Question about GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ...
Ge profile arctica
Model #psc23sgna bs fridge is getting too cold freezing vege's water and ice is fine we did have a power outage last week and that's when the problem seems too have started any help would be appreciated thanks david
  • pcs111 Dec 18, 2008
    I have a GE Profile Artica Refrigerator and our area had a brief power outage. And on the next day I noticed the freezer was running at 20 degrees F, when it should of been running at 0 F. What to do?
  • 833 Answers
It is unlikely that a power outage by itself will cause your problem. Recheck hour refrigerator thermostat. It should regulate to 38-42 degrees F. You can take an outdoor thermometer and put it into the fridge compartment, leave it for an hour or two and check. Adjust as necessary. If that doesn't fix it, we can proceed further.
Posted on Jan 24, 2008
6ya staff
SOURCE:
My ge profile arctica is about 9 years old. It is freezing food in the refrigerator, temp control is set at a 4 and the thermometer inside reads anywhere from 28 -40 in various areas of the fridge. Milk...
first run the diagnostics on the unit from the tech sheet inside the unit,then if thermistors are bad replace these there are 2 one on the left and one on the right wall in both fridge and freezer,if good per diagnostics then replace the electronic damper door located between the fridge and freezer compartments in the upper left hand corner of the fridge behind the plastic grille as these doors break and jamb open or shut and the temps can no longer be regulated during the diagnostics tests you can hear this door operate if its operating correctly,lastly,if these fail to solve your problem,replace the main control board in the back behind a panel
Aug 22, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezing food in frig. , not making ice .
Freezing food in the fridge also freezes the water line for the ice maker.
You have a thermostat problem. Get a new thermostat fitted.
Mar 31, 2011 | GE Profile¿ Arctica® Energy...
I have a GE Profile Arctica (2005 model) side by side. Model # PSS26MGPABB. The freezer is not getting cold enough (to freeze bread for eg), and the ice maker has stopped making ice (the water is not...
This could be a fan motor problem. Check to see if the fans are running and if not take a look at this page http://www.appliance-repair-it.com/refrigerator-fan-motor.html
If the compressor is not running this page will help http://appliance-repair-it.com/GErefrigeratorrepair.html
There could be a defrost problem, look on the back wall of the freezer to see if it is covered with heavy frost. If so your problem is that it is not defrosting. This page will help http://appliance-repair-it.com/GE-refrigerator-repair.html
Sep 20, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Water is not coming out of the water dispenser. The filter is fine and the ice machine is working. There are no leaks; but I can't get any water from the fridge.
the water for ice is not the same as for the foutain . it has a dual valve and one side of valve could be bad . other could be water line is frozen . if vegees freeze then the water line could . set the fresh food side a little warmer and in 24 hr it may be ok . **** .
Jan 06, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile Arctica PSS25SGNA BS Icemaker is not working seems to be filling with water but no ice.
The water dispenser and ice maker side run separate sides of the water control valve. Fill ice maker with tap water and let it freeze. If it dumps the ice then does not refill then the water control valve is the problem. I will be back soon with a photo and some links, Thanks, Sea Breeze
Nov 18, 2009 | GE Profile Arctica Stainless Steel Top...
GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Use the damper control to direct less air into the refrig compartment from freezer
Apr 23, 2017 | GE Profile PFS22 33" Artica French Door...
GE Profile Arctica - Frig Freezing Food
Replace the damper assy, in the Refrigerator section. The damper door is stuck open. Very common problem on these refrigerators.
Nov 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PSC23MGNA too cold on frig side & icing up on freezer side
Check your thermostat if it is still functioning well.
May 02, 2017 | Refrigerators
Wow, so you dropped some money into it, eh? I would take a look at the damper door asslb(DIFFUSER). located at the very top left of your refrigerator section in back. It has a motorized door that opens and close's and it may be stuck open. More than likely it is broken and needs to be replaced. GOODLUCK!!!!
FYI: All your cold air in your refrigerator comes from your freezer!
Dec 17, 2007 | GE Profile PFS22 33" Artica French Door...
GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ... Logo
522 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Ron Beer
Ron Beer
Level 1 Expert
vince
