Question about Sony KP-48V80 48" Rear Projection Television
Tv needs to warm up?
When I turn the tv on it has a black screen, then after it warms up it is fine. When I change the channel after it warms up and is acting fine the problem starts all over again and I have to wait again to let it warm up on a different channel. Anyone know what is wrong?
  • Sony Master
  • 8,617 Answers
I would suggest re-soldering your tuner connections and see if that helps. solder cracks tend to "fix" themselves after they warm up. Try the solder first but also look for evidence of a capacitor that may be swelled or leaking near the tuner.That is a possibility also.Hope this helps, let me know if you ned any further assistance.
Posted on Jan 23, 2008
I have a 46 inch Toshiba plasma tv. It is having a problem where the picture does not come up as soon as I turn on the TV. After about 20 minutes of warming up, the picture appears as normal but during the...
This tv is not repairable only can be replaced the Plasma screen itself.Not woth it,replacing the plasma screen,will cost the same as a new tv.This problems,u discribing is the Plasma screen itself sure comming to used and ages.Not any electronic boards componnent.Because the floorscents Plasma gas u seeing on the screen itself forming and lighting up the Plasma screen itself.
Dec 31, 2010 | Toshiba 42HPX95 42 in. Plasma Television
I get a large black rectangle covering 1/3 of my
Is closed caption turned on? (and the channel doesn't have any captions) Turn it off.
Mar 27, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
LG 32LCD LCD TV Problem
It turn out to be a $10 diode on the mainboard, which cost me $100 to have troubleshot and repaired
Jan 19, 2009 | LG 32LC2D Television
Sony KV-35S66
power supply kit hozout plus flyback 1fuse 1restor
Nov 10, 2008 | Sony KV-35S66 35" TV
Prima HDTV has a black screen on TV, but works fine while Playing DVD
try turning the channel up or down with the tv remote to input 1 or 2 depending on which one is being used for the dvd player. tv should use input 1. dvd should be on input 2.
when turning the channel set it to show the dvd screen, then go up 1. if it doesn't show, return and go down 1.
Oct 22, 2008 | Prima C2012 TV
Tried turning on my Sony and no picture no sound, just a black screen
Sony is known for having problems with the picture tube. Sometimes it will blink on and off. also bad connections on the main board. A CRT restorer will sometimes help with picture tube problems but this must be done by a tech that has one.
Apr 11, 2008 | Televison & Video
Big Screen TV won't turn off
Check the voltage to the relay, usually 12v dc. Also check the relay or replace as it may be stuck after the tv warms up. The micro chip for functions could be locking up. Try spraying a little freeze spray directly on chip after tv is locked up see if this unlocks, if it does you have a bad micro chip.
Jul 20, 2007 | Philips 55P8241 55" Rear Projection...
Tuning in takes ages whilst warms up
IF your TV is not one of the real old ones, you have a problem with the automatic tuning system. Some component in this circuit most likely a capacitor or coil is changing its electrical properties due to temperature which in turn causes the set to be off frequency until it warms up. A capacitor (condenser) can do this quite often. Stargazer
Jan 10, 2007 | Bush 2871NTX 28" TV
Sony KP-48V80 48" Rear Projection Television Logo
167 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
