Question about Clarion DXZ648RMP CD Player
CD stuck in tray for DXZ648RMP player
The cd is stuck in the player. Pressing eject just gives a clicking/grinding noise. Checking the manual just tells me to goto my dealer. Can you suggest anything i can do? is there a manual release option?
Many thanks
  • morimur Jan 23, 2008
    thanks, I will try the tips and rate you as soon as!
    Problem Solver:
  • 14 Answers
Figure out what fuse controls the CD player and pull the fuse out for a minute (or more), then replace it (theory being that the fuse acts as a reset button). If you cannot find the fuse, you can disconnect the negative battery cable, but you'll lose your radio and other settings. This trick seems to have the greatest chance of success overall.
Turn your ignition on to the accessory position. Hold the eject button down for 2 or 3 minutes. Depending on your make/model, the eject button may flash. When the button stops flashing (or when a few minutes has passed), release the button and immediately press it again (theory being that the two minutes of "work" followed by a quick break will fool the player into releasing the disc when you press the eject button again).
Try using some tweezers, needle nose pliers or hemostats (every tool kit needs a hemostat or two!) to pull the CD out while pressing the eject button with power going to the player (theory being that the disc is so slick the player can't eject it without help). Some people report success just by pulling the disc out with the tweezers without power to the player and without pressing the eject button.
If your player has a small hole in the front of it, like most personal computer CD players do, straighten a paperclip and push the clip straight into the hole to manually release the catch. Some players have a groove under the CD door instead of a hole. Look for a hole about the size of the paperclip and don't mistake an emergency release hole for an earphone jack.
Posted on Jan 23, 2008
Cd wrongly inserted in an AIWA CA-DW935M is stuck in the cd player, wants to get it ejected
I was able to find the manual for that model, which included a series of tests for the CD trays. Perhaps if you ran through them you will be able to get your CD out. If not, please ask for additional help.
AIWA CA DW935M Service Manual free download schematics eeprom repair...
Feb 09, 2014 | Audio Players & Recorders
Cdrom drive can not eject / Cdrom is stuck
How To Eject CD from CD-ROM drive if it is Stuck :
If you have a CD into CD-ROM drive and it is stuck and you are trying to eject tray of CDROM by pressing the eject button or windows eject command but CD won't eject as there is no command to eject a stuck compact disc from the CDROM drive then this article is for you.
Step 1: Switch off the computer.
5573fa0.jpgStep 2. On the front of the CD-ROM drive you may find a small hole called Emergency Eject hole below the tray of CD-ROM drive . Take a long pin around 3 inch, (also known as CD ejector) it must be hard enough, insert this pin inside the hole and push a little. The CD tray will slightly move to out.
Step 3: Now you may manually pull the tray and you are done. You have successfully ejected the stucked CD.
Step 4: Switch on the computer and you may work as usual.
on May 12, 2010 | Computers & Internet
How to get a dvd tray unstuck
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
May 19, 2013 | Televison & Video
My CD is stuck in my Toshiba Satellite A505D laptop slot, with no hole near the Eject button.
Look on the cover on the tray near the eject button. Should be a tiny hole.
Get something like a straightened out paperclip and insert it in to the hole and push firmly but carefuly. It's an emergency eject for a stuck tray.
Feb 07, 2012 | Computers & Internet
CD stuck in DVD player in tv
I'm sorry that the disc tray is not ejecting. Please check whether you're able to locate a small hole under the tray opening area. If one available, please insert a pin and it will eject manually now..
Dec 18, 2011 | Televison & Video
My cd doors wont open what can do.
Try disconnecting power. Connect back and then turn the DVD on by using the button in the player (not the remote) while at the same time you keep pressing repeatedly the eject button on the player. You will need to keep pressing eject until the unit start loading the disk.
If that does not work, then the DVD must be disassembled undoing the screws holding the top cover in the chassis.Once disassembled there is usually a disk stuck inside the drive or a mechanical issue. The disk tray motor rarely fails.
Do not disassemble the player unless you have repair experience. Before proceeding check warranty status.Call Kenwood if you want to book a repair
Feb 03, 2011 | Kenwood CD-223M 200-Disc CD Changer
Where is eject button cd is stuck making a grinding noise
On every CD/DVD/BluRay player there should be a VERY small pin-hole on the front of the actual tray(you may have to wipe any dust off the front in order to see the hole). If you stick a saftey pin in there you will release the lock on the tray and it will pop open. Now if the CD is really really jammed and the pinhole trick doesn't work you will have to take the drive apart to get the CD out.
I hope this helps! If not, please comment back and let us know!
Jan 05, 2011 | Dell Computers & Internet
Well we have a acer computer and the cd drive is stuck
If pressing the eject button does not eject the tray, look for the small pin hole on the cd drive and insert a paper clip to press that hole. It would manually eject your CD tray. Hope this helps.
Nov 03, 2009 | Acer Aspire 5500 5570-2609 Laptop
Sony 5 disk changer disk is stuck not able to open the tray
After some time it was showing some C 31 00 error. I searched on internet, opened the top cover, there is the CD changer and my cd was stuck in there, I pushed the CD from finger and there it goes... on press of eject it came out... thanks anyway...
Apr 02, 2009 | Sony CDP-CE375 5-Disc CD Changer
Clarion DXZ648RMP CD Player Logo
312 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
