Question about Samsung ML 1710 Laser Printer
Wrinkled page My Samsung 1710 suddenly wrinkles the right edge of the paper when I use the sheet feeder. If I use the single sheet feeder it does not do it.
  • zackgeo Jan 23, 2008
    This happened from one minute to the next while I was printing. No paper is stuck anywhere in the printer.
SOURCE: Paper completely wrinkled
I have the same problem!! All of a sudden the hp 1300 started majorly wrinkling the left side of the paper (and occasionally the whole paper). I had to buy a new hp 1320 which has been fine. I decided to take this printer home and find the problem. I used to work for IBM...repairing office equipment. I cannot find the problem EXCEPT that there are pieces of torn "mylar"...charcoal color on one side and tan color on the other. I am sure that this has something to do with the problem. I can see a roller(?) from the "straight through" in the back. It is difficult to see. I think this "mylar" (?) is ripped and causing the paper to wrinkle badly. How do I replace the damaged mylar? What is this mylar?? It is impossible to take the covers off and get at this! I have nothing to lose...I am ready to throw this printer away...what a shame if it is something simple to fix!
Posted on Jan 28, 2007
SOURCE: Phaser 7700GX Color Printer prints wrinkled pages!
when this occurs the problem is most of the time with the transport roller, fuser / fixing assembly roller.question is the image still toner only and not fused to the paper.
In these areas there is offen a jammed and not removed piece of paper dislodged in the paper path or jammed in the fuser or the transfer rollers teflon coating has perished inspect the areas carefully and remove any found if the unit still is faulty (fanning of paper the fuser would be the first to be replaced are past there usable life) if so then Post a reply
Posted on Nov 04, 2007
IB4G2008
  • 3587 Answers
SOURCE: Printer won't stop jamming
sounds like your printer wants to form it's own three piece band(kidding here).
sounds like you rollers are dirty or have something on one or both of them..like tires on a slippery road, these need to be clean and dry.
Posted on Mar 08, 2008
SOURCE: Single black line down center of newly copied page when using Auto feeder to copy
I had this same problem but after while it went away - so my solution would be to just keep using it, and perhaps it will solve itself.
Posted on Jun 05, 2008
SOURCE: Samsung ML-1610 Does not print after a paper jam
after checking no paper left on rollers etc, turn printer of for a while and then turn back on and press the paper release button
Posted on Oct 27, 2008
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
Paper jam
From the reference manual for your Photo Printer
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=60202&prodoid=58654761
"Epson Stylus Photo R220 Series Printers"
The Paper Jams
Press the font29.gif paper button to eject the jammed paper. If the error does not clear, turn the printer off, open the printer cover and the CD/DVD guide. Remove all of the paper inside, including any torn pieces, then close the CD/DVD guide. Reload the paper, then press the font29.gif paper button to resume printing.
r_note.gif Note: r_space.gif If you cannot remove a foreign object easily by yourself, do not use force and do not disassemble the printer. Call Epson for assistance.
If your paper jams frequently, check the following:
  • The paper is smooth, not curled or wrinkled.
  • The paper is of high quality.
  • The printable side of the paper is face up in the sheet feeder.
  • The paper stack was fanned before loading.
  • The paper is not loaded above the triangular load-limit mark on the left edge guide.
  • The paper stack fits under the tabs inside the edge guides.
  • The number of sheets in the paper stack does not exceed the limit specified for that media.
Feb 13, 2011 | Epson STYLUS R230 InkJet Photo Printer
Hello can you assist I can not figure out why the CX8310 Epson printer won't allow me to feed paper into it.
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right edge, behind the tabs, then slide the left edge guide against the paper. Make sure the paper is not in front of the feeder guard.
  • Don't load too many sheets at once (up to 20 sheets of photo paper, 80 sheets of Premium Bright White paper, or 100 sheets of plain paper).
    Sep 11, 2010 | Epson Stylus CX3810 All-In-One InkJet...
