Question about Motorola Mobility RAZR V3
I dropped my phone in the toliet.
Yuck! I know. Anyways, Only water was present, I removed it very quickly, dried it off, and then used a Lysol wipe on it. The screens don't work, and it keeps turning itself off. It has been drying out for 2 days.
  • Hdunn Feb 01, 2008
    Thanks for the answers. Where do you recomend I get replacement parts? Is this a DIY project, or should I hand it over to a pro?
    Problem Solver:
  • 3 Answers
Try taking the phone apart and laying each piece out to dry for a day. Water really isn't good for you phone and wrecked my last one.
Posted on Jan 30, 2008
    Scholar:
  • 93 Answers
Seems like your lcd and or flex cable might be gone. Also, u may have a short on the board, u probably tried to turn it on and it was still wet. Water damage can cleaned, and the parts are all replaceable. Check my profile as we may be able to help you.
Posted on Jan 23, 2008
What do you do if your Tracfone gets wet
If it's only on the outside, I'd just wipe it clean.
If it's worse I'd immediately remove the battery, wipe everything down with a towel, and let it dry completely. I'm in a dry location so letting it sit overnight would do it; if you're in a humid environment you might want to put it in a bowl of uncooked rice to absorb the water.
Only after it's completely dry would I put the battery back in and see if it works. If it does, great. If not, then it's time to consider getting a new phone. It's all a matter of how much water got into it and for how long.
The above is for fresh water. If the phone got immersed in salt water, I'd remove the battery, wipe the phone dry, quickly rinse it in fresh water, wipe it dry again, and let it dry completely.
Jan 14, 2013 | Cell Phones
Tip
Printhead won't Print color ink black yellow purple blue red cyan magenta
The Kodak printhead is known to dry out. You can call kodak customer service and complain your printhead is failling explain you have run the printhead cleaning many times waisting your ink. They should ship you a new printhead.
or if you dont want to wait on the phone....
I have found lysol hand wipes to work wonders on the kodak printhead. I have an ESP 5 and I have wiped the printhead with a lysol hand wipes many times and it works like new. Here is a link to the product.
http://lysol.com/products/disinfecting-wipes/dwipes-4-in-1/
To wipe the printhead follow these instuctions.
remove the printhead from the printer. put the tanks back into the printhead. Be very carefull not to drop the printhead and do not put the printhead on a table with the nozzle plate down (where the ink comes out). take the hand wipe fold it a couple times. Gently wipe the printhead nozzel plate in the direction of the lines on the nozzle plate do not do a circular motion or wipe against the grain. you may not even have to use a wiping motion. you can just place the wipe on the nozzles and let the printhead soak. this will clear up dried up ink and unclog the nozzles.
put the printhead back into the printer run one printhead clean once to purge the ink and try to print.
I hope this helps.
SDtester.
on Oct 15, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
I dropped my sprint instinct in tha toliet taday should i jus let it dry
just remove the battery for a while and let it dry, if you have a blower much better but use it at the back of the unit, not in the front where your LCD is located, keep a distance of atleast 6 inches and not hot, just enough that you can with stand the temperature, move it up and down, spread the air arond the unit, never focus on one part only., wipe your battery then let it cool down also the unit, then try to open it again.
Nov 01, 2009 | Samsung Instinct Cell Phone
Screen problems
hi im josh a mobile phne technician i cebu phils. Friend the problem is your phone is wet til right now im sure. Friend don't use alcohol to clean it will not cure instead it will intensify the problem. As my expertice in phone you need to use a thinner lacquer thinner for appliances and for paint. lacquer thinner is a substance that will dry easily and can enter in any slots of the part to push out the  water that can cause rust. and friend thinner will not leave any mark to make rust so it is the safest one. you try to disassemble your phone remove all plastic parts and  rubber parts coz the thinner may damage it. only the metal parts of the phone you sink it in the thinner for at leat 40 mins. then after mins. remove and let it dry under the sun or under the electric fan. for a long time about an hour or more.,then after you assemble the parts.then it will be back the same as new. don't use the battery it cann't be repaired.  good luck that solution is 90% sure and safe. please vote me so that i will know if i helped you.
Feb 23, 2009 | Motorola Mobility SLVR L7 Cellular Phone
I drped my phone in toliet
Open as much of it (battery cover, flip open), as you can and remove the battery. Mop dry with tissue/cotton bud for the cracks and then leave on a sunny windowsill for a few days without trying anything else. Then reassemble, recharge and give it a go.
Dec 21, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Prints people purple
The Kodak printhead is known to dry out. You can call kodak customer service and complain your printhead is failling explain you have run the printhead cleaning many times waisting your ink. They should ship you a new printhead and free inktanks.
I have found lysol hand wipes to work wonders on the kodak printhead. I have an ESP 5 and I have wiped the printhead with a lysol hand wipe many times and it works like new. Here is a link to the product.
I hope this helps.
I used my printer to do a photo guest book at my sisters wedding it turned out great (i wipped the printhead before i started all the pictures look perfect!)
SDtester.
Oct 12, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
My printer wont print black inc and when i want to print color it only prints pink no matter what color i want to print. it is a Kodak easyshare 5100. I just went and bought new inc of the printer to. Any...
I hope this helps.
SDtester.
Kodak easy share5100 will not print,copy from computer properly
Calibration needs to be run if you have not. if you have...
I hope this helps.
SDtester.
Oct 07, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak Easyshare 5100 All-In-One Printer
I hope this helps.
SDtester.
Sep 28, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Motorola Mobility RAZR V3 Logo
50 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
