Question about HP ScanJet 4850 Flatbed Scanner
HP Scanjet 4850 will not scan
Software installed correctly.s
Can open HP Document Viewer-Scan a New Document - Scan from Scan Doc button
Dialogue box popup - The Application is in Use
Dialogue box popup - hpqscnvw encountered problem & needs to close
Dialogue box popup - Unable to communicate with HP scanning software
Dialogue box popup (from Spybot Search & Destroy - as follows:
System Setup Global Entry
Change : Value deleted
file: zzzHPsetup
Until this week, the scanner was working for the past 12-18 months without a problem. When starting up a few days ago, the HP software began to ask me to insert the disc so that it could initiate.
Running Windows XP SP2
I have run RegCure and several spyware Programs, (Adware SE, Spybot Search & Destroy, Spyware Terminator & Super Anti Spyware) in an effort to clean my PC from a malware attack (Ziob)
Any help appreciated. Thanks, Raymond (rkcs@verizon.net)
  • trybka Sep 01, 2008
    HP Scanjet 4850 can not scan, after moving it to other place it is not working, before was ok., now can not find document viewer and wants to get it from CD room, but can not and all the system is hung up.
  • fixyafan2008 Oct 01, 2008
    Hello everybody
    Every time I scan negatives or tramsparency with my hp 4850 scanner a horizontal or vertical line appears in the scan depending upon the orientation of the material. I traced this problem to a very fine line scratch in the translucent material covering the lamp in the lid.
    Q. Is there an easy way to replace this translucent strip ?
    Regards
    ik
5 Suggested Answers
SOURCE: HP Solutions Center can not communicate with HP 3500c Scanner
Had exact same problem. Went to HP site and they said to check "add or remove programs" functions (in control panel) and if there are multiple copies of HP software to download their fix. I checked, had multiple copies, downloaded patch and all worked well again.
Posted on Nov 06, 2008
SOURCE: Can't install my HP Scanjet 3970!
Billy,unplug the scanner.go into device manager and remove/uninstall all drivers for the scan jet.reboot computer.go to hp site and download new drivers/set-up.reboot computer.hook scanner back up to pc.pc shuld see the device and load drivers .if not go back into device manager and find/click on scanner.tell it to update drivers it shout do this automaticly..but if not point it to the new drivers.update.if you still having a problem or i have confused you contact me here.RICHARDM69
Posted on Dec 06, 2008
ziraffa
  • 827 Answers
SOURCE: Unable to scan using HP Scanjet 3200C in Win XP Pro
Hi Shantala,
HP advises that, on some systems, the scanner hardware may get into an error state that will keep the scanning software from finding the 3200c ScanJet. If your scanner still isn't found after installing this driver and software update, please follow the directions below:
  1. Unplug the power cable from the 3200c ScanJet.
  2. Unplug the parallel cable(s) from the 3200c ScanJet.
  3. Shut down the PC and wait for ten seconds.
  4. Plug in the power cable to the 3200c ScanJet.
  5. Plug in the parallel cable(s) to the 3200c ScanJet.
  6. Power your PC on.
If you still have the problem, uninstall the driver from device manager, and download and run this .exe file version of the driver instead.. and if necessary, repeat the above steps..
ftp://ftp.hp.com/pub/softlib/software4/sj648/sj-1436-3/sj648en.exe
Hope this helps
Chris (ziraffa)
Posted on Dec 22, 2008
SOURCE: hp scanjet 5300c vista
I had the same problem. I tried various compatibility settings (without success). What fixed it for me was going to the Compatibility tab and checking the "Run this program as an administrator" box.
Posted on Dec 31, 2008
Scanjet 4600 is stuck halfway through scan
About 2,970 results (0.68 seconds) Search Results
    HP Scanjet Scanners - Scanning Stops at the Preview ...
    h20564.www2.hp.com/hpsc/doc/public/display?...na...
    Hewlett?PackardWhen attempting to scan from the front panel of the device, the Scan Preview window displays normally but does not show the document or picture being ...Missing: 4600
    Scan stalls half way through and never finishes - HP ...
    h30434.www3.hp.com > ... > Scanning / Faxing
    Jan 11, 2011 - 7 posts
    More times than not, the scan stops part way through (example attached) and then (after several minutes) displays the messages below:.Missing: scanjet ‎4600
    issue Scanjet 5590 windows 7 Business 64 bits - stop during
    Jan 19, 2010 - 10 posts
Feb 05, 2016 | Office Equipment & Supplies
When I scan a negative, all I get is a picture of this negative which is useless. I thought that I could get the picture out of the negative that I scanned and save it so that I could get rid of the...
With the scanner you should have received a cd "HP Scanjet 4800 Series HP IMage Zone Software. Mine is version 5.3 for Windows/8.4 for Mac OS v 10.2.
I have this installed on a pc.
When the button on the lid (2nd from left ) is pressed this opens a window HP Scanning.
On this is an option to "Scan Negatives using the TMA (Transparent Materials Adaptor)" Select this and follow any further instructions concerning optons.
Jan 20, 2011 | HP ScanJet 4850 Flatbed Scanner
The scanner keeps jamming. i try to scan form the document feeder &the papers keep getting stuck. It will not complete a scan!what do i do?
