Question about Ricoh 6513 Copier
Ricoh 6513 Service Code 370
Does anyone have a clue what this code means and how I can fix it. I have an older machine with no maintenance contract and would like to fix it myself it is simple enough. Thanks.
  • 417 Answers
HI there I hope it is the colour machine version so below is the description from the service manual.
Thanks J
SC370 Abnormal TD
information (K)
- Timing -
When communicating with
TD sensors, during
printing process, or
process control self-check
- Condition -
TD sensor output exceeds
4.5V or drops below 0.5V.
• Poor connection
• Dirty sensor surface
• Defective TD sensor
• Toner density is out of
• Not enough developer
3-007-001 1. Make sure the TD sensor is properly
2. Check if the connectors on the TD sensor
interface board 1 and the slip ring and the
TD sensor interface board 2 are properly
3. Clean the surface of the TD sensor.
4. Replace the TD sensor. If it becomes OK
after the sensor is replaced, replace the
developer of color related to the problem.
If the problem is related to the toner density
(too low or high), find the cause and fix it.
Posted on Feb 03, 2008
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
Ricoh 3310l fax shows error code 0390H in display. Anyone know what this means?
I've never seen a message like that with the 0390H code. There is no mention of that code in either the user manual or service manual. The closest thing is the sc390 code, which means either the toner density sensor or the developer has gone bad, and typically replacing the PCU can fix that problem.
If the new PCU doesn't fix the problem, you might want to try calling Ricoh for support, since their documentation doesn't mention that code.
Jun 11, 2010 | Ricoh 3310LE Plain Paper Laser Fax
Solution for "code 373 ricoh aficio color 6513"
Hello sir; the error code you display is toner senser problem, now the first thing you have to do is make a full color copy find out which color missing then pull out developer unit from missing color the senser right underneath, replace it.
May 23, 2009 | Ricoh 6513 Copier
Error code SC542 on a Ricoh 3245
Hello, this code is : Fusing temp. warming-up error. This means that the fuser did not warm-up in the allowed time. Possible causing-- in order; Thermistor bad or out of position,
fuser lamp bad,
thermofuse bad,
BICU board defective,
power supply board bad,
poor fusing unit connection ----check this first if you had the fuser out of the machine.
If you would like to talk, I can see if we can try to reset the code -- sometimes if the machine is to cold at warm-up the code will throw. # 216-701-1591. Thank you.
Jan 12, 2009 | Ricoh 6513 Copier
Ricoh 6513 error code PM CAll
Preventive maintenance.....
It's for a clean up, and sometime there's some parts to replace...
Apr 04, 2008 | Ricoh 6513 Copier
Ricoh 6513 streaking
Depending on your use IE lots of thick paper 150gsm plus.
The fuser rollers wear very quickly.
There is no Cheap fix for this.
These machines are very costley to run.
Ricoh Tech L3 22 years exp.
Mar 21, 2008 | Ricoh 6513 Copier
Ricoh 6513
A sc541 code is with the fixing ass'y did you try to reset it? Did it come right back? Is the fuser warm to the touch? If so it is most likly to be one or both of the termister in the fuser. If it is cold it may be the fuser heatting lamp or thermal fuse
Feb 08, 2008 | Ricoh 6513 Copier
Error code
sc 385 is ID sensor vsg adjustment error.Clean the ID sensor.If the developer life is expired replace the same
Sep 05, 2007 | Ricoh 6513 Copier
Ricoh 6513 Copier Logo
544 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
