Question about Whirlpool 24 in. GU1500XT - Multiple Color Built-in Dishwasher
Dishwasher not drying well
My dishwasher has stopped drying very well. It previously would dry even the plastic containers and plastic cups well, but now most everything plastic and some glassware is still wet when the cycle finishes. Does this sound like it is the heating element that we need to replace?
  • 185 Answers
SOURCE: Whirpool 1100TXP Dishwasher.
is your water temp set at 120 degrees
Posted on Apr 08, 2008
  • 77 Answers
SOURCE: Won't run - normal light flashes
You may try removing power to D/W for a minute and reconecting. likely cause though is keypad (console). If a light above a pad stays on the pad is likely closed all the time. Normal is probably cycle most often used. you can test the keypad by removing power to D/W and accessing the control panel. remove conncter P-1 and using an ohmeter test resistance between 13 and 4 on the connecter coming from keypad. yes without very small clips or 4 steady hands it is a little tricky. in the field we use a breakout board. if you get any reading when not pushed pad is bad. you may find a manual inside the kickplate which explains the keypad sequence. it may be control but more likely keypad, even if test is inconclusive.
Posted on Jun 07, 2008
SOURCE: dishlex dx 302 heat drying
Our heater wasnt working either, read your comments, pulled it apart and bingo! a dry solder on the 12V relay. Thanks everyone you've saved my sanity!!
Posted on Jul 12, 2008
  • 2651 Answers
SOURCE: How complicated is it to replace the heating
would be easier to remove the dw form the cabinet , at least partially. Hopefully there is enough slack in the electrical line as well as water feed line. sometomes you can walk the d/w out woithout disconnecting them. the heating element can be unscrewed from underneath( 2 white lug screws mount them to the underneath of unit)..
Posted on Feb 23, 2009
  • 102 Answers
SOURCE: not drying. heating element bad? easy to change?
Check the heating element to see if it is bad. If you just order a heating element for it, it will come with an element and a new control board. That should take care of your problem. Remember use only powder detergent in your machine. No tabs and no gel.
Posted on Apr 11, 2009
  • 90 Answers
SOURCE: dishes still wet
You need a new heater element . Get engineer to fit for you.Cheers,Derek.
Posted on May 19, 2009
0 characters
1 Points
Is there a heated dry feature on the Dacor? When I open the door at the end of the cycle there is still a lot of moisture and water droplets in the unit.
Below is a website with information about your dishwasher. It says it has a condensation dryer which means it dries the dishes using the heater coil in the bottom of the unit. This is a very slow process which continues to dry even after the unit has run all of its cycles. Usually over night they should be dry but any puddling water left on the dishes such as an over turned mug or cup will still be left on the dishes. The drying is done in this way to prevent damage to delicate glassware or melting plastic items in the unit. There is no dishwasher available that can fully dry the dishes due to the possibility of damaging your dishes.
Sep 28, 2010 | Dacor ED24 Built-in Dishwasher
The soap container will not open during the wash cycle. The soap is still there after the whole cycle including drying is done.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
Sep 07, 2010 | Asko 24 in. D3112 Free-Standing Dishwasher
What causes the pungent odor in dishwasher? It seems that the all the water are not being dried
Hi, this is a very common problem and can be sorted out easily, rather than explain it here i include some weblinks that explain it all in detail. plus my favorite below.
Here is one that takes the smells, hard water stains etc out of your dishwasher and plastic and glass ware. Fill up dishwasher, with plastic glasses, glass ware, dishware. No metal, of any kind! anything you want sparkly and clean.
No detergent! Fill up a small bowl at the Bottom of the dishwasher with vinegar, 1 cup of white. Run the cycle, do not dry. Fill up with 1 cup of bleach, run again. This takes care of all hard water stains, germs that are causing smell etc. Also check for food at the bottom of the dishwasher.
The site below explains WHY you get those smells.
Aug 19, 2010 | Samsung 24 in. DB5710DT Stainless Steel...
The dishes are still wet after "drying" overnight?
With the energy efficient dishwashers today it is very important to use rinse aid for proper drying. The rinse aid will help sheet the water off of the dishes prior to the dry cycle. If you do not use rinse aid you can expect poor dry performance.
Next to the detergent cup in the door is the rinse aid dispenser, be sure it is full. You only need to fill it about once a month. There is also a product called "Turbo Dry" that you can use in the rinse aid dispenser, it helps dry even plastics very well.
Next be sure you have selected heated dry on your options.
Sani Rinse will also help as it heats the water before the dry cycle.
Let me know if you have questions.
Aug 01, 2010 | Whirlpool DU1055XT 24 in Builtin...
We have had an LG 7810 dishwasher since 2007. There is a film always left in the bottom of the dishwasher (large area, covers most of the bottom, not just near the drain) and a moldy sludge that builds at...
when you are done doing your dishes are they hot? do you see steam comeing out the dishwasher?
if no you have a bad heater
try heated dry are they dry at the end? not including plastic they never dry and the tops of cups.
how often do you use the dishwasher?
Jun 19, 2010 | Dishwashers
Had the same problem (apart from the code) and the answer is to stop putting plastic in the machine ! It seems the dishwashers need the heat radiated from the Ceramic plates, stell knives etc to help dry. The plastic simply absorbs some water and then your dishwahser spends most of its drying time trying to get that water out again. Also Plastic doesn't radiate any heat to help. As soon as we stopped putting plastic plates and tupperware containers in, hey presto the dishes are drying again
Apr 13, 2010 | Kenwood KDW243A Builtin Dishwasher
Had the same problem and the answer is to stop putting plastic in the machine ! It seems the dishwashers need the heat radiated from the Ceramic plates, stell knives etc to help dry. The plastic simply absorbs some water and then your dishwahser spends most of its drying time trying to get that water out again. Also Plastic doesn't radiate any heat to help. As soon as we stopped putting plastic plates and tupperware containers in, hey presto the dishes are drying again
Apr 12, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwasher is not drying properly and is out of warranty. Saw a post that LG has a free retrofit to fix problem but customer service denies. Is there a recall on the LDS5811ww?
No recall.
You should use water temp 120 to 150 F, and make sure you use rinse aid (such as Jet Dry). Plastic items (like cheap advertising cups or storage containers) do not have enough mass to retain heat and dry very well. Item with more mass (glass and metal items) will dry as long as you conform to listed perameters listed above.
Oct 16, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Tub still wet/ not drying
YOU NEED RINSE AID ! ! Make sure your selection option is HEATED DRY.Please rate this !
Jun 06, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher does not dry the dishes thoroughly
I have a GE dishwasher with poor drying. One service call said to make your water hotter and us a jet dry rinse. Not any better. Another call went to GE, this time they have a vent kit to help push out the steam and the computer will be reprogrammed to allow a longer dry time. Will have this done when the parts arrive at my home. Then the repair man will install and make computer adjustments. Looks like GE knows they have a problem but won't fix it until you complain more than once and demand a fix. For all GE dishwasher owners with this problem start calling the customer service.
Feb 05, 2007 | Kenmore 18 in. 14432 / 14439 Built-in...
Whirlpool 24 in. GU1500XT - Multiple Color Built-in Dishwasher Logo
376 people viewed this question
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
Michael Thomas
Michael Thomas
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
