Question about Master Heaters Master B115DT 115,000BTU Fan Forced Air Heater with Thermostat
Master 115,000 btu heater
When I set the thermostat and turn unit on it will heat to correct temp. However, it will not come back on unless I shut it off and turn it back on. Any help would be greatly appreciated.
Tom
Remember, under thermostat operation, the heater heats to 2 degrees above the set temperature, and doesn't come back on until it drops to 1 degree under the set temperature. If it doesn't come back on at 1 degree under, then you do have a thermostat problem, no doubt.
Posted on Nov 17, 2008
    Problem Solver:
  • 19 Answers
I would say it is a bad themostat.
Posted on Mar 05, 2008
6ya staff
SOURCE:
165000 btu master shuts off after 30 seconds no matter where temp set at
U may have a problem with the over temp shut off , or your thermostat is bad so the over temp kicks in .
DO NOT REMOVE OR BYPASS OVER TEMP , FIRST FIND OUT THE THERMOSTAT AND CHECK/REPAIR/ REPLACE IT.
Feb 17, 2015 | Reddy 165000btu Kero Heater
Water Temp
Sounds like the thermostat is bad on your heater.
Rod
US Parts Center
May 03, 2013 | Jandy Ae2500t 115,000 Btu Heat Pump
Reddy heater 115,000 btu heater runs for about ten minutes then shuts off does this model have a thermostat or carb that might need adjusting????
A heater with this problem is probably the hardest to determine the cause. There is no carb orn thermostat to adj. If it uses a spark plug ignitor I would check the plug gap and make sure it is at an angle to the nozzle. If it has Hot Surface Ignition this will not be the problem. I would then check the fuel filter in the dip tube in the tank and the pump pressure. I should be about 4.5 psi. I would also remove the nozzle and replace it or at least blow it out backwards withlcompressed air to clean it. If all these items fail to correct the problem I would replace the flame sensor. Let me know what you find out or if you have any questions.
Dec 12, 2009 | Reddy HEATER R115 115,000-BTU PORTABLE...
I have to play with thermostat to get my heating system on
You did not make it clear if the thermostat is a programmable unit or not. I am wondering if the thermostat is not set on the correct heat anticipation setting. A heat anticipater is a small heater that helps the thermostat turn off before it over shoots the desired temperature setting. If the thermostat is set for a 5 degree setting, it will turn off at 63 degrees if set at 68. If the anticipater was set at 1 or 2 degrees, it will shut off the heater at 66 or 67. Newer thermostats will only allow the thermostat to cycle 6 times per hour so if you never reach the desired temp, you have to wait 10 minutes before it will allow a call for heat. Check the installation instructions to see if there is a setting where you can get the anticipator temperature closer to your set temp. Good luck.
Dec 11, 2009 | Goodman Heating & Cooling
Electric furnace/heater pump/fan unit won't shut off
There are dip switches on the main board.. When you remove the lower panel on the air handler there are instructions to where the dip switches should be for your units fan control. if the switches are in the correct configuration.. The Thermostat may be malfunctioning or not wired properly. and last.. and most expensive.. the motherboard may also be failing.
Jan 09, 2009 | Heating & Cooling
Short cycling
There are a few reasons why your furnace is restarting after it reaches temp. and shuts off. First, if you have a mercury bulb thermostat it needs to be level and the heat anticipator needs set properly. If you have an electronic thermostat then you need to make sure the DIP switch settings inside are set properly for propane. If you have a digital thermostat there are also settings to be made for your type of heating. These settings will be explained in the thermostat installation instructions. Also, Make sure your furnace filter is clean. If this does not help then there are some other things to check which may need to be done by a technician depending on your mechanical aptitude. Hope this helps!
Dec 08, 2008 | Coleman Propane Forced Air Heater...
Master 115,000 will not stay running
It sounds as if your are having a fuel delivery issue. Always start troubleshooting fuel delivery problems with a pump pressure test. Air pump pressure is extremely critical on these computerized heaters. Instructions are at www.reddyparts,.com
Dec 03, 2008 | Master Heaters Master B115DT 115,000BTU...
Master Heaters Master B115DT 115,000BTU Fan Forced Air Heater with Thermostat Logo
181 people viewed this question
Top Master Heaters Heating & Cooling Experts
T bone 1963
Gil Shultz
Paul Carew
Are you a Master Heaters Heating and Cooling Expert? Answer questions, earn points and help others
