Question about Philips 42PF7320 42 in. EDTV-Ready Plasma Television
Screen flashes colors then turns off
The cable company sent a signal to there box to temporarily turn it off. Ever since that when I turn it on the screen will flash colors and then turn off.
  • 138 Answers
Check connector between Logic & PSU 2nd pin from Left (Vs_ON) for DC volts.
If Voltage is 0 then problem is with Logic or SSB.
If Voltage is 3.1 VDC then problem is with PSU or other PCB's on Panel.
On startup Logic checks for errors and also polls the SSB for Errors. If Errors found then Logic will not send High to PSU.
To confirm if SSB or Logic is at fault then disconnect and remove SSB.
Use 2 Jumpers to short J8003 & J8004 on the left edge of the PSU
Use 1 Jumper to short CN2012 on the lower left part of the Logic PCB (White signal to the Display).
Plug in the AC to the PSU thru CN8001.
If PDP panel operates with White field screen then problem may be the SSB.
Posted on Aug 20, 2008
You gave too technical an answer . I'm 80 years old & don't know what you are talking about.
Assuming you have a TV hooked up to some kind of cable box, I would venture to say the TV is telling you it is not receiving a signal from the cable box.
Two things could be the problem;
1 You are on the wrong channel to receive a signal - some boxes send the signal to you on channel 3 - if your TV somehow got changed to channel 4, for example, it would not recognize the signal from the box. Make sure you are on the correct channel setting.
2. The cable box may not be turned on or formated properly. Turn the box off and then back on after a few minutes. Follow any messages on the screen on the box for a proper start-up.
If nothing helps, call your cable company for assistance..
Feb 23, 2015 | Televison & Video
Red power light flashes and set wont come on
Turn off the tv for five minutes and then turn on..
Can u tell me model no and company name so that i can help u clearly
thank you
Oct 12, 2008 | Hitachi 46F510 46" Projection HDTV
I have a westinghouse LCD model EW37S5KW unit. box.
What do you mean by primary color? can you attach a picture plz?
The problem you are talking about is most likly the panel.
Jan 08, 2014 | Westinghouse Televison & Video
When I turn my hitachi flat screen tv on,
you are not getting a signal change soure ie box or dvd player and input jack then try
Jul 26, 2010 | Hitachi 32HDT20 32 in. Plasma Television
Original installation color flared up around edges and outlines
what she tried to sell her was and HDMI cable for hi def signal between box and tv. now with what your describing sounds like panel solarization. if you can send me a pic i could better verify your problem. sent pic to
Apr 27, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
When i turn on my screen it says no signal and turns off
Either the "data" cable between your screen and your desktop is defective, or that cable is not connected to your screen, or that cable is not connected to your desktop, or the video-card inside the computer is defective.
Check the connections.
Temporarily connect the screen to a different laptop/desktop computer, to see if the screen still works.
Temporarily connect a different screen to your desktop, to see if your desktop's video-adapter is working.
Feb 28, 2010 | eMachines W3507 PC Desktop
Sony kdl-40v5100 has handshake problem
1.This issue sounds as though the TV connection circuit has an issue.
2. You have changed the DVR and the HDMI cables and you still have an issue with the video (pink screen) indicates a video circuit issue ( improper voltage or current) at the video section of the circuit.
3. This will require some troubleshooting by a qualified tech.
4. To make sure, try connecting another properly working LCD TV to the cable box or DVR an check.If you get a picture and sound properly it is the TV.
5. Usually a cable box is QA'd (quality assured) by the company and will not be sent unless tested 1st
Feb 05, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
Toshiba 37WL66AS LCD TV troubleshooting color control Our Toshiba 37WL66AS LCD TV has an image color problem. Ever so often the screen goes reddish (especially skin tones). Turning the TV off for greater...
my toshiba around 6yrs. old...this morning when i tried to turn it on,..nothing...i have cable so i use a "box" & my cable company remote...i can turn on the box manually..the remote turns on my dvd player.{sony]...we had a blizzard start during the cable company said they were having problems..i cannot turn on the tv does nothing at there a safety feature that is causing the problem?..the model number is;27df46...serial number;BAB614020144A...PLEASE ADVISE...Fiona Duffy
Dec 05, 2009 | Toshiba Televison & Video
Select Language
With electronics sources or monitors,asking a language preference is a first or early step in initial programming.To analyze the source of the "which language " request--dis-connect the cable box temporarily and hook up signal direct to tv.If ? is still there,the tv is asking it. If ? is gone,then the source box was asking. Any further assistance needed,please let me know.
Oct 03, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Philips 42PF7320 42 in. EDTV-Ready Plasma Television Logo
55 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
