Question about Whirlpool 24 in. DU930PWP Built-in Dishwasher
Whirlpool diwasher adg 9142
The power is on but it's showing an error message f4 and has a little water taht won't empty. the righthand start program buuton is also flashing.
Any help greatley apprecited.
  • 15,935 Answers
Check the inlet strainer at the bottom of the machine for blockage.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
My .Whirlpool ADG 7952 is showing F4 what is the problem please
remove front lower panel below door. paper with spec's and diagnostic procedures and codes should be there. is water on?
cause water valve can buzz if water no turned on under sink.
Jun 28, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
Why Whirlpool ADG-6558/1 IX stops sometimes the wash cycle after 15/30 min?
reset the panel by hitting normal-- heat dry NOT at the same time until all lights flash then push cancel and it should start. element is going bad
Jun 02, 2014 | Whirlpool Dishwashers
Whirlpool dishwasher adg 642 not working start light flashhin 4 times
Hello Faye,
The F4 error code is a drainage error and it means that the control board did not detect a drop in the water level in the tub so it thinks it didnt drain.
The things that could cause this are a clooged filter on the pump asm, a blockage in the drain pump or hose or even a defective control board if in fact all the water has seemed to drain out of the tub.This is how ya set the diagnostic test to clear the codes and see if it reoccurs
  • Make sure the appliance is empty of water before running Diagnostics as it does not pump out before starting to fill and therefore you could overfill the appliance.
  • Open the door and set the program to the first program. (Normally rinse).
  • Turn the power off.
  • Press and hold the start button and while holding turn the power on.
  • After a little while the start button will flash, release the button.
  • Press the start button once and close the dishwasher door.
  • The machine will now run through a diagnostic routine.
  • Diagnostic takes about 20 mins.
  • The machine will stop during diagnostics if an error is found and will display the error code. If no error is found it will complete the diagnostics and end the program.
  • To exit diagnostics at any time just press and hold the start button till the program is cancelled.
    GENE
  • Nov 05, 2011 | Whirlpool 24 in. ADG7540 Built-in...
    2LYMPAIA - F4
    Hello
    If you have F4 and the sump is full of water, there's a good chance the drain pump is being jammed by a broken bit of glass or pottery. However, if the appliance is empty of water and F4 error code is flashing, where do you go from there?
    The electronic control (module pcb) does a self check of the components, during a drain cycle the programme allows a time parameter for the appliance to empty away the water. How does the pcb know the water has gone? Simply by testing a pressure switch for continuity.
    The pressure switch is an on or off switch, when the appliance is empty the internal contacts are "made" (on) when the appliance is full of water the switch is "broken" (off).
    The sensing grid of the pressure switch is exposed to the dishwasher wash water and can over a period of time get clogged with crud ( a mixture of food waste and detergent and limescale), eventually this crud stops the switch from being in the correct attitude during the self tests. The electronics notes the on or off and determines that the appiiance has not drained and gives error code F4.
    If you have F4 error code it could be the pressure switch needs cleaning or replacing.
    On the self test about 4 mins is allowed for the appliance to empty the water away.
    Aug 03, 2011 | Whirlpool Dishwashers
    I have an error code f4 on my whirlpool adp 8966 dishwasher can you tell me what it means please
    F4 indicates draining failure.Your washer drain pump starts and after 4 minutes the OWI(optical water indicator) detects that mashine is 'not empty'
    Posible mailfunction reasons:
    The drain pump must be defective/blocked
    The siphon would have got closed
    The control board would have got damaged
    OWI defective
    Apr 04, 2010 | Whirlpool 24 in. ADP6940 Dishwasher
    Whirlpool Dishwasher machine (Mod. ADG 8970/1) wont start. Water is taken in. After several attempts to start an error code "F4" appeared.
    Hello Sir,
    This error code, " F4 " comes only when the waste outlet is totally clogged with waste and blocked. Try to dismantle the machine and locate the Waste outlet pipe and thoroughly clean it. This will reset the error which is caused.
    Thank you Sir,
    Have a nice day.
    Jan 13, 2010 | Whirlpool WFW8300SW
    F4 error message. Cleaned out screen at water inlet and still get error message.
    There may be excess water in the water reservoir. Empty the washer Turn it off at the mains, and unplug it, then put some old towels on the floor, tip the washer forward until the excess water comes out, Reconnect and try again. Hope this helps it works for me and saves ££££'s in repair fees
    Oct 04, 2009 | Asko W6461W 24" Front Load Washer w/ Delay...
    Program shows shows f4 and peeps
    F4 indicates
    DRAINING FAILURE
    drain pump starts and after 4 minutes the OWI detects that mashine is 'not empty'
    posible mailfunction reasons:
    drain pump defective/blocked
    siphon closed
    control board defective
    OWI defective
    OWI - optical water indicator
    remember to unplug it from power if any repair is done
    Best regards and good luck
    Oct 04, 2009 | Whirlpool 24 in. ADP6940 Dishwasher
    F7 error
    Raise your water supply temerature. Next open door and within 3 seconds hit hi-temp scrub, then energy saver. Do this again. Close door and latch, then push reset button.
    May 22, 2007 | Whirlpool 24 in. ADG7952 Built-in...
    Whirlpool 24 in. DU930PWP Built-in Dishwasher Logo
    236 people viewed this question
    Top Whirlpool Dishwashers Experts
    Oloyede Monsuru
    Mike
    Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
