Question about Tomtom ONE GPS Receiver
Signing internal memory
I've had tom tom one 3rd edition for about a month. I turned it on one day and it came up with a screen that said 'Would you like to sign the internal memory?' I clicked 'yes', but it just turns itself off. I turned it back on again and it said the same. I then clicked 'no', and it just went onto a screen that said 'internal memory is not signed, please reboot', so i said continue (the only option) and it turned itself off and then back on again... only to come up with the same screen i started off with! I've read the manual but it doesnt say anything about the matter, and i've also tried the online manual but still no luck. Can anyone help me? Thanks.
SOURCE: GPS Won't Turn On
My 510 was doing the exact same thing.
I called customer support and they helped me get it working again.
866-486-6866 is the number but here is what they had me do.
I had to push down the reset button for 15 seconds (the reset is in a small cut out near where you plug in the charger on the will need to use a pin and you will feel the pin push in the button if you have it in the right spot.)
Then release the reset and hold down the power button for 10-15 seconds. the screen should come right back on.
If you need more help I suggest calling the 866# they are very helpful.
Posted on Mar 13, 2008
  • 125 Answers
SOURCE: change the language from spanish to english on my tom tom one 3rd edition
This is from my tomtom one (not sure what edition) so the page numbers refer to mine.
1.Touch the screen for the menu
2.on page 1 of 3 on the menu, touch the blue wrench (change prefs) the black right arrow key to page 4 of 7 in preferences and touch the flags icon your desired language
Posted on Jul 17, 2008
  • 103 Answers
SOURCE: tom tom one 3rd ed only turn on one time now it will not turn on
Hello, Unplug your Tomtom device, batteries should be fully charged. The tricky thing to Tomtom devices is the ROM put into the device. It needs to be reset once in awhile. The soft reset is like formatting a hard drive but leaving the system files alone. At the bottom of the device, there is a reset button. You'll need to use the end of a paperclip to reset the unit. After it's reset, reinstall the Tomtom application only by using the Tomtom Home application. Let it reset itself and come back to the original screen, then go to menu and set your preferences. Also if it's connected to Tomtom home and if you backed up your data to your computer, reinstall your maps. The only time your Tomtom device gets bogged down and won't finish a reinstall is when all 1 GB of memory is used up. Hope this helps.
Posted on Jan 19, 2009
  • 5 Answers
SOURCE: i need operating instructions for a tom tom one
You can get manuals for any tomtom at
Posted on Mar 20, 2009
  • 515 Answers
SOURCE: my tom tom one 3rd edition is stuck on power down mode an
Posted on Apr 13, 2009
  • 121 Answers
SOURCE: my tom tom has totally lost signal ive had it five months can anyone help? thanks
plug in the usb to pc (computer)
download tom-tom home 2.6
create an account click update my device/one/go
cllick install gps quick fix
Posted on May 03, 2009
0 characters
1 Points
My tom tom one 3rd edition frezes when i turn it on
most of these have this problem please try reset the tom tom
Oct 17, 2010 | Tomtom ONE 3rd Edition GPS
My tomtom one-3rd gen, can't seem to locate a satellite. I reset it and made sure it was fully charged. Still nothing happens. Help!
connect your tom tom to computer and go to tom tom home there you can download free updates to fix the problem,i do this to mine about every month,hope this helps.
Jul 19, 2010 | Tomtom ONE 3rd Edition GPS
How do i get fix my tomtom one 3edition from looping
My solution after probs with 2 different units: Buy a Tom Tom. I did and it works great.
Mar 11, 2010 | Tomtom ONE 3rd Edition GPS
Tom Tom hasn't been used for 6 months. Cant
Found my manual and got it going. Thank you.
Nov 18, 2009 | Tomtom ONE 3rd Edition GPS
Tomtom One 3rd Edition Map downloads
Some versions of the TomTom ONE 3rd Edition have limited internal memory(no memory card slot).
connect your device to TomTom Home to check how much memory you have available and check the map is not too big for the internal memory
Mar 24, 2009 | Tomtom ONE 3rd Edition GPS
How do I reset to factory settings how to reset factory settings on tom tom one
Which Model of Tom Tom One ?
3rd Edition
2nd Edition
make sure you're fully charged, remove any optional memory cards (depends on the unit) there should be a reset hole, place a straightened paperclip into the hole and press for 15 seconds.
make sure you're fuly charged, press and hold the on/off button for about 15 seconds until the unit restarts
Mar 18, 2009 | Tomtom ONE GPS Receiver
Tomtom ONE 3RD
All I wanted to know is where in kansas city I can get this problem professionally fixed
May 20, 2008 | Tomtom ONE 3RD EDITION GPS Receiver
Hello, the same day that I brought my tom tom one I lost the instruction book and the mounting stuff.
May 10, 2008 | Tomtom ONE 3RD EDITION GPS Receiver
Tomtom ONE GPS Receiver Logo
64 people viewed this question
Top Tomtom GPS Devices Experts
Martin Murray
Are you a Tomtom GPS Device Expert? Answer questions, earn points and help others
