Question about Acer Aspire 3610 Notebook
Wireless internet connection
Hello i have got my internet set up but it will only connect through the yellow cable can you help?? i have spoken to my internet provider and they said that there is a problem with my computer
  • cybersugar Jan 25, 2008
    My computer will not connect to the internet with the ethernet cable directly into it. I have a desktop and it comes right up but my laptop will not. Help please.
  • Anonymous Mar 01, 2008
    my notebooke is used with Linksys and was working great for a year now overnight it can no longer detect the built in wirless card in the computer, i can only use it hard wire
  • 1,067 Answers
Reset roughter unplug then back in then cheak wirless area look for your roghte in the list maby download latest drivers from the makers site for it ok
Posted on Jan 23, 2008
How to connect xbox360 to internet with laptop
Hello bernelltaylo,
This is a very simple procedure, but pay close attention.
First, here are the requirements to attempt this procedure.
- An Ethernet Cable,
- Wireless Connected Laptop
- Bridged Connection Eligibility
1. Get an Ethernet cable, they are commonly blue, or yellow.
2. Plug one end of the Ethernet cable into the back of your Xbox 360 console, and the other end of your Laptop.
3. Log onto your laptop, (assuming you're using Windows), and find the list of your wireless/wired connections.
4. You'll see something like, "Local Area Connection 2", and "Wireless Network Connection 3". Make sure you're already connected to the Wireless Network before continuing to the next step.
5. Highlight both the connections, and right click one of them. Click on, "Add a Bridge".
6. A process will start which will bridge the connections, enabling your laptop to work as a modem for your Xbox 360. This may take as long as anywhere between seconds, to minutes.
7. When it's done, do NOT remove the Ethernet cable, until your desire to disconnect from the internet on your Xbox 360.
Hope this helped, see ya' later. :)
Dec 02, 2012 | Microsoft Xbox 360 Console
The CD is not available for installation is it necessary? I have all of the cable if the Yellow cable connects to the cable router what does the white cable on the wireless router connect to. Thank...
If the cables supplied have RJ45 connectors then they are used for connecting and configuring the wireless settings in Netgear router and to connect the Netgear to the DSL modem foe Internet access.
Most likely the color of the cables is not important.
To configure the wireless settings, connect a cable from one of the LAN ports (not the WAN/Internet port) to the LAN port on your computer. You may remove this cable after configuring the wireless settings if you want to connect to the Netgear by wireless only. You need to connect other computers to the Netgear's LAN port with a cable if they do not have wireless cards installed in these computers.
The other LAN cable is used to connect the Netgear WAN/Internet port to the DSL modem so you computers can connect to the Internet via the Netgear router.
Follow these instructions to configure the Netgear router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-
Feb 23, 2011 | NetGear WGT624 Wireless Router
Yellow port
that port is given for IPTV. so that will different.
Feb 25, 2010 | Linksys WRT160N Wireless Router
My internet connection will work when yellow cable is plugged in but wireless has stopped working on both laptops. The wireless connection isn't even showing up in the wireless connection window.Help!
your router may have been reset somehow and the wireless settings have been retired. goto: . and follow the setup wizards for wireless setup. This will repair the problem
Aug 27, 2009 | Netopia 2247NWG-VGx Wireless Router...
I am replacing BT 105 modem with a Belkin adsl2 modem with wireless g router. The 105 has a blue cable with a square connector. I tried to put the yellow supplied cable in the back of my computer but it...
no, but you need to configure the router to connect to the internet, you should have a "quick start guide" that will help you connect to your router and set your ADSL dial settings (as it needs this to connect you to your internet service)
once these connection settings are set you should be able to connect to the internet
you can then explore the other settings including the wireless configuration of your router
Oct 03, 2008 | Belkin Computers & Internet
I've installed my wireless router, modelwrt54g2v1, and the yellow ethernet cable is still connected to my laptop, once I remove it I have no connection?
The yellow cable (CAT5) is giving you your internet connection
you will need to follow some steps:
1) Access the routers GUI (usualy by going to a web-page in your Internet explorer EG check the manual)
2) make sure that wireless is enabled on the router + DHCP is enabled
3) at this stage set wireless security here as well (to stop unwanted use of your broadband and people hacking your PC)
4) make sure that the laptop wireless is switched on, sometimes there is both a physical on/off switch and a software/keyboard enable/disable button, disconnect the Yellow network cable
5) go to control panel:network connections
6) right click on the wireless connections icon and then view available wireless networks
7) if you see your network then highlight it and click connect
8) enter the security password (if any) which you set in step3 above.
let me know how you get on
Aug 29, 2008 | Computers & Internet
L2TP connection problem
Hello, I've had the electric cut off and immediately back on and I lost my connection from Wireless router to modem. I could not connect in the same way. I could access the router settings with wireless laptop and PC but not to internet on either. I bypassed the router and connected the PC computer to modem then to internet verifying with a browser. I then reconnected the computer cable back to router and router to modem. It stayed connected. But I'm not sure if you have a PC connected to the router also. Sometimes just unplugging some cables and replugging will solve problems. Hope this helps.
Feb 18, 2008 | D-Link AirPlus DI-524 Wireless Router
Configure router via ethernet cable in first instance. Then install adapter. May need to hange MTU for AOL as ISP.
Oct 08, 2007 | NetGear WG111T 802.11g/b (E82321) Wireless...
We bought a wireless router can you help me set it up where do the wires go
Hello, The wire from your cable modem plugs into the WAN (labelled "connect to modem") port on your wireless router. You then need to install the software on your PC to set up the router.
Sep 30, 2007 | Belkin (F5D9230-4) Wireless Router...
Unable to detect my router
This is because your router is setting your pc at a different IP address than your original modem. Make sure router is set to enable DHCP which gives out an automatic ip address and check your wireless card and network cards are set to obtain ip address automatically. It may take a few re-starts to get on the internet as your systems will need to clear their previous DNS settings. Also i assume you have set up the home network wizard (XP) as you are now using a router and not a direct modem. Also try Start>Run, then type ipconfig /flushdns then press enter.
Dec 27, 2006 | D-Link AirPlus DI-524 Wireless Router
Acer Aspire 3610 Notebook Logo
95 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