    Paper not feeding properly
    Follow these steps to reload paper:
    1. Remove the paper and make sure it's not curled or wrinkled.
    2. Fan the stack to make sure the sheets are separated.
    3. Open the paper support and pull up the extension.
    4. Extend the output tray.
    5. Flip the feeder guard forward. Squeeze the edge guide and slide it left.
    6. Insert paper, printable side up and short edge first, against the right side and beneath the tab.
      You can load up to 100 sheets of 20 lb plain paper or up to 20 sheets of photo paper.
    7. Slide the edge guide to the edge of the paper, but not too tightly.
      Follow these guidelines when loading paper:
      • Do not load paper above the arrow on the edge guide.
      • If you're printing on both sides of the paper, try loading fewer sheets.
      • Load the printable side face-up. It's often brighter or whiter than the other side.
      • Load letterhead or preprinted paper top edge first.
      • If you experience paper feeding problems, try loading fewer sheets.
      • If you're using special paper, check the package for special loading instructions.
    Follow these steps to reload paper in the Automatic Document Feeder:
    2. Tap the originals on a flat surface to even the edges.
    3. Move the edge guides outward.
    4. Insert the originals face-up. You can load up to 30 letter-size sheets at a time. If you load legal-size sheets, insert only 10 sheets at a time. Make sure the originals are not creased or folded and do not have tape, staples, or other materials that could obstruct the feeder.
    5. Slide the edge guides against the originals.
    Feb 27, 2010 | Epson Stylus CX9400 Photo Printer
    When paper is going into the paper feeder it is is getting wrinkled immediately and jamming the feeder
    Sounds like someone got something stuck in the ADF (Auto Document feeder). See if it looks like the paper is really getting wrinkled up more on one end than the other and focus on that side of the feeder. I have seen post it notes cause this problem. People put in their originals and forget to remove post it notes before feeding the documents through. They come off and get stuck in the feeder. Without more detail it is hard to say what is stuck in there but it sounds like there is something impeeding the paper path. Shine a flashlight in there to see.
    Oct 03, 2009 | Minolta Di3010 Copier
    FIRST printed page is quite wrinkled, the rest are fine
    Hello sir;Try to print one page, when the paper process half way then stop the machine, remove the cartridge, check the paper is wrinkling, if yes ,that's meanspaper feed roller dirty or registration roller slipply, ortherwise, check the fusing unit, need to replace presure roller. The 2nd issue, you need to replace paper stop roller or rubber pad.
    May 12, 2009 | Brother HL 5250DN Laser Printer
    Each time I print on plain paper the paper feeds into the machine and when it hits pinch rollers after the print head, the top right hand corner is turned over. Two pages later and the third page is so...
    1. Flip the feeder guard forward.
    2. Remove the paper and make sure it's not curled or wrinkled.
    3. Fan the stack of paper to make sure the sheets are separated.
    4. Reload the paper against the right edge of the sheet feeder andslide the left edge guide against the other side, but not too tightly.
    5. Don't load paper above the arrow mark on the left edge guide.
    6. Make sure the printable side of the paper is facing up.
    7. Flip the feeder guard back.
    8. Once you have completed the steps above, press the cp_button_6.gif Start button.
    Mar 07, 2009 | Office Equipment & Supplies
    My brother hl-5250dn printer is spitting out very wrinkled paper
    It could be the fuser unit. If you open the door on the back of the printer and pull open the paper path tray you will see an orange colored roller. If this roller is wrinkled even just a little it will wrinkle the paper. I purchased fuser roller units for my 5240 and 5250 printers and replaced them myself and that corrected the problem. I got the fuser units from ebay.
    Jul 30, 2008 | Televison & Video
    Printer
    High moisture content in paper,
    or fuser (ie hot bit rear) needs replacement the orange fuser pressure rollers are wrinkled or worn.
    Jan 09, 2008 | OKI C3200n Led Printer
    Samsung ML 1710 Laser Printer Logo
    52 people viewed this question
    Top Samsung Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Victorman
    Victorman
    jasbo
    jasbo
    Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
