Question about HP Officejet 5610 All-In-One InkJet Printer
Blurred printing down center of page
My HP officejet 5610 has blurred printing in center of page. I have tried new cartridges and alignment with no improvement. Is there something that needs to be cleaned?
WE GAVE UP ON THIS TON OF JUNK HP LOSER
SOFTWARE SUCKS SO BAD. WE JUNKED IT.
CALLED HP (DIDNT CARE) DO HP LASERS NO LOWER
THANK GAWD FOR BROTHER MULTI SYSTEMS
HP 5610 OWNERS WE FEEL UR PAIN!!!!!
Posted on Jan 23, 2008
How do I change the ink in hp officejet 5510
Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access doorc00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridgec00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tapec00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridgec00034769.jpg
  5. Close the print-carriage access door.
Back to top Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Feb 08, 2011 | HP Officejet 5510 All-In-One Thermal...
I installed a new printer cartridge. The alignment page printed out but I threw it out. I didn't realize I would need it for any reason. How do I align my cartridge without the paper.
Every HP I've owned has printed the alignment page until you scan it. Just plug in the printer, power it up, and check it out. If that doesn't work, try removing the ink cartridge, and reinstall it. One way or the other, I'm sure the HP will print a new alignment page.
Carl
Dec 30, 2010 | HP Officejet 5610 All-In-One InkJet...
I have an hp officejet 5610 all-in-one and I replaced the tri-color print cartridge. However, when I tried to align the cartride, it failed. I have turned the printer on/off and now I no longer get the...
your color cartridge is not printing
get a new one or refill the old one
check here how
utube.png You-Tube video "sOriLrbuBao" placeholder (do not delete) utube.png
utube.png You-Tube video "II9gpIXs_lE&feature=related" placeholder (do not delete) utube.png
May 14, 2010 | HP Officejet 5610 All-In-One InkJet...
Hello, My name is Cherie Hefty. I have an Hp Officejet 5610. I am having problems getting it to print anything. Everything was working properly until I had to switch the black ink cartridge because it was...
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr14
Aug 13, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 - Scanner/Copier only prints black pages
hi,
djiu9ofdfd27
Jul 08, 2009 | HP Officejet 5610 All-In-One InkJet...
HP OfficeJet 5610 All In One alignment cartridges and no printing
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
ab101
Jun 18, 2009 | HP Officejet 5610 All-In-One InkJet...
Trying to align heads, 5610 HP all-in-one
This seems to be an issue with the alignment of the printer.
Remove both the cartridges from the printer and clean the cartridge contacts with a soft lightly moist cloth and then re-insert the cartridges. Unplug the USB cable of the all-in-one and then let the all-in-one perform the alignment process and once it prints the alignment page. Once the alignment page prints out, place the alignment page (With the printed side on the scanner glass) and then press the Scan button. the alignment process should complete successfully.
For more information, refer the below hp document.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00442099&cc=us&lc=en&dlc=en&product=441125
Jan 07, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
HP Officejet 5610 All-In-One InkJet Printer Logo
218 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
