Question about Fujitronic FH-776T Portable Air Conditioner
Fujitronic FH-776T Is the Fujitronic FH-776T actually an air conditioner in the traditional sense condenser , compressor and freon or is it an air exchange cooler ? Thanks
  • 104 Answers
Yes, it has.
Posted on Jan 24, 2008
How do i add refrigerant to a amcor kf900e portable air conditioner"
The compressor picks up the gas that is bringing the heat removed from the house to be compressed to liquid and cooled in the condenser coil When running the compressor is very hot. When the freon is low the compressor will be cooler because it doesn't have as much heat to compress. To add freon you must add a service valve to the low pressure line.
Aug 02, 2014 | Amcor KF 9000 BTU Silver Portable Air...
I have central air and I was wondering how do you put freon in it because its not blowing out cool air
Is the compressor starting? On the outdoor unit you will see a large copper pipe and a small copper pipe. Is the larger of the two cold to the touch? wet? Just because a central air system is not blowing cool air does not mean it needs freon. If you have clogged filters it cannot do an air exchange. So, I would recommend checking the easiest things first before adding Freon.Most people make the mistake of adding Freon and overcharge their system. In a low load situation you can slug the compressor with liquid and your system is ruined. If you do have to add Freon it indicates that you have a leak. An AC System is a closed system and if it is working properly you should not have to add Freon.
Aug 03, 2011 | Whirlwind FH-778 Air Conditioner
I have a Fujitronic FH-700B Portable A/C unit that is squealing when I press the Cooler button. I can't find any help or support online as the item is no longer sold - is there a manual or...
SOUNDS LIKE THE MOTOR NEEDS OIL...LOOK FOR ZOOM OIL THIS LITTLE GUY IS A LIFE SAVER.. IT COULD ALSO BE FAN HITTING SHROUD, AND WILL CURE ITSSELF OVER TIME, BUT A OLD UNIT I THINK NEEDS THE FAN OILED..HOPE I WAS OF HELP. HIT THAT YES BUTTON IF'N I WAS .. JAY MOTOR GUY
Jul 21, 2011 | Fujitronic Heating & Cooling
No Cooling
The water pump or the float valve is not working.
Aug 02, 2009 | Fujitronic FH-797 Portable Air Conditioner
FA 1300 NOT COOLING WELL. IT SEEMS TO KICK ON BUT THEN TURNS OFF AND IS NOT BLOWING COLD AIR
Hi there. If unit just starts to get cold then the compressor shuts off and if the compressor comes back on after 3 to 5 minutes, the system has a freon leak or the compressor is over heating.
If you are technically inclined, search for leaks using soapy water at all tubing connections.
For overheating compressor: Clean the condenser with compressed air or vacuum cleaner. If still overheating, start switch or start capacitor may be bad.
Thanks
Paul
Jul 12, 2009 | Fujitronic FA-1350 Air Conditioner
Fujitronic 1300 ~ compressor does not stay on and not overly cold
sounds like the units compressor is shutting off. this could be caused by being low on freon, or a dirty condensor coil. the condensor coil is where the hor air exits the unit. make sure it is clean, free of lint/dirt. if it is clean, you will need to take it in to a repair shop and have the coolant leak found/repaired and then recharge the unit.
Jun 04, 2009 | Fujitronic FA-1300 Air Conditioner
How to clean inside of this cooler
"You cant be sure whats in the "pickel Barrell" till you take the lid off" !
Aug 28, 2008 | Fujitronic FH-776T Portable Air...
Our Fujitronic FA-900 Portable AC is not running cold like it used to.
Try A.B. May they are out of Kansas City but they will travel up to 90 miles I have heard.
Jun 02, 2008 | Whirlwind FH-778 Air Conditioner
No cooling
May have burnt wire or bad capacitor to compressor.When running incool can you here the compressor running or is it maybe just the fan outside running?
Jan 08, 2008 | Fujitronic FH-797 Portable Air Conditioner
Fujitronic FH-776 air cooler
I have looked all around sir, Cant seem to find one.
Aug 03, 2007 | Fujitronic FH-776 2.11 Gallon Humidifier
Fujitronic FH-776T Portable Air Conditioner Logo
187 people viewed this question
Top Fujitronic Heating & Cooling Experts
Marvin
Marvin
Bill Long
Jay Finke
Jay Finke
Are you a Fujitronic Heating and Cooling Expert? Answer questions, earn points and help others
