Question about Bosch Nexxt WTMC 6300 Electric Dryer
No power my wife was drying clothes she saw a flash and the dryer stopped working i checked the breaker i am getting power to the plug and to the back of the dryer the schematic isnt very helpful mainly in german is there a fuse i took the dryer apart but cant find one
  • 770 Answers
Post your email here and i will send you the service manual on this model i need to know if you are in Canada or USA there is two diffrent models under the 6300
Posted on Jan 24, 2008
Dryer won't dry clothes
First check and see if your heating element is working by holding down the dryer door switch and turning on the dryer too see if you get a glowing from the rear inside of the drum. If it does glow then check to see if you have a kink in your dryer line or check to see if you have a clogged vent outside the vent to the dryer. Also you may want to try resetting your power to the dryer by unplugging the dryer and turning off and then backb on the breaker to the dryer then plug the dryer back in and see if that works.
Nov 09, 2012 | Dryers
I have a kenmore dryer 80 series it only makes a lite sound when I push the start button. I won't come on. The power is good.
The Kenmore 80 Series of dryers are consumer grade dryers for home use. As with most home appliances, the Kenmore 80 series dryers will occasionally not work as intended. If a problem occurs with your dryer, however, you do not necessarily need it serviced by a technician. You can attempt to troubleshoot and fix any problems with your dryer before contacting a technician.
  1. Kenmore 80 Series dryers may not run for several reasons. First, make sure that the power cord is plugged into a working power outlet. You may need to plug a different device into the outlet to check that it is receiving power. If the second device does not run on the power outlet, you may have blown a fuse or tripped a circuit breaker. Check your fuse box or circuit breaker box and make the change as needed.
    Next, make sure that the dryer door is fully shut. The dryer will not run with the door ajar.
    Finally, check that the "Start" button was fully pressed and that a cycle was chosen on the machine. If you do not choose a cycle for the dryer, it will not run.
  2. If your Kenmore 80 Series dryer does not heat up during use, check that a heat cycle has been chosen for the load. There are several different dryer cycles you can choose, some of which do not use heat. Make sure that you have chosen a heated cycle.
    As above, check that you have not blown a fuse or tripped a circuit breaker. The dryer may use more than one fuse or breaker: one is used to power the drum, and the other for the heating element. Make sure that both fuses or breakers are in working order.
  3. There may be times when Kenmore Series 80 dryers do not fully dry your clothes. When this occurs, check the lint screen and clear out any lint. The air may not flow as well if the lint screen is clogged.
    Next, check to see if the exhaust vent is clogged. Lint and other particles may clog the exhaust vent over time, restricting air flow and making it more difficult to dry your clothes. To check the vent, run the dryer and hold your hand under the vent. If you do not feel any air flow, clean or replace the vent.
    If you used cold water to rinse the clothes it may take longer than normal to dry. The same is true if the load of laundry is very wet or is filled with items that are very absorbent.
    Finally, check the load size. The more clothes in the load the longer it will take to dry. If you want to reduce drying time, separate the clothes into piles of light and heavy items and dry them separately.
  4. please comment on these solution by saying how helpful.
Dec 22, 2010 | Kenmore Dryers
Acts like it has no power.
Check 230v at wall and back of dryer.
Check Breaker
Check Thermal switch (2 wires) at top of the element in back.(unplug the two wires from thermal unit and plug them together and try the dryer for a test
football shaped white,small fuse at bottom left in back of dryer
Do the same for a test.
If this was helpful please rate me.
Leo Ponder
Aug 02, 2010 | Whirlpool LEB6300 Electric Dryer
While I was out of town my wife was drying clothes and she said the dryer stopped, and when she opened it the clothes were still damp. She tried to re-start the dryer and it would not start. She called a...
you must check if there is power to the element when you have it switch on , , if you have no power to the element , then trace the wiring from the element to a hi limit thermostat , it a small round disc shape item about the size of a 10 cent coin with two connections , remove the wires and check continity accross the two terminals, if it is ok , then check the on and off switch or timer dial , you might see burn marks around the connections , since it trip the circuit breaker
Jul 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer won't turn on...
Try pushing the breaker pair off, then on and re-check the dryer. If still nothing, pull the power plug and check the two slanted slots for ~220 volts AC. If you don't have access to a voltmeter, or a friend with one, call an electrician to check. If you read the voltage stated, then the problem is within the dryer. Check the back of the machine for a reset button.
Sep 14, 2009 | Dryers
Dryer won't start
Could be a blown fuse.Check out repair manuals and more pix HERE The fuse looks this:
Sep 01, 2009 | Dryers
Electric dryer not drying clothes
The electric dryer requires 220 volts to dry clothes but only 110 volts to turn the drum .reset your circuit breaker even if it looks ok ,if that dosent work, unplug from the wall and check where the plug wire goes into the back of the dryer and look for loose or broken wires.
Apr 26, 2009 | Estate TEDX640JQ Electric Dryer
Dryer doesn't dry clothes thoroughly
Turn off your breakers, then back on to insure a good reset. Then check the wiring from the receptacle, to the plug and then to the back of the dryer. You are getting some heat which tells me that one leg of power is out. I don't think it is your element, because you get some heat. Let me know how you do.
Feb 09, 2009 | Dryers
Magic chef dryer
hi there,
she may have tripped the house breaker. unplug the machine and check the breaker on the house electrical box. plug the dryer back in and see if that will work.
Sep 30, 2008 | Dryers
Bosch Nexxt WTMC 6300 Electric Dryer Logo
134 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
