Question about Sony PlayStation 2 Slimline Console
Ps 2 no spin
My ps2 spins eratically and says disc cannot be read. is it the laser or spin motor?
  • tjsert Jan 23, 2008
    i tried blowing in air and still not working
    Sergeant:
  • 226 Answers
Http://www.g4tv.com/xplay/features/45797/PlayStation_2_Disc_Read_Error_Fix.html
yes when you open your ps you can remove the lense by using small screw driver.
if you remove it you can blow very well by using air compresser
Posted on Jan 23, 2008
PS2 Modchip and Laser Fix installation Failure ...
I bough ps2 with cracked after 3-4 days not working dvds are not read.
sometime it's working some dvds..
so plz solve my problem...
May 28, 2012 | Sony PlayStation 2 Slimline Console
Ps2 powers up, but disc is not spinning and
Following could be the reasons for not spinning any PS2 disc:
  • A dirty laser. Try cleaning the laser and see if it helps. If you can see crust or dust covering the laser eye, it may not be strong enough to read anything at all. If the laser looks clean, this is probably not the issue.
WATCH this video to clean lens
  • An unplugged laser cable. These things normally do not come out by themselves, but if you opened the ps2 that was spinning OK to clean the laser and/or removed the laser to clean it, plugged it in, now it's spinning 1/2 of a turn, the laser cable may not be in securely. If it is in securely, make sure it is plugged into the motherboard end properly.
  • A dead laser. On models 30001, 35001, and some 30001R, this is the most likely issue. These models are old and the original lasers were a bit unreliable.
No Spin At All If your spindle hub is NOT SPINNING AT ALL, NOT EVEN 1/2 OF A TURN, it may be bad or unplugged. A tell tale sign of it being unplugged is if you hit eject, the laser moves down the rail, and starts grinding because the PS2 keeps trying to move it down the rail even though it hit the end. There's a small switch on the spindle hub that tells the unit to stop pushing the laser because it's reached the end. Spindle hubs usually do not go bad by themselves, usually either the PS2 too a bad fall and it became bent [try spinning it by hand], or someone the cable out and put it in too many times [or incorrectly] and the silver contacts on the cable were detached.
Nov 18, 2009 | Sony PlayStation 2 (PS2) Console
The disk isn't spinning. When tray closes, it tries to spin for a moment, but then it doesn'tt.
When you first put a CD/DVD into the Playstation 2, the disc spins enough so that the laser can read if it's a CD, DVD movie, DVD ps2 game or CD ps1 or 2 game to spin at the appropriate speed. If there is no disc inside, or the laser thinks there is no disc inside, the disc will only spin that 1/2 of a turn. So what would cause the laser to think there is no disc inside?
A dead laser. On models 30001, 35001, and some 30001R, this is the most likely issue. These models are old and the original lasers were a bit unreliable. I would suggest using a 400C since it is a better laser [and more available] than the 400B. YES, despite anything you have read, you CAN replace a 400B with a 400C IN ALL CASES.
Jun 05, 2009 | Sony PlayStation 2 (PS2) Console
PS2 slim- Disc not spinning
definately the laser has died.
Give us a shout if you need any help.
FixMyConsole
May 13, 2009 | Sony PlayStation 2 (PS2) Console
Ps 2 disc wont turn
I had this same issue with my PS2, honestly I think it was something to do with the laser eye reader that reads the disc, when it is dirty the disc won't even spin or attempt to read it.
you can either take an air compressor and when the ps2 is off, have the disc tray open and blow the dust out of it.
Or, i personally would take the ps2 apart and clean the diode itself with some rubbing alcohol. Just don't void your warranty or somehow break it.
This article will help you with disassembly: http://arstechnica.com/gaming/guides/2003/11/ps2-repair-guide.ars Hope this helps!
Mar 18, 2009 | Sony PlayStation 2 (PS2) Console
Ps2 slim spindle dont spin
If your spindle has stopped spinning, it will most likely be 1 of 2 problems. Either your spindle motor has burnt up, or even though it is very unlike, a lead wire that supplies the power to the spindle has became disconnected. Now, if the case it the burnt up spindle motor, there are hundreds of motors for every kind of PS on, of course, E-Bay. If the problem is for some reason, a soldered wire has broken from the motor. It is very simple to re-attach the lead with a quick touch from a soldering iron. I hope this has helped.
Jan 02, 2009 | Sony PlayStation 2 Slimline Console
PS2 not reading disks
Your lazer lense has bit the dust. Depending on your model type the first gen systems lazers are very easy to replace. The later versions sony made it harder to replace. You can find out what model you have by looking at the back of your PS2 then you can either call sony or go to there website and find out what generation PS2 you have. Then go from there. Hope this helps
May 08, 2008 | Sony PlayStation 2 (PS2) Console
PS2 Disc does not spin
just because you see read doesn't mean the laser is good.
the laser has to read the toc (table of contents) for it to read the toc it must be at the beginning, it must be at the right depth from lens to cd and the spindle must spin. now if you have to spin the spindle that means it most like is not reaching the beginning of the cd or the spindle motor is bad.
Jan 02, 2008 | Sony PlayStation 2 Slimline Console
Sony playstation 2 console problem
clean the lense with some alochol.
http://arstechnica.com/articles/paedia/hardware/ps2.ars
Dec 05, 2007 | Sony PlayStation 2 (PS2) Console
Disk wont spin
First of all the new laser lens will not allow your Slim to read NTSC UC games if you have a PAL european Console.
There is no reason the New laser should have not read the disc unless it Came to you damaged. It sounds like you know how to replace a laser.
Sep 13, 2007 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 Slimline Console Logo
83 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
