open the panned which is located on the base of the laptop and just buy a ram use the model number listed in the catalog or you also check from toshiba website using the model number of your laptop.
there will be two slots in the laptop one which will have a RAM on it and the you will see the other slot which is empty so you just need to insert the RAM like the way previous ram is attached on it. and thats it you can turn on your lappy and u r good to go
Several memory vendors will help you find the answer. I like http://www.crucial.com/store/drammemory.aspx It walks you thru finding how much and what kind of memory you have and what you can install.
I haven't been able to find out much information on this specific laptop, but an easy way I usually use to determine the type of memory I need is to run a scan at crucial.com. You do have to use Internet Explorer, but it always gets the job done. You can also remove the RAM from the computer and it should have a sticker with the type of RAM it is. Here is the direct link to the scan on crucial.com.
http://www.crucial.com/systemscanner/
There's not much that one can "upgrade" on a laptop.
You could install more RAM.
You could install a larger & faster disk-drive.
If you're running Windows XP, you could upgrade to Windows 7.
That's the only components that can be upgraded.
Here's a 12-step memory upgrade procedure from the tigerdirect.com website:
Upgrading Your Memory to Improve Performance Compiled By Our Editors http://static.tigerdirect.com/html/installingmemory.html 12 Quick, Easy Steps to Installing Desktop Memory Increasing your computer’s memory is one of the most powerful ways to improve performance.. The following 12-step guide illustrates how you can install your desktop memory upgrade in 10 minutes or less with the use of a demagnetized screwdriver. But before you begin, make sure you are working in a PC-e environment. If you handle your circuitry improperly you can inflict permanent damage. Your PC’s biggest enemy is static electricity. Static electricity can damage your module and other computer parts. You need to ground yourself to avoid "shocking" your computer. Grounding yourself removes any static electrical charge your body might be carrying. To ground yourself, you can wear antistatic wrist straps or you can do the following: With your computer turned off, touch an unpainted metal part of your computer case with your hand. Plant your feet and do not walk around (because walking can produce static electrical build-up. Now you’re ready to proceed with our 12-step program for installing memory:
1. Make sure your PC has been turned off PC! You’d be surprised how many people forget this common sense first step.
2. Remove all the power cords from your computer system.
3. Remove all the screws that secure your computer case and put them in a place where you can easily find them..
4. Remove the computer case. Usually you can simply lift the case off once you have removed all the screws. However, if you have difficulty removing the case, consult your computer’s user manual.
5. Locate the memory slots on your motherboard. In some PCs you will find then beneath a power supply or drive. If so, you may need to remove some additional parts in order to gain access.
6. If you need the replace an existing memory module, undo the module clamps and gently lift the memory module out of the slot.
7. Take your memory module out of its anti-static bag and hold it gently by the edges. Line up the notch on the bottom of your new memory module with the empty memory slot and press the new module down with your thumbs until the pins rest snugly inside the slot. You may have to exert some pressure! When will hear a click when the memory module is installed correctly.
8. Secure the new memory module by attaching the module clamps. 9. Put the computer case back on.
10. Replace the case screws to secure the case.
11. Attach your power cord.
12. Now that your new memory has been installed, turn on your computer! Once your memory has been physically installed, the computer must install it electronically. Once your PC is turned on, you may have to go into computer BIOS to enable your system to detect the new RAM you have just installed. Refer to your computer us
If this solution is helpful please click a thumbs-up rating below.
The NEC Versa m500e has 2 memory slots. Each slot can hold DDR PC2700 with a maximum of 512MB per slot.
I'm not sure where the memory is located on the Versa, but normally in the middle on the bottom of the laptop there is a memory slot. on some units the memory is located under the keyboard, so you have to remove
this first to change the memory.
You need a Type 2 PCMCIA card for this laptop. I was able to find a wired one here. Be sure that your OS will work with the card you choose. Also I have no experience with that website, so buyer beware. Another good place to find older computer parts is eBay, happy hunting.
