Question about Smart BUY NW9440 C-DUO 2048/80 17.0 WSXGA HDD 802.11A/B/G WIN XPP (RM122UT) PC Notebook
SMART failure possible hard drive
I was using my computer when it just shut down. Now all I have is the BIOS screen (Dell Inspiron 1000) that tells me that there was a possible hard drive failure and that I should do a back-up asap. I dont know how to do a back-up in BIOS. Can you help?
    Genius:
  • 1,067 Answers
U cant best bet pull it out get pcmia mini hard driver ready on ebay 5 bucks plugs your labtop drive in big computer then u can pull info off it install new driver go get one at best buy u will need to reboot xp on it redo all that
Posted on Jan 23, 2008
1000-0143 Dell error
This error code is related to " Drive Smart read command failed."
POSSIBLE LINK to fix: -
http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=dhs&docid=266787#HDD
Remove and reinstall the Hard Drive for the error codes:
  • 1000-0141
  • 2000-0141
  • 1000-0142
  • 2000-0142
  • 1000-0143
  • 2000-0143
  • 1000-0144
  • 2000-0144
  • 1000-0145
  • 2000-0145
  • 1000-0146
  • 2000-0146
  • 2000-0151
Please see the Service manual for instructions on how to remove and replace the Hard Drive. Be sure to remove and reinstall the cables for the hard drive if you are on a Desktop Computer.
After reinstalling the hard drive re-run the diagnostics if you receive the same error code Contact Us.
Run the Drive Self Test (DST) from the Utility Partition also known as the 32 bit diagnostics to determine if the previous error has been corrected. If the DST from the Utility Partition does not indicate a failure of the drive, we consider the error to have been corrected and the drive does not need to be replaced.
  • 1000-0146
  • 2000-0146
Mar 04, 2012 | Dell Latitude D810 PC Notebook
Remove or reset Dell inspiron 530s bios password
try this:
1- shut it down then open the computer box
2- find a green or blue jumper beside the memory slot or Data cable slots
3- remove jumper , then turn computer on
wait for 10 sec then shut it down
4- put the jumper back and close the computer box
5- turn the pc on and have fun
Feb 08, 2012 | Dell Inspiron 530s Desktop Computer...
Blue screen flashes when computer starts up it says UNMOUNTABLE____BOOT-_____VOLUME
thats a hard drive problem you have to take the hard drive to a tech to recover the data by doing a dirty installation and then you have to replace the hard drive becoz it might give you a smart error and you will not be able to recover anything
Oct 27, 2010 | Dell Inspiron 1000 Notebook
Computer will not boot up.
That means the BIOS is looking for a floppy drive that possibly doesn't exist.
Go into the BIOS by pressing F2 and where it says diskette drive on the main screen, highlight it and choose the option to disable it. Then save changes and let the machine reboot. This time it shouldn't look for it and it will go thru into windows.
Jan 11, 2010 | Dell Inspiron 530 Desktop Computer
My dell inspiron 1000 will not boot without a password and i have no clue what it is and the backdoor passwords didn't work
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-1000-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
Nov 29, 2009 | Dell Inspiron 1000 Notebook
Possible water or hard drive damage to Dell Inspiron 1000 Laptop
its fryed the GPU, sorry it won't work anymore, unless a miracle happens. If it was off and you left it off until it completely dried out (6-7 days) it would of still worked.
Sep 27, 2009 | Dell Inspiron 1000 Notebook
Dell 1000 Inspiron won't get past start up screen, frozen
Had this exact problem on the same model (Dell Inspiron 1000) laptop. Solution was simple: remove battery, problem goes away. I guess the battery was so far gone it was hanging the BIOS on startup.
Sep 17, 2009 | Dell Inspiron 1000 Notebook
Screen comes up stating; self monitoring system
The error refers to the SMART system (read more about it).
Your hard drive may be getting ready to fail or you may have received a false error message (which can occur). If possible go into the bios/CMOS and disable the SMART system so that you may be able to boot normally. Once booted you need to make a backup of your data immediately.
If you are unable to boot the machine even after disabling SMART you may need to replace the hard drive and hook the old one up either externally (the preferred method) or as a slave so that you may backup the data on it.
Mar 02, 2009 | Dell Inspiron 530 Desktop Computer
Dell Inspiron 1000 will not boot up.
Greetings,
The symptoms you described are normally common motherboard failure signs.
Try removing the ram and hard drive from the computer and then try booting the computer.
Oct 28, 2008 | Dell Inspiron 1000 Notebook
My Laptop Dell Inspiron
Check the disc for scratches, this could be a bad disc. However, I'm leaning towards another issue besides the hard drive being bad. Tell me what initially happened to make you buy a new hard drive. Hard drives aren't effected by the heat produced by the machine, so tell me what made you think it was heat that caused the hard drive failure.
Jul 08, 2008 | Dell Inspiron 1000 Notebook
Smart BUY NW9440 C-DUO 2048/80 17.0 WSXGA HDD 802.11A/B/G WIN XPP (RM122UT) PC Notebook Logo
104 people viewed this question
Top Smart Computers & Internet Experts
Computer Links
NOEL
NOEL
Vebble
Are you a Smart Computer and Internet Expert? Answer questions, earn points and help others
