Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Projection tube relpacement gel
Dear Expert,
I need to find a source for the gelatenous liquid within the 'packs' on top of my projection tubes. If you have advice for the replacement that would also be appreciated.
Thank you,
Alvin
[email protected]
  • Anonymous Jan 23, 2008
    I'm not sure what you guys get out of this except EXPERT status but you should get a feather in your cap too! The local company wants $505.00 to do this work and it will take a week at their shop! I've worked to the component level all my life since the 'tube' days, through DTL, TTL, etc. This seems like an easy fix to me and I appreciate your information so much! I will recommend your service to everyone I know and I will use it if I'm stumped again! Why do you answer questions without us spending our 'fee' for your service? I'd love to help people fix things to the component level if my services would be valuable. Most things are no longer fixable due to surface soldering and LSI! Thans again and take care. Alvin
  • Anonymous Dec 15, 2008
    i was told it will cost 350 to fix this is there away to get it done cheaper
    Problem Solver:
  • 7 Answers
Also, if anyone else has this prob. www.tvrepairkits.com has it. photo instructions too. just fyi...
Posted on Apr 10, 2009
  • Philips Master
  • 8,617 Answers
Here is a link where you can order the CRT coolant for your Projection tubes,
http://www.matelectronics.com/cgi-bin/ss000001.pl?SS=coolant&PR=-1&TB=A&SHOP=&ACTION.x=23&ACTION.y=14
heres how you change the coolant,
It's best advised to change the fluid with the tube out of the set. Some guys in the shop like to do it on-board but personally I can do it just as fast by pulling the tube. Removing the tube is no big deal, after removing the front screens and back cover you'll have to pull the crt socket board off. This is probably the hardest part since Philips puts a glob of RTV between the socket and the tube, as you're pulling down, gently wiggle the board, it will pop off. You'll have to pull the HV anode lead out of the HV block on the LSB board in the back. Unplug the convergence plug for the particular tube you're changing as well as the Yoke plug. There are normally 2 ground wires connected to the backside of the CRT metal shielding. Those have to come out. After removing the 4 1/4" screws holding the crt down, slowly remove the CRT. BE very careful that you don't bang or bump the certering rings when you remove the tube. Those are a pair of rings around the neck of the crt with tabs on them. They're usually RTV'd down but they can be moved. If you move them you'll have to recenter the tube.
You'll find the plug on the top of the coolant chamber, twisting 180 degrees loosens it so you can remove it. Careful, there's a small white washer you must keep and it tends to fall and can get lost. Drain your coolant into a container like a kitty litter container. After the fluid is drained, removed the 4 screws holding the lens on and clean the inside of both the lens and CRT coolant chamber with a rag. Reinstall the lens. Sit the tube upright, begin slowly filling the chamber back up with the replacement fluid until it reaches the very top. Reinstall the cap with rubber gasket washer and tighten 180 degrees. Clean any coolant on the outside of the tube off, you don't want any of this stuff dripping down into the set.
Reinstall tube the same way you removed it. As long as you didn't move those centering rings, any convergence adj. should be very minor. Proceed to do the same to the rest of the tubes.
Normally the blue tube dirties the worst and fastest. The glycol based coolant is extremely sticky and corrosive as well as conductive. If you do the coolant change in the set and you spill any coolant on the PC boards, STOP WHAT YOU'RE DOING AND CLEAN UP THE SPILL IMMEDIATELY! AS I said, this stuff is conductive and will short circuit the boards it's spilled on quickly.
If you're not comfortable doing this call a pro.
Posted on Jan 23, 2008
  • Sonny Berry
    Sonny Berry Jan 23, 2008
    I personally like helping out because all I really know is electronic repair, and its not right for people to spend thousands of dollars on a projection unit only to be charged all kinds of cash for something that only cost a few dollars. Glad I could help ya.
6ya staff
SOURCE:
Mitsubishi rear projection tv is too dark to see picture
This is a very common problem within your projection TV set there is a small red, green, and blue picture tube. On top of the tube there is a lens that focuses the video on the screen. Between the lens and the top of the tube there is a hollow chamber filled with a clear liquid. This fluid is specifically designed to keep the tube from overheating. After about 4-5 years the fluid will start to become cloudy and will will get worse over time. Tvrepairkits.com is a good place to get a repair kit to fix this condition yourself.
Dec 19, 2011 | Mitsubishi WD-62525 62" Rear Projection...
SAMSUNG PCJ522R, 2000 MODEL. COOLING PACKS HAVE LEAKED AND ALL POSSIBLY NEED TO BE REFILLED, WHERE DO YOU REFILL THEM? SIMPLY BY REMOVING THE CAP AND ADDING NEW COOLING GEL, AND HOW MUCH DO YOU ADD? OR...
The crt coolant tanks should be full all the way to the plug. Its a special CRT coolant which has to be installed. The circuit boards will also need to be cleaned and possibly require the components that were in contact with the coolant resoldered.
Jul 10, 2011 | Samsung PCJ522R 52" Rear Projection...
Looking for blue picture tube 7"liquid cooled tube
You need to change the coolant Fuild in Blue Tube Mats has it 1-800-628-1118
Jul 01, 2010 | Philips 50PP9202 50" Rear Projection...
The picture on ours is extremely dim. dunno if it is because of its age, but it is considerably more dim than other projection tvs i've seen. is there a fix?
These tvs have 3 picture tube that have a coolant (liquid gel) filled into these tubes. Over the time this liquid goes bad specially in philips tv and becomes clouded that make the picture dim and a little foggy with colors. This requires specialized professional help. WE www.fixurtvs.com do these repairs in sacramento & yolo county CA areas. The repair can cost $ 150 to $ 220. If colors are real bad with 3d kind of look, the convergence may be bad too. both combined should cost less than $ 350. Check out mor answers and estimates at www.fixurtvs.com.
Feb 25, 2010 | Philips 60PP9202 60" Rear Projection...
Pic suddenly went dark, very dark. Images seen are oversaturated. hitachi ultrascan hd is about 8 years old. Help!
I have the same problem. I took the back cover off of the TV and blew all of the dust out and the TV started working again. But this only lasted 2 days. Now the TV is dark again.
Jan 19, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Phillips 51pw936317f picture not as sharp as when new
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc.
You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jan 17, 2009 | Philips 51PW9363 51" Rear Projection...
Picture tube gel leak
The best way to clean it is to remove the board completely and wipe up as much as possible, then use qtips with rubbing alcohol to remove the left over residule the alcohol will dry quickly, but still allow the board to air day a full 24 hrs before reinstalling it in the TV.
Aug 16, 2008 | Televison & Video
Sony KP-57 hw40 red picture tube... manufactured 2002
yes you would need a service manual and have to do all the alignments but it would need to be an exact match on the picture tubes as some sets have different components within the same mode year depends on serial number so be sure the replacement tube has the exact tube numbers that your tube has. it still is a very involved proceedure and the picture tube can and will hold a very serious charge and it can give you a severe shock if not handeled properly and discharged properly.
May 19, 2008 | Televison & Video
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
881 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
