Question about Garmin GPS 126 GPS Receiver
Internal wiring The previous owner of the unit replaced the connectors on the unit and i think he didn't connect the wires correctly. most wiring diagrams  show the wiring for the external cable  which does not correspond with the wires that are connect to the pc board inside the unit. Can anyone tell me which wires to connect to serial port on pc and to which pins?
  • 59 Answers
Hi - I have a Garmin GPS 126 in bits on my desk ready for a new cable as the socket in the back has some broken pins.
Also refer to the Garmin GPS to PC Wiring Instructions here on the Garmin site: http://www8.garmin.com/support/faqs/faq.jsp?faq=68
The internal 8 pin white connector on to the back of the circuit board is as follows:
1 Red Positive
2 Black Negative
3 Yellow Data Out
4 Green Data In
5 not used
6 not used
7 White Alarm
All the best, Tony at KiwiGPS, New Zealand
Posted on Apr 25, 2009
Where is the fuel pump relay on 2006 Dodge Ram 1500 4.7
There isn't a fuel pump relay , it is controlled by the totally integrated power module !
MODULE-TOTALLY INTEGRATED POWER
DESCRIPTION
The Totally Integrated Power Module (2)(TIPM) is a
combination unit that performs the functions of the
Power Distribution Center (PDC) and the Front Control
Module. The TIPM is a printed circuit board based
module that contains fuses, internal relays and a
microprocessor that performs the functions previously
executed by the FCM. The TIPM (2) is located in the
engine compartment, next to the battery (1) and connects
directly to the B+ cable (5) via a stud located on
top of the unit. The ground connection is via electrical
connectors. The TIPM provides the primary means of
voltage distribution and protection for the entire vehicle.
The molded plastic TIPM housing includes a base and
cover. The TIPM cover is easily opened or removed
for service and has a fuse and relay layout map integral
to the inside surface of the cover. The TIPM housing
base and cover are secured in place via mounting
tabs. The mounting tabs secure the TIPM (2) to the
battery tray mounting bracket (3).
OPERATION
All of the current from the battery and the generator output enters the Totally Integrated Power Module (TIPM) via
a stud on the top of the module. The TIPM cover is removed to access the fuses or relays. Internal connections of
all of the power distribution center circuits is accomplished by a combination of bus bars and a printed circuit board.
For complete circuit diagrams, refer to the appropriate wiring information. The wiring information includes wiring
diagrams, proper wire and connector repair procedures, details of wire harness routing and retention, connector
pin-out information and location views for the various wire harness connectors, splices and grounds.
Sep 07, 2015 | Dodge Cars & Trucks
I have a 2007 trailblazer. The rear speakers didn't work and some of the head unit lights didn't work. I replaced the headed unit and that didn't fix it. I then replaced both speakers and one...
Put new wireing in going to both back speakers, Factory wireing is verry thin end it breaks with age. Change it over to at least 16 guage speaker wire or 12 guage, Your system will sound a lot better.
Oct 26, 2012 | Cars & Trucks
I need to disconnect my battery in my 2005 GMC SIerra.....I do not have the code for my radio and I don't want to the radio when I am done working on my truck any ideas.
I'm not sure why you need to disconnect the battery but if it's to replace it you can connect another 12 volt battery to your truck with jumper cables or jumper wires. Connect the negative post to an engine ground and the positive to the positive jumper post. It's under a red plastic cover near the driver's side front of the engine. Just be aware that the positive battery cable is live and you'll have to be careful that it doesn't come into contact with a ground. That radio should have no code in it unless it's programmed by the owner. The default code is 4 zeros. If you bought the truck new and you didn't program a code into it you should be OK. Check the owner's manual. If you didn't buy the truck new and the previous owner programed a code into it your only chance is to get it from that owner.
May 03, 2011 | 2005 GMC Sierra
I purchased a 30yr old home with a garage heater and the internal wiring was totally messed up. It is a “Utility” brand by “Zero-Climate” out of Hayward, Ca. The model on it is “50 UF-5″. It is a...
your best bet is to google the make and model , is there a pressure on it try jumping this out if it has one check rubber hose to it might be spit or just old
Aug 31, 2010 | Dayton (3E386) Heater
FRS 2800 Mackie Amplifier Connection Problems
that sounds like an internal connection problem, try getting inside the unit to where the internal wiring is connected, if you have signal coming through well thats a big plus, see if there are any loose wires or if the internal connection is damaged, would probably pay to replace the complete terminal, should be able to pick up XLR connections fairly easily from any electronic spare part dealer, trouble with this type of gear is that the connector is continually being used, so over time they do wear out or suffer damage
May 30, 2010 | Mackie FRS 2800 Amplifier
All the lights work,but the one on the left brake light stay off. The plug was burn all around the outside of it and in side some. I replace the lamps,the lamp plug's.I think it maybe the housing'I can't...
You said: "The plug was burn all around the outside of it and in side some"
I've had similar issue in my previous vehicle; in my case the connectors to the headlight switch unit was clearly burnt. and, even after replacing the headlight switch unit, the lights (switch) failed under a year and required replacing the switch again. (hindsight: i should have had the wiring looked at and fixed instead)
Logically, your issue sounds like a short in wiring or in plug/socket connections.
Someone more qualified will need to respond to this post...
Good Luck!
Feb 16, 2010 | 1998 Jeep Grand Cherokee
My 12000 watt powermate generator isnt sending any power to the plugs . there seems to be two yellow wires with female flat connectors that arent going to anything . i just picked this up used and i think...
the four pin connector is a part of the auto-shutdown when over heated system..one of the yellow wires goes to the panel (in the back there is a flat male connector) that one is connected to the on/off switch.. if this is not what your talking about send me a picture of your problem to sal_kh_sab@yahoo.com
Sep 02, 2009 | Electrical Supplies
Gm 32 pin
then you have a problem with the wires that were probably cut during that install from the previous owner, and you need to undo them and reconnect them again, cause they aren't staying connected. I am almost sure he cut something to cause this when all that needed to be done was to use a wiring connector made for his car to adapt to the new radio when it was replaced.
Oct 01, 2008 | 1998 Oldsmobile Aurora
LG REAR PROJECTION RT48SZ40RB
SMPS power board has packed up. Mine did it about 2 years ago and has just done it again. DC bus should be between 360 and 400 volts dc. Mine was up around 420.
Jul 04, 2008 | Televison & Video
Garmin GPS 126 GPS Receiver Logo
337 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
