Question about Creative Labs Nomad Jukebox Zen Xtra MP3 Player
Boot problem device only boots up to eax screen and stops
  • Anonymous Jan 15, 2009
    I have run into a similar problem on my Zen Xtra. When it is turned on the device freezes on EAX and won't do anything (not even turn off). Any additional guidance would be appreciated.
  • 4,402 Answers
"Hard-disk Problem"... I'd just like to confirm once more that smacking the player on its rhs while turning it on works.I had to smack it fairly hard though so don't be afraid!! I didn't try smacking it till I checked out the threads above so thanks everyone I'm a happy man again!! :)
Posted on Jan 23, 2008
Clicks when switched on, stops after a while, screen says reboot and select proper boot device or insert boot media in selected boot device and press a key
Your machine can't find the boot sector of the hard drive. This could be because there is a cd/dvd in the drive or the BIOS has the wrong boot sequence assigned.
Nov 04, 2013 | Toshiba satellite c660
How do you run CHKDSK /F with the blue screen stop error on my desktop?
You MUST have a boot device like CD, DVD, or USB. Use the install disc to access command prompt, by choosing the repair option. You could also download and burn a boot CD like Hirens.
The other option is to remove the drive and attach it as a slave or USB to another computer.
Oct 15, 2012 | Dell Computers & Internet
E-machine gets the blue screen that says.....stop 0x0000007E(0xC0000005, 0x8053A593) what does this mean
A registry error or device driver is causing this. Attempt a boot to safemode by tapping f8 after the computer boot logo screen and before the windows logo screen.
if you can't boot to safemode then try the same key sequence but select "last known good configuration". If this does not work, then you will have to repair reinstall the operating system.
if you can get in safemode or last known config, make sure to run a spyware/virus check if you didnt' install any programs, devices or used a registry cleaner like CCleaner
Feb 14, 2010 | E-Machines eMachines Desktop PC
Hello: I have a computer running Windows XP Media Edition SP2. Several weeks ago, I started experiencing boot up problems with my computer. It stops booting in normal mode. It will boot in safe mode. When...
It looks like you installed the wrong drivers for your motherboard.  It can cause a Blue Screen Of Death.  Also how many hard-drives do you have in that computer?  IDE?  Are the jumpers set to CS?  I find that CS causes problems.  If you have 2 devices on a ribbon cable make one master w non ATA   and the second device as slave.  Also the boot.ini could be confused.  Is the boot.ini on the wrong hard-drive   Did you accidentally put 2 operating systems on the same computer?  lots of things could have caused this.
Nov 09, 2009 | Microsoft Windows XP Professional
My sidekick 3 just stays at a white screen with the 4 bottons
Sidkekick 3 stops booting with the 4 Danger icons on a white screen
1) Remove the battery from your device
2) Flip open the screen
3) with the battery removed, press and hold the W key on the keyboard. Press and hold it and don't let go until I say so. :)
4) Put the battery in (you're still holding "W" right? Good). This is a little tricky to do but you can do it.
5) Keep holding W! :)
6) The device will boot to a screen that has a picture of a SK with Xs for eyes and stars spinning around it's head, like it's been clonked on the head. When you see this, you can let go of the "W" key.
7) After a few more seconds you'll see a screen that says "Sorry! Please restart your device by selecting the Reboot button. If this screen appears again, contact Customer Care."
8) Click the Reboot button on the screen, and hope for the best.
This *might* fix your problem. If it doesn't, there's no point in repeating the steps, just call customer care and have them replace your device. However, a lot of times I've seen an SK3 stuck on that screen, those steps above will fix it.
It's not a workaround, it's a fix. If that fixes it you won't have to worry about your device having a problem, because it won't have a problem anymore.
The only thing this "fix" will help with is if your device stops booting with the 4 Danger icons on a white screen. That's it. It won't do any other magical fix for any other problem. It's really *not* worth the time and hassle to try to use this trick to fix anything else, because if your device boots at *all* past those 4 icons, then this fix, she will do nothing. :)
Oct 03, 2009 | T-Mobile Sidekick® 3 Cellular Phone
IBM T20,inaccessible boot device
The Innaccessable Boot Device message means one of 2 things:
1: your hard drive has died - not much here, must replace drive.
2: The master boot record has become corrupt. Without any media, this will be hard to fix. You will need to boot to the Windows CD and either run the recovery console or perform a windows repair to fix this issue.
Jun 23, 2009 | IBM ThinkPad T20 2647 Notebook
'GENRAL PROTECTION FAULT'error seen when pc boot with xp
This is what the error says ?
Trap 0000000D =========== General Protection Fault ============
tr=0028 cr0=00000011 cr2=00000000 cr3=00000000
gdt limit=03FF base=00017000 idt limit=07FF base=000017400
cs:eip=0008:2FFF3066 ss:esp=0010:00060E7B errcode=0000
flags=00010013 Cy NoZr IntDis Down TrapDis
eax=00000F44 ebx=00000004 ecx=00000005 edx=00000000 ds=0010 es=0010
edi=00070000 esi=000000A1 ebp=00000000 cr0=00000011 fs=0030 gs=0000
The boot loader files are either corrupted or missing.
To repair this problem,try boot with the Windows XP CD-ROM
and choose the option to install. On the next screen, choose
repair to repair your Windows installation. When the repair
process is finished, you will be able to boot back into your
operating system without losing data or having to reinstall
Jan 01, 2009 | IBM P4 3.2/512/40/CD/XPP DT M-Class...
Inaccessible boot device
Your boot setup has been corrupted. so I think you should reinstall the Operating system and choose the repair option..
Please get back to me and let me know whts up...
Jan 13, 2008 | Toshiba Satellite Pro 4600 Notebook
Creative Labs Nomad Jukebox Zen Xtra MP3 Player Logo
48 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
