Question about Dell 5100MP Multimedia Projector
How do I disassemble and clean (Filter)?
Unit gives message that it's overheating.  You cannot even turn it off when this message appears.  I'd like to clean the filter, if there is one.  How involved is disassembly of projector?
4 Suggested Answers
  • 225 Answers
SOURCE: Is there a solution to
The first link is to the troubleshoot part of the user guide. Look for your symptoms in there and try the fix. The first video is one I made on how to take the projector apart. The second video is one I made showing how I fixed a fan failure.
http://support.dell.com/support/edocs/acc/M109S/en/ug/html/trouble.htm#wp1180421
Posted on Jun 24, 2011
AJIN G
  • 6694 Answers
SOURCE: the 4100mp dell projector will
hi,
Try to reset the lamp hour of your projector. For that do the following.
1. power on the projector.
2. Press the menu button
3. select lamp settings
4. Select lamp reset
5. Select yes to reset the lamp hour.
OK
Posted on Jul 29, 2011
I forgot password of Dell M109S. How to reset password?
Posted on Jun 01, 2013
What is the best way to remove the lint from the lint filter compartment?
This would indicate you have a lint build up somewhere in your exhaust system. The best way is to disassemble the unit and completely clean the unit. Also remove the exhaust hose and make certain it is clear all the way through and that the exit door is not blocked closed or plugged inside. I normally do this annually and then use a long brush to clean monthly to maintain a safe, functioning unit.
Nov 02, 2015 | Sears Kenmore Elite Electric Dryer 69278
NEW HP Spectre 13T-3000, 13.3" Touch will not run with the battery and shuts down randomly
you can use the unit without the battery. Remove the battery, plug in the charger/power supply and turn on the unit and wait for the result. if the problem persist?..... maybe the fault is in CPU fan. check the fan...overheating the processor. Cleaning the heat sync and reapplying silicon compound on CPU's can cure the problem.
Sep 02, 2014 | Computers & Internet
Clean filter message reset
the filter will need to be cleaned and if the set still shuts down then I would suspect the fan may need to be cleaned and possibly replaced.
Aug 07, 2012 | Panasonic PT-43LC14 43" Rear Projection...
Emachines t5212 overheat message then shuts down
Three causes of ovheating:
1) Dust. Dust inside the computer, Dust around the vents, fans, cpu and heat sink. Take a can of compressed air and clean the dust out of the computer.
2) A Fan not working. Make sure the fan inside the Power Supply where you plug the power cord in works. Also there is a fan that sits on top of the CPU and Heat Sink. Make sure it works. Normally the system will give you an error message if the fan is not working.
3) Thermal Paste - The Thermal Paste around the cpu and heat sink has dried up or is too thin to keep the unit cool. Apply a fresh coat of Thermal Paste on the CPU and Heat Sink.
May 09, 2012 | E-Machines W Computers & Internet
My laptop turns itself off after 5mins
Unit is overheating. Disassemble, clean fan, ducts, and apply new thermal compound to the CPU and GPU. Check Hoosier Newman's Blog 'Getting In Too Deep' for video on doing this or on YouTube for instructions.
Not really technical, but you should have some technical skills disassembling the unit and putting it all back together right.
Apr 09, 2012 | HP Computers & Internet
I'm using whirlpool mastermind chrome split ac.. clean filter light started blinking so i cleaned and replaced the filters but still CLEAN FILTER light is blinking. please give a solution
If you didn't turn the Master ON/OFF Switch to OFF, before removing the filter. That is the problem. To clear the error message. Turn the Master ON/OFF Switch to OFF, unplug the unit, remove the filter and reinstall it. Wait 10 minutes, plug the unit back in, turn the Master ON/OFF Switch to ON. The controls should have reset themselves and the clean filter light should not appear.
Hope this helped you solve the problem. Please let me know. Thanks.
Jun 12, 2011 | Whirlpool ACC108PS Air Conditioner
Cannot turn the projector on with the remote control
Hello :
read the following paragraphs please :
1:Are the input and output vents blocked or obstructed in any way? That could cause overheating problem and what you see with your projector is one of it's symptoms .
2:Are the filters dirty or clogged? Most manufacturers will recommend filter cleaning on a monthly basis depending on usage .After cleaning the filter always remember to reset your projector .
3:Remove any extension cords, power strips and/or surge suppressors. Many current model projectors will not even try to ignite the lamp if they detect drops or fluctuation in voltage supplied to the unit. This is a safety feature to reduce stress on the lamp.
4:Pull the lamp back out of the unit, give is a brisk shake and reseat the lamp. Occasionally there is some buildup on the lamp contacts or filament during manufacturing.
5:Try removing and reseating the lamp, or to try another lamp.
6:Remove the lamp from the projector. Ensure that it has no cracks, discoloration or "smoky" appearance.
PLEASE RATE !
Apr 12, 2010 | Eiki LC XG200 Multimedia Projector
The unit begins and after a short time the unit stops.
it sound like the unit is very low on r134a refrigerant and in being so the compressor is overheating and the thermocouple sensor on the compressor body is shutting off power to compressor to keep it from burning up
Jan 17, 2010 | Frigidaire FDL25P1 Dehumidifier
Fujitsu M4097D error about Front side optical alarm
HI,
I work on the fujitsu scanner hotline. This message means that the optical unit needs to be replaced, there will be very little you can do to fix this problem.
Apr 06, 2008 | Fujitsu M4097D IPC Path-Through Flatbed...
Dell 5100MP Multimedia Projector Logo
391 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
