated cables and power cords.
    No matter what i do, it keeps coming back.
    usually last for 2 to 3 minutes each episode.
Thanks for trying. Does not apply to my problem.
Posted on Feb 07, 2008
  • Fixitman67 Feb 07, 2008
    Maybe this will clarify. The 865PE chipset doesn't
    use Intel's extreme graphics.
    Intel.com suggest not using it.
  • Fixitman67 Mar 02, 2008
    problem fixed by new graphics card.
    nothing wrong with Sony monitor.
  • 983 Answers
If there no menu button means just after loading os go to properties by right clicking in desktop there u go to settings tab go to advanced option.. there u will be having the tab some thing like intel extreme graphics go to that go to display properties there u will having the option to adjust ur height and width of the screen area... check this out...
Posted on Feb 06, 2008
Dim monitor issu. I want it bright always.
it could be age-related but there is also a power setting in the OS. Alternately you can check also the monitor OSD and see if there is a setting for adaptive brightness enabled
Feb 26, 2016 | Compaq TFT5015 15" LCD Monitor
Samtron 56v pc monitor video background with gray vertical lines
How to Tell If A Computer Monitor Is Going Bad
Computer monitors are designed to work properly for years.
Whether it's from a defective part or power surge, they go bad eventually, and you'll probably know it when it happens.
Look for vertical or horizontal lines across your monitor screen that shouldn't be there.
Time how long it takes for your computer monitor to come out of sleep mode. It shouldn't take more than 5 or 10 seconds for the screen to be fully operational when taken out of sleep mode or turned on after being turned off. If the screen is not operating as quickly as it should, it could be a sign it's getting old.
Read more :
How to Tell If Computer Monitor Is Going Bad eHow
Oct 13, 2015 | Samsung SAMTRON 56E/57E/56V
Viewsonic v1930wm
Sounds like the unit needs repair.
Jun 23, 2014 | ViewSonic VX924 19" LCD Monitor
HP W2007 + Xbox 360 = Constant Sleep Mode
the monitor is bad
if it will not power on,
or show NOSIG< with XBOX on then turned off the monitor must show NOSIG>
why not test the monitor on any pc made even laptops VGA jacks works, so that works, its not the monitor.
and bad xbox video caused. but is not it. as you said.
the menu needs sync lines active. to pops the OSD button menu.
so the monitor is bad.
or the cable.
what is w2007, lets see.?
its old. at 1680 x 1050 @ 60 Hz
this old monitor runs CCFL lamps.]
im shocked it glows at all up to now.
ever do flash light trick test?
see got data, but no back light, CFFL is dead.
HP W2007
users guide last page.
This HP product contains mercury in the fluorescent lamp
in the display LCD that might
require special handling at
end-of-life:
that means CCFL died, also all do, soon.
(as short as 2 years, full time , they die. 20k hours)
out of your service manual it shows.
ccfl-wcj1avqu0msqxnqr1cdquwfl-1-0.jpg what any running pc connected the OSD menu most work
not in sleep mode.
if there is sinc, H/V pins active
that OSD must work or the blacklamp is dead
use flashlight see, there is data there, see?
Sep 09, 2017 | HP W2007 LCD Monitor
Monitor going to sleep
juanmgerman0, Connect SDM-X82 to known-good pc that has all sleep mode, power-save mode disabled. (turned-off) If unit still goes to black screen mode, then look at the "date of Manufacture" on rear of unit and let me know if you see "2002 -2004" as the year produced. Retrevo lists unit as "time to retire". Power supply may be going into shut-down mode having detected a problem with itself or the CCFL inverter circuit. 12fixlouie
Aug 19, 2010 | Sony DELUXEPRO SDM-X82 18.1" LCD Monitor
No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Stefan
Jan 31, 2009 | HP 2025 20.1" Flat Panel LCD Monitor
Blank screen
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen went white, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace.
Thank you,
Mar 18, 2008 | Mag Innovision LT776s 17" LCD Monitor
Works when it wants to then turns whie with grey line in it
Hi
If only the monitor is going to sleep, then it could be a problem with the connection from the monitor to the computer or with the cable.
If the computer goes to sleep and if you are not able to wake it from sleep then check the sleep mode settings and also the power management settings for the keyboard and mouse.
You may also do a system restore if you are not able to wake the computer from sleep.
Feb 24, 2008 | Sony SDM-HS73P 17" LCD Monitor
HP Monitor goes into sleep mode
Problem of monitor sreen going black in 5-10 secs is generally dry solder joints around the inverter transformer on the inverter PCB.
Oct 29, 2007 | HP Pavilion F1703 17" LCD Monitor
Open Questions:
Sony SDM-HS73P 17" LCD Monitor Logo
91 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
