Question about Sony KDS-R50XBR1 50" HDTV
I Have had my tv 18mths now and the blotches started 6mths ago on the top right and left of the screen,they go all across the screen and look worse against a light backround.It looks like if you could get your hand behibd the screen and wipe it with a cloth it would dissappear,it's a bit like a coating of fog or dust,can you help please.
  • 1 more comment
  • Vandra Jan 24, 2008
    Thanks for your reply,I have tried different settings with the colour and it was already set to cool but it is still the same.I too heard that it was the optical box so it looks like I need to replace this.I just hope it is not too expensive.Thanks for your help though. Vandra
  • Anonymous Apr 13, 2008
    greenish hue to background,greenish burn in on right side, lacks crispness. alredy tried changing adjustments
  • ambusher1 Jun 21, 2008
    I have blotches on the screen and the screen also has a green tent. I have tried to adjust the color temp with no sucess.
  • 4,402 Answers
This may not be the problem, but the following service bulletin may be of interest:
Last Update: 1/25/2006
Document Reference/Event ID: E30094243
Subject: Picture might have a slight Greenish tint.
Under certain conditions (especially cold/ first power ON), white areas of the picture may take on a slightly greenish tint after power on until internal temperature stabilization is achieved. Typically, this disappears after approximately 10 minutes operating time, however, in certain cases (i.e. colder conditions) the set will continue to fine tune the picture longer that 10 minutes. This is in order to create optimum picture performance under nominal viewing conditions.
This is not a defect but a characteristic of the LCD panels. Be assured that the time it takes to disappear will neither lengthen nor reduce over time.
If the condition improves but reduction in effect is desired, there are customer adjustments that can minimize this condition. Please demonstrate these adjustments with the customer, to determine if these settings are acceptable. (User adjustments are supplied in Solution A)
In cases where no Uniformity improvement is achieved (after 30 minutes power on time) proceed to Solution B; Optical block
Please be aware that all Optical Blocks exhibit warm-up behavior.
Replacing an Optical Block will not eliminate or significantly reduce the time below 10 minutes.
Internal temperature stabilization needed.
Solution A)
You may reduce this effect by changing some user settings as follows:
(1) Change the Color Temperature setting to Cool - (refer to page 81-82 of the instruction manual). If further reduction is desired proceed to step 2.
(2) Slightly Reduce the Green bias (only available in PRO Picture mode under Advanced video settings), then select white balance Adjustment - (refer to page 81 of the instruction manual). Example:
a. Menu, Video, Picture Mode, Pro Mode
b. Menu, Video, Advance Video, White Balance, G-Bias (Reduce several steps)
Solution B)
Replace Optical block after gaining approval from Sony Tech. line.
Posted on Jan 23, 2008
My kid ran a magnet across the screen now there's a purple blotch along the top of the screen.
The TV needs to be degaussed.
There is an automatic degausser built in but it may NOT be strong enough.
Try this: Turn off the TV and let cool for 10 minutes. Then turn on for one minute.
Repeat the previous sequence until screen is clear of blotches.
The cooling period re-arms the degausing circuit.
If this doesn't fix it adequately, you need to find a TV repairman that has a degausing coil... these are getting a bit rare now. It would take him ten minutes with the coil to fix it.
Dec 25, 2009 | Sanyo AVM-2506 TV
Blue streaks and faint blue blotches on screen
The Optical Block / Light Engine is the problem. Very expensive repair / over $1000
Aug 08, 2009 | Sony KDF-42WE655 Television
It sounds like your light engine is on it way out. I would have this verified by a service center. Very costly to replace. They will probably try a new lamp first.
Jan 21, 2009 | Sony KDF46E2000 46" Projection HDTV
Green blotches on screen
your vs and va need to be adjusted on power supply i can walk you through it but requirs volt meter and taking the back panel off tv
Jan 15, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Red blotches on screen
Serce this questin using the term "pink bloches" I explained it there.
Oct 10, 2008 | Epson Livingstation LS57P2 57" Rear...
I accidently held a magnet up to my TV screen and its busted up. How do I fix it?
Magnets and projection screens do not mix well. When you say `busted up` it could mean a few things.
If it means blotches of color on the screen
-Caused when your projection TV becomes magnetized.
-Use a strong magnetic coil and make circular motions around your projection TV screen starting on the upper left corner.
-Increase the size of the circles you're making until you've covered the entire screen. Slowly move away from the screen; continuing to make circular motions with the magnet.
-When the magnet loses contact, the color blotches should be gone.
hope this helps
Oct 08, 2008 | Televison & Video
Bad picture. in wide
sir kindly adjust its screen focus of your tv,,, thankss and hope too help you,,,gud luck
Feb 25, 2008 | Televison & Video
Dark blotches / Dirty behind screen
it could be dust in the mirror or in the optics,in this set if im not mistaken you have acces to the mirror from the back, anywhere from 12-20 screws it sould be easy to remove plastic cover first and the the mirror.this mirror are very delicate you dont want to leave fingr prints on it it will show just like the dust is showing right know. taking the mirror off will also give acces to the lense.
use someting soft to clean it.
Dec 28, 2007 | Mitsubishi WD-62528 62 in. LCD Television
Dark blotches behind the screen
When I had this problem with my 52525 I cleaned the bulb with a lint free cloth. The dark blotches went away.
Dec 28, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Screen is filled with a circular Red/Green/Blue pattern
The problem will be with the de-gausing circuit, this de-magnetises the tube when the set is switched on from cold, this is a fault you will need to get an engineer to look at ie, not a D.I.Y repair.
Mar 05, 2007 | Samsung TXR2675WH TV
Sony KDS-R50XBR1 50" HDTV Logo
163 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
