Question about LaCie 2-Port eSATA 3Gb/s PCI Express Host Card SATA Hard Drive
LACIE BIG DISK 2.0 USB
THE DISK MOUNTS BUT WHEN ATTEMPTS ARE MADE TO ACCESS IT THE COMPUTER HANGS AND REQUIRES RESETING. I HAVE TRIED VARIOUS FIXES SO FAR AND NOTHING HAS WORKED. I AM RUNNING WINDOWS ME OS. THIS IS THE THIRD SUCH DISK I HAVE RECIEVED FROM LACIE AND THE SAME PROBLEM IS EVIDENT WITH ALL. WHAT AM I DOING WRONG. PLEASE CAN U ADVISE.
REGARDS
TRISH
  • lings
    lings Jan 23, 2008
    hi there, here is my computer specs, don,t know if this will help but the RAM is 1GB, which should be sufficient to cope with HARD DRIVE REQUIREMENTS.
    CPU:
    Intel Pentium 4 HT 2.4Ghz.
    RAM:
    1GB.
    Motherboard:
    Abit IS7-G. Further details available here.
    Graphics Card:
    Abit Siluro FX5600 - Nvidea GeForce 5600 GPU, 256MB RAM.
    HDD:
    Maxtor IDE 80GB, 7200rpm.
    DVD-RW:
    NEC ND-3540A.
    FDD.
    USB 2 and Firewire ports.
    Onboard Gigabit LAN and sound.
    REGATDS
    TRISH
    Problem Solver:
  • 14 Answers
You can try by increasing the RAM of ur Machine
Posted on Jan 23, 2008
6ya staff
SOURCE:
I bought a LaCie 600GB Big Disk USB 2.0 ( 300990U ) at a garage sale and my Dual 2 Ghz Power PC G5 doesn't seem to recognize it. I am running on OS 10.4.11. The power supply seems to work and I have tried...
Chances are it is formatted in a way that OS X cannot detect. See if you can format it using the Disk Utility and then see if that allows it to mount the drive then...
Mar 27, 2011 | LaCie Big Disk (300990U) (LAC300990U) 600...
My LaCie 500 GB external HD is not recognized by my (or any other) computer when connected, attempts to instal driver software fail and the device does not appear in the list of devices with removable...
Your problem could be any one of these issues:
1. Faulty USB port on PC: Try a different computer or laptop
2. Faulty USB cable: Try a different Cable
3. Corrupt memory: Fix by an expert required such as www.SaveMyUSB.com
4. Faulty connections on main circuit inside the hard drive: Physical Fix by an expert required such as www.SaveMyUSB.com
5. Faulty controller chip (worst case scenario) : Direct flash memory read required by an expert required such as www.SaveMyUSB.com
Hope this helps and that it is 1 or 2 as 3, 4 and 5 will cost you money.
Dec 31, 2010 | LaCie 500GB USB 2.0 7200 RPM 8MB 500 GB...
I have 2 Lacie 2TB external drives. 1 of them does not appear anymore on my desktop it did the other day off and on. 1 or 2 times in the rebooting a disk formating pop up appeared saying it did not...
Try changing the USB port to connect it. Also try substituting the cable used to connect the errant disk. It may be a cable issue or a USB port on your computer.
Sep 08, 2017 | LaCie 301294U 1TB Big Disk Extreme + with...
LaCie Big Disk 500GB not showing up
1. the usb connector in the PC may have a broken board contact needs soldering or replacement.
2. there may be a broken USB cord to the external usb drive
3. the electronic controller in the USB case may not be working.
4. A new case may be needed with a new controller.
Jul 08, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
My lacie mounts on the g5 but when i click it, it doesn't open.
It would be a good idea to look at the Mac system log so from a v bad memory do...click Apple (top laft hand corner) then about this Mac then System Profiler then Logs and take a look and see what errors you are getting. If this doesnt give you any clues my advice with external disk problems is where possible to remove the disk from the enclosure and install it in the Mac. if you can, THis will eliminate the USB cable, interface, and box. See if it mounts then. If it does run disk utility to double check it but get your data off first onto the Mac. Hope this helps....Mark
Aug 21, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
Lacie hadr drive problem
Data recovery software.
Check this link:
http://www.software.com/view/8384/72/easeus-data-recovery-wizard-professional-4-x
Feb 06, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
La cie hard drive mount issues
I had the same problem and surprisingly, after many attempts to get the drive to mount with different connections, etc., the problem turned out to be the power adapter. If you've got the same kind of adapter on another drive, switch it out and see if your drive shows up. Good luck.
Nov 09, 2008 | LaCie Big Disk Extreme with Triple...
LaCie Big Disk
Fixya is unable to suggest parts sources.
Dec 17, 2017 | LaCie 301294U 1TB Big Disk Extreme + with...
Lacie big disk 2.0 usb
For anyone with a Big Disk drive that doesn't get recognised by Windows and gets a TUSB 6250 message in Device Manager, the cause is very likely to be the power supply. Although the drive will be powered up, it is not spinning at the correct speed. I tried all of LaCie's technical support suggestions, some of which are outlined above and none worked. They finally suggested getting a new power supply. This solved the problem (Wattac, £22). This problem has affected a lot of LaCie Big Disk owners...
Mar 26, 2008 | Computers & Internet
Open Questions:
Outlook MAil Contact NuMbER {?}{1?.855?.536*?*5666}#[email protected] COLORADO call or contact SbCgLoBaL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL mAiL USA Calling SbCgLoBaL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL mAiL USA's phone numbers against each other. Contacting SbCgLoBaL mAiL USA in General WhileI:855:,:5365666 is SbCgLoBaL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL mAiL USA.
Nov 11, 2019 | Best Computers & Internet
Outlook MAil Toll {1^855^&536^&5666}#[email protected] Free NuMbER HELP DESK call or contact SbCgLoBaL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL mAiL USA Calling SbCgLoBaL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL mAiL USA's phone numbers against each other. Contacting SbCgLoBaL mAiL USA in General WhileI:855:,:5365666 is SbCgLoBaL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL mAiL USA.
See all LaCie 2-Port eSATA 3Gb/s PCI Express Host Card Questions
LaCie 2-Port eSATA 3Gb/s PCI Express Host Card SATA Hard Drive Logo
80 people viewed this question
Top LaCie Computers & Internet Experts
Ekse
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
