Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Leaking solution tank / m/n f5881-900
After installing filled solution tank onto scrubber unit, the solution drains out the bottom of sweeper.disassembled entire unit. checked all hoses,
valves,manifolds,fan and all connections and found no obvious problems.
all other functions seem to work properly. thank you
  • SpiritQuest Jan 24, 2008
    Bought a new clean water tank when old one cracked. Put tank in place, and for the first time since purchase, my Hoover V2 lets the clean water go straight through and drain out onto the floor from the sprayer nozzle, with the handle not depressed. Coincidence?
    President:
  • 1,673 Answers
Check th reservior unit, part #43516008, is the solution tank seal that sits on top of the reservior unit ok and in the right position? Is the control rod, inside the handle releasing when yuou release the trigger? Are the hoses attached to the reservior unit. May have to replace the reservior unit. Also check the valve at the bottom of the tank to make sure it isn't stuck open. Push it and see if it comes back down. Here is a picture that may help:
leaking solution tank / m/n f5881-900 - 52d0ea0.jpg
Posted on Jan 24, 2008
My Bissell proheat2x leaks water from bottom of machine, if you have the water tank full and cleaner and leave it sit it drains out onto the floor, it leaks when you are using it to, is this a seal or...
Nope, not a seal problem, just natural good old fashioned natural gravity. I know it doesn\'t take long for it to start leaking after use but Bissell covers this in the manual. Thoroughly clean the unit, run clean rinse water through every cycle and empty all tanks and cavities after use. Do not leave water in any of the tanks when not in use. What doesn\'t leak on your floor (which doesn\'t take long) could cause permanent blockages in the lines. It\'s a pain, I know, but I use the garage or back deck to park and prep mine after use.
Aug 15, 2013 | Vacuums
When trying to scrub rug, the cleaning fluid runs out but the scrubber will not **** it back up. My rug is soaked!
You have an air leak. This is almost always caused by the lid not being correctly installed on the recovery tank. Remove the lid, hook it in the back, and snap the front latch in place. A less common problem is that the square duct on the front of the lower tank has been removed to use the attachment hose and not put back in the tank after use.
Feb 02, 2011 | Hoover SteamVac F5914-900 SpinScrub...
No water when i start the machine
- Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.
- Check for debris on spray tips. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.
- Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
Nov 23, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell proheat 2x not spraying water
Please check the following with liquid in both tanks.
Nov 03, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
We cannot get the water and soap to dispense in out Bissell steamcleaner
Check to ensure there is liquid in the water tank and the formula bottle.
Note: This machine will spray with liquid in the Water tank only if the machine is set to the Water Rinse setting. On any other setting, you need to have liquid in the formula tank as well.
If no: add liquid to the Water tank and the Formula tank.
If yes: check each of the following....
-If everything is seated and attached properly, prime the machine by turning off the power, waiting one minute, and then turning the power back on and depressing the trigger on the handle.
- If priming the unit fails to fix the problem, remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
Aug 13, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell steam cleaner will not spray any water
Jun 15, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water leaking
The water tanks on this unit have had a very bad history of leaks. Most of the repair people had never heard of this unit, but one did, and had a spare set of tanks. If the unit is still under warranty, it is worth your while to get a replacement unit. Call Eureka, and ask them how to get a replacement unit, especially if you are having more than one issue with the unit (such as leaking, no heat, broken upholstery nozzle, etc.). I had success in sending back the serial number plate and a detailed list of my problems. They sent me a new unit, and I was able to get at least one unit working properly. Some repair men may be able to fix leaks in the seals on the tank. Hold the tank up and if it leaks, well you got your problem! Eureka will not solve your problem, I've discovered they like to let their service depots handle their junk. Most service depots can give you a solution if they are worth their salt. If the service depot can still get tanks, go that direction. If no replacement tanks are available, call Eureka for a whole unit.
Sep 16, 2008 | Eureka Atlantis 2595A Upright Wet/Dry...
Leaking
If the seal and plungers are ok(bottom of tank), then most likely have a crack on the bottom of the tank, lot of times it will be under the seals, breaks away and will like out.
Dec 24, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
190 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
