Question about Kenmore 44102 Front Load Washer
Kenmore 417.29042992 front loader washer
Washer will not spin in the spin cycle. I noticed the door latch light stays on when the door is open. Please help.
Peter
  • 2 more comments
  • Anonymous May 11, 2010
    The repair parts list manual call it a "door lock/switch USCC". Is this the same as your "wax motor switch?
    Ok, now it spins fast but how do I change the "wax motor switch"?
    Is there a reason the door lock light is on as if it was properly engaged?
    can I use the washer as usual until i can get and replace the part?
    I assume I just leave the test connector in place until then...
    thanks for your help [email protected]
  • Anonymous Mar 29, 2014
    How do I open door on a Kenmore coin operated front loader comercial heavy duty washer which has fail to complete its cycle?
  • Anonymous Mar 31, 2014
    Can't open the door
    New Friend:
I have a kenmore 417.29042992 front loader. water goes in & out,
but won't agitate or spin. (replaced door switch already) Have a timer to go in. Any toughs ??
Posted on May 05, 2010
If front loader washer quit spinning, check the wax motor switch. You can make a temporary fix by providing a short on the door lock contact. The Kenmore 417.29042992 front load washer provides a test connector that's readily accessible behind the front lower panel. Insert a wire between connector pins 1 and 2 (red and white/red color wires) and your washer should spin during the spin cycle. Hopes this helps.
Posted on Jan 28, 2008
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 24, 2008
6ya staff
SOURCE:
Frigidare gltf1670as
You likely have a broken or slipped drive belt or broken spring on the belt take up arm on the drum. Appliance Parts.com has a lot of DIY instructions on how to get at the belt and make repairs.
Jan 23, 2018 | Washing Machines
My Whirlpool Duet washer was out of balance and almost fell over during the spin cycle. The washer was shaking and the front door came open during the spin cycle. Now the front door will not latch and stay...
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a front loader HE washer. The lights are
Try unplugging the washer and see if the latch disengages. I'm also wondering if the cycle was interupted (power loss) and a restart is necessary.
Aug 02, 2009 | Washing Machines
HE front loader washer door opened during cycle and will not shut
the latch broke within( the hook inwhich actually hold doorshut) , youll need a new latch assy.
Mar 14, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Front load washer door won't open
There is an override switch directly below the latch under the machine on most front loaders.
Jan 24, 2009 | Kenmore Elite 45986 Front Load Washer
Unlock the control panel to a kenmore elite front loader
to unlock the controls
select and hold drain/spin for 3 seconds until the control locked status lights turn off.
Nov 22, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Front load washer wont spin
yes. the solinoid or wax motor (depending on which switch you have) has fail and is not telling control that the door is locked. replacing the switch will fix it
Nov 20, 2007 | Kenmore 44102 Front Load Washer
Kenmore 44102 Front Load Washer Logo
1,008 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