In summary: * Very unintuitive, convoluted and unpleasant to use (same on Win2K as XP) - sometimes the SW hangs during scan and needs a reboot - sometimes the SW crashes with a dialogue "try reinstalling HP software", and needs a reboot - sometimes it scans and after conversion to pdf
Advantages: I cannot see any advantages with this product
Disadvantages: Software is convoluted and unreliable, paper jams are difficult to clear
function showHideReviewText( sType ) { if ( sType == 'more' ) { document.getElementById( 'review_text_full' ).style.display = 'block'; document.getElementById( 'review_text_short' ).style.display = 'none'; document.getElementById( 'review_title_link' ).onclick = function() { showHideReviewText('less'); }; } else { document.getElementById( 'review_text_full' ).style.display = 'none'; document.getElementById( 'review_text_short' ).style.display = 'block'; document.getElementById( 'review_title_link' ).onclick = function() { showHideReviewText('more'); }; } } ...with a dialogue "try reinstalling HP software", and needs a reboot
- sometimes it scans and after conversion to pdf every page is blank
- very occasionally it scans a document properly
*If the sheet-feeder jams is says to refer to the documentation to clear it, which doesn't exist. There is no way to clear the jam except to pull hard & hope. No levers to release it like one would expect.
*Frequently has error ...
...cycled to work again.
Everything has to be started by pressing a button on an application called "HP Director". There are 4 apps started from this:
1) Scan Picture
2) Scan Document
3) Make Copies
4) View & Print
also Help
also Settings (which are used in conjunction with settings found in (1) and (2)!)
- Each application has to be exited to return to "HP Director"
its a worst scanner
and prone to jamming problem
Jun 09, 2010 | HP Scanjet 5590 Flatbed Scanner
I have an HP Officejet 6500. I want to scan a document to a PDF, then upload it to a website. How do I do it? I scanned the document, but now I can't find the PDF.
(1.) Start / All Programs / HP / HP Viewer / Scan Document (icon is in left margin)
(2.) A small screen appears entitled "Select Source", and provides the "HP Officejet 6200 Series TWAIN" option. Highlight this then click "select".
(3.) I accept the default provided on the next screen (i.e., radio buttons for "Document" & "Scan for editable text"; "Scan to:" (drop box) "HP Document Viewer; check "Show Preview" box; then click "Scan".
(4.) After a brief pause, my printer scans, then the HP Document Viewer screen on the PC provides a small image of the scanned document and allows me to click the "accept" icon.
(5.) After "accepting" the scan into the HP Document Viewer, it takes a minute for it to appear in the "viewer". Notice that the "View Thumbnails" tab is highlighted at the top of this screen. Click the check-box next to the scanned item then click the "View Page" tab just to the right of the "View Thumbnails" tab.
(6.) The new screen should show a larger version of your scanned document. Now notice the "Save As" icon in the upper left corner. Click that, then "yes" to warning default screen, then select a file name and location to save it into.
(7.) Before clicking save, click the drop box next to the "Save as type:" and select one of the pdf options. Mine offers: "PDF 1-bit", PDF 8-bit Grayscale", and "PDF 24-bit Color" options. Choose one of them then click "save".
(8.) You should then be able to find the scanned pdf file in the directory you selected to save it under.
Note that you may need all of the HP printer utilities and tool software installed for this to work. If you don't, you may need to uninstall/reinstall the printer software.
Nov 06, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Problem using OCR with Canon MP610 all-in-one
I got this message too, before I installed an OCR program. It may be that you need to install one (or specify it, if you have one already). With my MP610, an installation disk was included that contained the OmniPage SE program for OCR. When I installed that on my computer, and told MP Navigator (another Canon-supplied program, that controls scanning) to use it as the "Open With" program for OCR, it worked.
Dec 15, 2008 | Canon MP610 Photo All-In-One Printer
Scanner not found
Macintosh: Scanning Software Does Not Open or Stops Responding in Mac OS X V10.4
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01396146&lc=en&dlc=en&cc=us&product=1138342&rule=15414&lang=en
The link will take you to the HP page where the handle for this problem is detailed. I did every step as listed and downloaded updated driver / software for the 4315. It works!
Aug 04, 2008 | HP OfficeJet 4315 All-In-One InkJet...
HP C6180 won't scan to word or document viewer etc etc
the save as function is in the print/scan manager, not the software..you'll need to point it to where you want it to save, and also what format
May 28, 2008 | HP Photosmart C6180 All-In-One InkJet...
Horizontal Lines
This might be a hardware problem, but it could also be caused by an outdated (or corrupted) driver; you could uninstall the original driver, then download and install the newest version directly from HP here:
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&dlc=en&product=446435&lc=en&jumpid=reg_R1002_USEN
If that link is broken, or doesn't work for you, use this one:
http://tinyurl.com/2n7lge
Also, I've copied the following information directly from the HP 4850 Scanjet user's manual:
If you have the HP Image Zone software installed, you can use the onscreen Help to solve other problems with the scanner. To gain access to the Help, open HP Solution Center, click Help, and then click HP Scanjet 4800 series scanner Help. The Help system provides information about the HP Scanjet 4800 series scanner hardware as well as information about the HP Image Zone and HP Scanning software itself. Also, see Scan troubleshooting in the general Troubleshooting and support section of the Help.
Good luck with this; let us know what you learn...
Jan 26, 2008 | HP Scanjet 4850
HP ScanJet 4850 Flatbed Scanner Logo
273 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
