Question about Toshiba 43H70 43" Rear Projection Television
3D image Picture also sags in on top,bottom and sides like ( )
  • 2,336 Answers
This type of behaviour is related to the convergency section. In order to fix it you will need to replace 2 identical ICs that are mounted on an aluminum heatsink and check for any other defective components such as fuses or fuse resistors that are associated with the convergency circuitry.
Good Luck.
Posted on Jan 23, 2008
    President:
  • 4,402 Answers
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
My new lg 3d tv is closng on top bottom and sides is there anything i can do to cure the problem
Could you provide more information? What do you mean when you say, "closing?" Do you mean there is a black band around the picture? If so that means the original picture is recorded at a lower pixel density than your TV will display.
In the past most TV program signals provided a picture dimensions (in computer standards) very roughly 600 pixels wide by 400 pixels tall. What this means is that a picture of that pixel size will display as a small, squarish image slightly wider than it is tall on a (now) standard 1080p LCD television--which produces an image 1920 pixels wide by 1080 pixels high.
That would be nearly unwatchable (picture too small) except for the fact that most TVs compensate for the relatively small size of "standard definition TV (SD TV, as opposed to HDTV) by enlarging the image so that the top and bottom edges of the picture touch the top and bottom of the TV screen. This will leave black bands on either side of the picture. Some LCD TVs will automatically stretch BOTH dimensions of the image, which yields a distorted, "sqaushed" image.
All my comments above apply to both standard LCD and 3D-LCD TVs, by the way.
A more precise overview of the facts about TV picture size can be found here:
http://en.wikipedia.org/wiki/Display_resolution
Nov 23, 2013 | LG 42LW5300 42 Class 3D LED HDTV
My 47 inch vizio 3dtv has issues with the 3d. There are two images and neither are in 3d. The glasses don't work.
You have to put the TV into 3D mode to view it by pressing the 3D button on the remote. Before you press that button, look at the screen... if you see two images side by side, then you would choose SBS... if the images are one on top of the other, then it is the over/under mode, or with Vizio,Top/Bottom option which is the "TB" icon. Once you have chosen this, the screen will inform you to put on your 3D Glasses.
Aug 15, 2012 | Televison & Video
The picture is showing a double image and is distored.
The problem you are refering to is more than likely a convergence problem. The convergence circuit in your tv is controlled by an IC (integrated circuit) stk392-110 and it makes the 3 colors (red, blue, green) line up/converge together to create a clear picture. You'll know when this part needs to be replaced because the picture you see is 3d looking and possibly bowed on the top or bottom or on the sides in any or all 3 colors.
Jan 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
RCA R52WH74 Picture is sagging, looks 3d, and double picture
Go to menu then setup look for convergence if you do not see convergence then you have A open FUSE It will be on right side of FBT flyback transfomer there is 3 of them in a roll they are small brown rectrangler looking caps but ARE FUSES it will be the one in the middle. Replace it and you have a FIXYA.
Feb 19, 2009 | RCA R52WH73 Projection Television
3D image
you have to replace all 3 ic's and 2 are stk 392-110 and the 3rd one is stk 392-150 they are located on the extreme right of your tv on a long heat sink all 3 are located there.You can get replacements as well as free tech online support at
http://servicemanuals.vstore.ca/
Apr 10, 2008 | Hitachi 51UWX20B 51" Rear Projection...
Sone TV Picture not aligned.
This looks like Pincushion problem. nothing you can do. Only a Trained technecian can do this adjustment to reproduce a perfectly aligned image. It requires a pattern Generator and other tools. call the company tech.
May 10, 2007 | Sony KV-36FS100 36" TV
Toshiba 43H70 43" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
