Question about HP Pavilion dv4000 Notebook
HP dv4000 laptop CD not reading
It was working a week ago, but now it will not read any cds or dvds. the laptop is recognizing the drive, but cds will not play. they just turn and turn and make lots of noise. when i click on "properties" on the cd drive under My Computer it tells me that the device is working properly, but it isn't. light scribe came installed on the laptop, but that seems to be enabled.
can anyone tell me why cds aren't reading in the cd/dvd drive? thanks!
  • 2 more comments
  • honeybunnymn Jan 24, 2008
    no, i'm sorry, this did not work. dvds are playing just fine, but we get the error message along the lines of "windows cannot play this type of format." and all we're trying to play are normal cds we've purchased at the record store.
    i also tried disabling and enabling the drivers as well as uninstalling and reinstalling them, to no avail.
  • Kbhardwaj Feb 04, 2008
    I am also facing the same problem with HP dv6000 series laptop.
  • Anonymous Jan 07, 2009
    sir ,
    i have the same problem not reading any cd.
    pls help.
    palit
  • Anonymous Mar 12, 2009
    same problem here! dvds work great but i cant for the life of me get cds to play
  • 689 Answers
Hi
Type of media settings might be the issue but making a change for standard CD/DVD recording (it affects reading too) Issue can be resolved. Right click on the CD/DVD drive (Usually D drive ) click on properties and select and choose the recording option. Click the enable CD recording for this drive option
Click on apply and OK. Try again. You may try after reboot the computer. If issue persist please post so we can think about some alternate solutions.
Good Luck
Posted on Jan 24, 2008
6ya staff
SOURCE:
Does not read Cds or DVDs
most sony CD and DVD players have a digital signature design to play CDs and DVDs that are original and licensed. some CDs or DVDs dont work since the player does not recognize or scan any digital signature embedded in the CD or a DVD. 2nd, lens problem causes most players not to read CDs nor DVDs. you can try to buy CD or DVD lens cleaners to have your lens cleaned.
Nov 01, 2010 | Sony Computers & Internet
The DVD drive in my wife's Compaq Evo N600C has stopped reading CDs. It reads DVDs fine, but doesn't recognize any CD or CD-R.
1. Right-Click on My Computer -> Properties
2. Click on Device Manager.
3. In the list of devices, click on CD/DVD Drives.
4. Select ur CD/DVD device and right-click on it.
5. Check the Device Status (Working Properly)!
6. If required, You can update / uninstall / rollback the driver for this device by clicking on, Driver option.
7. Apply settings and close dialog box.
8. Restart the system.
if it helps tell me....tc! :)
Jan 03, 2010 | HP Compaq Evo Notebook N600c
HP dvd740b does not detect blank CDs and DVDs
i think you,ve hit the nail-on-the-head.
The laser has to power up highrer to write a DVD, or ocassionally have a dual laser. 1 for read/write CD. And 1 For Read/Write DVD.
Certain cd roms, only use CD- media. it,s probably worth checking which media is supported by the drive.
Also check the drives aren,t conflicting, on the same ide channel, sometimes swapping channels, ide primary/secondary can help, or swiitching Master/Slave/cable select jumpers on the drives Themselves.
Mike @ Compurepair.
Sep 04, 2009 | HP dvd740i DVD±RW Dual Layer Burner
Hp CD\DVD rom not reading CDs, but is reading DVDs?
cd/dvd rom is probably not working ,try using a lense cleaner disc if that doesn't work it's cheap enough to just install a new drive DVD/Rw as they are about £20.00 new.
Jul 30, 2009 | HP Computers & Internet
Can operate with CD ROM's. Won't recognize DVD's.
Sounds like the drive could be going bad. The way the laser reads DVDs vs. CDs is different, that is why you are able to read one, not the other. I had this happen to me, except the opposite. It could read DVDs, not CDs. Had to buy a new one, and all is well.
Apr 22, 2009 | Pacific Digital Mach 16x8x16x Double-Layer...
Dvd rom not reading cds/dvds
I had similar problem on a Toshiba Satellite A30 laptop, I simply had to reconnect DVD drive. It usually loosing it's connection with motherboard and drive is visible in My Computer but it doesn't recognize any discs. If reconnection does not solve your issue you may try to update your DVD firmware and if it won't help replace DVD drive. Good Luck!
Mar 21, 2009 | Compaq Presario C700T Notebook
Dvd drive will read/play dvds but will not recognize a cd
go to safemode and try reading CDs in safemode. If your burner still can't read CDs then it's most likely bad. You could get an external usb burner.
Mar 18, 2009 | HP Pavilion dv4000 Notebook
DVD drive reads DVDs but not CDs
Sep 28, 2008 | Computers & Internet
CD drive
replace the drive,,the servo for the lazer is bad...
Jul 10, 2008 | Computers & Internet
Can't READ or PLAY CD/DVD in DVD drive
Many laptops allow you to detach the CD/DVD drive - if this is the case for your laptop, perhaps it is slightly loose, or been removed by Safely Remove Hardware. You could try physically taking the drive out, and putting it back in, and that might do the trick.
Feb 14, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 Notebook Logo
1,103 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
