Question about Zenith IQC50H94W 50" Rear Projection Television
Convergence problem I found resistors RK50, RK54, and RK57 burned, would you know the values. Thanks
  • elektech Jan 23, 2008
    The RK50, RK54, and RK57 are location printed on the board not resistance value information.
  • 2,130 Answers
Go ahead and replace the burned resistors but you need to find out "why" they burned. You may find out that the new ones will also burn up if something else is at fault. Don't just stop there. Look for a cause.
Good Luck,
- Jim
Posted on Jan 23, 2008
    President:
  • 4,402 Answers
I looked around and i found 1 each of the following 1W axial lead fusible resistors: 1.5, 1.8, 2.2, 2.7, 3.3, 3.9 Ohms.
this is for Hitachi kit but they should be close maybe you could narrow it down
im assuming you replaced the stk's already
  • Zenith Master
  • 8,617 Answers
RK50 is 2.2ohm 1 watt Metal film @ 5% tolerance
RK54 is 1.5ohm 1watt Metal film @ 5% tloerance
I acnnot locate an RK57 anywhere on the convergence schematic. could you recheck that number and I will look again. Hope this helps. Let me know if you need anything further.
    Problem Solver:
  • 6 Answers
50k,54k and 57 k
43FDX20B RK58 RK50 RK54 RK42 Values STK392-120's
I don't think it will hurt especially if the updated manual indicates it.
May 13, 2012 | Hitachi Televison & Video
Hitachi 61swx10b HDTV - Convergence problems. User 'gdroukas' mentioned in a post that it is probably the convergence amps and a few resistors that have changed value. Can anyone be a bit more specific? ...
Convergence ICs are Big Black ICs and will have the part number on them. STK392-110,
upgrade to 120s or 150s better ICs.
Resistors to replace are RK42 3.3ohms, RK46 1.8 ohms, RK50 2.7ohms,RK54 1.5, RK58 3.9 ohms. RK62 2.2ohms
Mats Electronics has STK ICs 1-800-628-1118 order convergence Kit that comes with resistors.
ACME has the Convergence resistors they must be 1 watt resistors 1-800-575-9833
Let me know if you need any more help Thank You.
Jan 13, 2011 | Televison & Video
I need to find the value of rx50 rx54 rx58 on hitichi dp1x convergence board
The DP1X was used in various Hitachi Models and those resistors have different ratings depending on the Model number. Post your model number and I can list the ratings for those resistors for you. Also do you mean RK50, RK54 and RK58 as those are convergence resistors board location prefixes that usually get blown. Double check the Prefixes.
Nov 26, 2009 | Televison & Video
Hitachi 50FX20B convergence problem
RK42 is 2.7 ohm 1watt
RK46 &RK54 are both 2.2 ohm 1watt
RK50 & RK62 are both 3.3 ohm 1watt
RK58 is 3.9 ohm 1watt
They are all metal film (flameproof) 5% resistors
Jul 20, 2009 | Hitachi 50DX01B 50" Rear Projection...
Incorrect resistors on DP1X PWB?
Assuming this unit was never worked on and it was actually working properly before the IC's decided to take a vacation I would recommend leaving them alone as there may have been an engineering change after the service manual was printed.
Apr 15, 2009 | Hitachi 43FDX15B 43" Rear Projection...
Hitachi 53uwx10ba
ok
upgard the stk392-110 to a stk392-150
note use flame proof resistors 1W
rk42=3.3ohm/rk46=1.8ohm/rk50=2.7ohm/rk54=1.5ohm/rk58=3.9ohm/rk62=2.2ohm
regards,
daniel.
Jan 07, 2009 | Televison & Video
65xwx20b
Is this a Hitachi set? If so then check the model number and be sure it's right.
Dec 05, 2007 | Televison & Video
Resistor ohm values??????
RK42 = 2.2 , RK46 = 1.5 , RK58 = 3.3 , RK52 = 1.8 , RK 50 = 2.2 , RK54 = 1.5
Aug 28, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53uwx10b
Hitachi has created a repair kit part# X480293 for this problem. It includes: (2)STK392-150 convergence ic's,resistors RK42 = 3.3 ohms,RK46 = 1.8 ohms,RK50 = 2.7 ohms,RK54 = 1.5 ohms,RK58 = 3.9 ohms,RK62 = 2.2 ohms,all 1 watt resistors.
Aug 20, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Zenith IQC50H94W 50" Rear Projection Television Logo
145 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
