Installing developer How do I install the developer pack? Ricoh only provides instructions for changing the toner but not for the developer. Thank You, Joe G.
  • brian c
    brian c May 11, 2010
    You will need a specialized vacuum to do this! Don't use a standard household vacuum!
    You need to get the developing unit out, and there should be a cover / lid on the unit.
    You will see the developer powder on a magnetic sleeve roller.
    You will need to get the cover off, and dump / empty the old developer powder into a suitable bag / container, and carefully vacuum the sleeve roller while rotating the roller with the gears on the back of the unit. Do NOT rotate it in the wrong direction! You will be able to tell if you are turning it in the wrong direction, as you will feel a drag on the unit, and the developer powder will start to "bunch up" on the magnetic roller.
    You will want to get as much of the old developer powder out as possible.
    Refill the unit, and rotate the assembly by hand in the correct direction until the magnetic roller has coverage.
    If you DO decide to tackle this on your own, be advised that there may be TDS (toner density sensors) in the unit that can be damaged from the static created by the vacuum.
    There will also most likely be a reset / adjustment process once you have replaced the powder.
    If you have never done this, I strongly advise you to obtain a service manual!
    Good luck.
  • 589 Answers
If you give me more details regarding the exact model, I may be able to link you to a service manual.
Posted on Jan 23, 2008
  • lc1955 Oct 17, 2010
    I ee your note above was posted 3 years ago but I am hoping you can still help. It is a Ricoh FT4022/4522. I have been unable to locate a service manual.
How do i fix problem Add Toner
The Ricoh has toner and developer. When the developer is depleted it can not get to the right density when toner is added so the machine keeps saying to add toner. You need to clean out the developer unit and put in new developer. Depending upon your model you may need to install a drum and blade too. Ricoh technicians are trained to dissemble the unit and just replace the parts needed instead of getting a whole drum/developer unit. If you live in Southeast Florida Advanced business computers is a great source for help. Computer network repair, printer and copier maintenance repairs, leasing and supplies.
Oct 28, 2015 | Ricoh Office Equipment & Supplies
How to solve add toner see instruction front cover to replace toner ricoh mp2000
If you just add toner and it just keep saying add toner. open sp mode.
Press: Clear modes>1-0-7>Clear/Stop> SP2 x x x- Drum > 214 -Developer Initialization>Exectute and wait.
please rate. thanks
Dec 09, 2014 | Ricoh Aficio mp2000 Copier Machine
Ricoh aficio c420dn wont print black
Hi, my experience with this machine is that the gear that drives the black pcu breaks or cracks. Usually caused by the pcu being too hard to turn. I always turn the developer gear in the pcu before installing it just to loosen the toner.
Mar 15, 2017 | Ricoh Aficio Office Equipment & Supplies
Empty Developer on MP1900
Should replace the TYPE 28 DEVELOPER every 60,000 pages.... this is needed to mix with the toner. if you cleaned the toner/ developer mix out of the developer already then it will definatly give you blank pages ..... hopefully this helps.
Mar 13, 2014 | Ricoh Office Equipment & Supplies
Print copy white
If the copies is whitw possible causes:
toner empty,not toner
developer drive transmission mechanism failure
image transfer current terminal poor intact
Feb 09, 2013 | Ricoh Aficio 2035 Copier
Ricoh afficio 1045 & ricoh 450 toner is mixed in ricoh fw 780 now background and negative image is coming what can i do plz give some idea
firstly you need to remove the developer and vacume the developer unit and magnetic developer roller.
Put in new developer and correct toner in toner unit.
Call service...
After replacement there is a sequence wich needs to be done, for developer initialization.
Aug 16, 2011 | Ricoh FW 780 Black and White Copier
Changed toner on ricoh 240w printer but still saying toner empty, replace toner
cycle the copier 1 to 5 times.. obviously it was either under toned and needs to cycle or you didnt remove the packing material from the toner befor you installed it ...check that too...
Mar 31, 2010 | Ricoh Aficio 3025P Black and White Copier
Where do you put the developer
The developer is mixed with the toner in the toner cartridge.
Mar 14, 2009 | Ricoh Office Equipment & Supplies
RIcoh MP-4500
It's probably happening because the cleaning blade on the drum needs to be changed or replaced.
Oct 25, 2008 | Office Equipment & Supplies
Ricoh 1018d won't add toner after installing toner bottle.
the part numbers are different for each toner from ricoh, Lanier, Savin and Gestetner. From what I recall is the bottles are different, check the old bottle vs new. Also if the machine had run very low you may have to open and close the fron cover several times, this intiates a toner feed program.
www.p4photel.com
http://www.websitetoolbox.com/tool/mb/copierquestions
Feb 26, 2008 | Ricoh Aficio 1018D All-In-One Laser...
142 people viewed this question
k24674
jasbo
jasbo
