Question about Sony KP-65XBR10W 65" Rear Projection Television
Sony kp-65xbr10w led light blinks 5 times
The tv picture also blinks off and on when the tv is turned on....picture is not really clear and dim....any suggestions of what the problem may be???Thanks
  • Anonymous Oct 29, 2008
    I have a simular problem with model number kp-48s75.My sreen is visible but totally saturated in red. I also have the 5 flashes of the LED.This is a code for a tech, but everyone at sony tells me I need to take it to a SOny repair shop.
I have a sony tv model kv36fs17. led flashes 5 times. tv works but no red color. would could be the problem? thanks
Posted on Mar 23, 2008
Hi just to let you know its an indication to your bulb
has gone faulty
its a expensive repair around £300 pounds plus fitting
6ya staff
SOURCE:
What's your problem?Hi, I have a Sony projection TV KP-46WT510 theres no picture or sound, but it still turns on and I can see the the on screen menu. When I turn it on the led blinks four times
You can Google and find the service manual which will explain what the 4 blinks means.
If you have the Sony remote with the set off:
Display, 5, Volume down, Power
If the set has it you will see a box appear on screen with a list of items--all should have a zero to the right of each---one with a number indicates the number of times that error has been detected.
Let me know if you have questions or cannot find what the four means and I will research it.
Mar 28, 2012 | Sony KP-46WT510 46" Rear Projection HDTV
Sony Projection TV KP-65XBR10W 10 years old. The red light on the front blinks in intervals 5 times and the picture blinks to black at the same time some times.
You probably have one or more of the CRT's drawing too much current because of age. The only repair is to replace all the CRT's. The Main problem is the cost involved and the fact that you must send the CRT's back to sony to be rebuilt because Sony no longer sends the assembly with the optic coupler. Sony just does not support the older NTSC sets when it comes to the CRT's.
I hope this helps,
Skyassoc
Dec 08, 2010 | Televison & Video
Led stand by light blinking
No power supply proble Google to Encompass Parts Distribution and type in your model number.
Jun 01, 2010 | Sony KP-46WT520 46" Rear Projection...
Sony KP-65XBR10W had blinking light
In your google toolbar type in Understanding Sony Blinking codes it will then take you to website that tells you what the blinks mean .
Sep 24, 2009 | Sony KP-65XBR10W 65" Rear Projection...
Sony trinitron kv35s26 (August 1997) no video, only audio
this is the best out there , but you will have to use one with the same chassi #
http://www.eserviceinfo.com/equipment_mfg/Sony_2.html
glad to help! plz give time for a good rating, thanks , j (electech)
what another models fault is in the video, should help find you find problem
Sony
Model:kv32s45
Chassis:AA2d
No video, Has High voltage. Turning up G2 show a very dim full raster and on the sides a very bluish faint bar .
Replace Vert. IC561 (TDA8172)
Comments:
need any more help just ask , thanks
electech
Oct 29, 2008 | Sony KP-65XBR10W 65" Rear Projection...
5 blinks, Sony KP-65WS500 stays up only with one CRT gun at a time....
5 times blinks shows White Balance error in tv. You need to adjust Screen Volts (G2) and problem will resolve. Screen volts controls located at Focus Block as shown in below picture.
d90a778.jpg Need further help, please let me know.
Bye.
Sep 09, 2008 | Sony KP-65WS500 65" Rear Projection...
Green lines across screen
check these components in the Video out, IC7101, 7201, 7301 and others in C
board circuit.
Q510,516,524 (A board)
if they are good then the picture tubes would need to be replaced, but since they are no longer available it realy wouldn't matter much would it.
Feb 13, 2008 | Sony KP-65XBR10W 65" Rear Projection...
TV goes out
pyrosp4,
it maybe you blue crt (picture tube). mine turn blue and then shuts off. i got it repaired for 460. 300 for the part 160 to install. you can try to adjust the voltage settings behind the speaker screen and see if that clears the problem. if not its you blue crt.
pridah
Dec 18, 2007 | Sony KP-65XBR10W 65" Rear Projection...
Sony KP-FX432M91 TV 10 blinks
my sony kp-fx432m91 has a 10 blinks problem. it has no pictures but has sound that goes off after 5 seconds please advice on what to do.
my email address is [email protected]
Oct 31, 2007 | Sony KP-FX532M91 TV
Sony KP-65XBR10W 65" Rear Projection Television Logo
333 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
