Question about RCA RT2500 System
Low Frequency Effect
My LFE light is flashing. I'am not getting any sound. It's just flashing left speaker right speaker.
  • 2 more comments
  • cman132546 Jan 24, 2008
    Yes it work in the past. I've tried every thing from un hooking the speaker wires and re- hooking them back up. And I still get the same response.
    i'll try that. But if that don't work what shoul i do
  • cman132546 Jan 25, 2008
    Where is the amplfier located?
    yes i tryed another set of speakers
    President:
  • 1,950 Answers
Has your speakers worked in the past? Did this error come up after you played with the settings of connections?
Posted on Jan 24, 2008
  • 790 Answers
Hi
in this case the audio is good but the output speaker is not working because you have blown fuse at the amplifier section thats why cant hear the sounds... check the amplifier section then check the fuse speaker protector.. replace a new fuses with the same rate....
Thanks....
6ya staff
SOURCE:
Sorround speakers not working though connected correctly
Without knowing exactly what your problem is, perhaps you are not playing sound that was recorded in at least 5.1 format. A DVD or BluRay will indicate the format on the cover. The data is decoded and split into (for example) six discreet audio channels. Left front, Centre front, Right front, Surround Left, Surround Right and LFE (Low frequency effects) If you are playing a standard stereo audio disc, then the sound will only be heard from the front L&R speakers, which are expected to be full range speakers. You can, however choose an audio configuration that also provides a signal for the SUB (LFE) and even a pseudo surround. If you want more info I'm happy to help. Just tell me exactly what sound source you are playing and we can work it out.
Cheers for now, Don.
Feb 19, 2015 | Denon AVR-1804 Receiver
Htddw7600, brand new, sub amp is not working, only way to get any bass sound is to unplug the sub cable from back of main amp and touch it on side of sub out port.
H?,
You have a very good system...one of the best of SONY..SUB does not get activated automatically especially on STEREO mode.DIRECT STEREO Notes • No sound will be output from the subwoofer.
.your system has Dedicated Power Amplifier for 2 Externally Driven Sub-Woofers (200W RMS x 2)..in order to activate the sub woofer amplifier you need to make a selection on the surround modes while you are switching the modes of the surround you will see the speaker position on the display of receiver as well..if you do not see the sub woofer it wont be activated..Sound Field Program (A.F.D) is a good example to test it..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Additionally please follow the instruction on your user manual to activate the SUB ,as is follows..
BASS-OUT
Low-frequency (bass) signals can be directed to the
subwoofer and/or the front left and right speakers
according to the characteristics of your system. This
setting also determines the routing of the LFE (low-
frequency effect) signals found in Dolby Digital or DTS
sources.
Choices: SWFR (subwoofer), FRONT, BOTH
• Select SWFR if you connect a subwoofer. LFE and
low-frequency signals from other channels are directed
to the subwoofer according to the speaker settings.
• Select FRONT if you do not use a subwoofer. LFE and
to the front speakers according to the speaker settings
(even if you have previously set the front speakers to
SML).
• Select BOTH if you connect a subwoofer and you want
to output low-frequency signals from front channels to
both the front speakers and subwoofer. LFE and low-
frequency signals from other channels are also directed
to the subwoofer according to the speaker settings. Use
this function to reinforce low-frequency signals using
the subwoofer when playing back sources such as CDs.
Jun 23, 2011 | Audio Players & Recorders
I have a sony HTDDW7600, i cannot get the dedicated subwoofer amp to work. The fan is running on it, but for some reason the only way i can get it to do anything is to unplug the cable that goes from the...
H?,
Hope this helps!
BASS-OUT
sources.
SML).
Jun 23, 2011 | Sony MUTEKI HTDDW1600 Theater System
Conncet a sony sub to a denon reciver
Depending on the model, there are two ways to connect a subwoofer to an amplifier, receiver or processor. The best way is to connect the subwoofer to the SUB OUT or LFE output of a receiver, but some subwoofers can be connected to the speaker level outputs of the receiver or amplifier.
1. How to Connect a Subwoofer to the Subwoofer Output
The preferred method of connecting a subwoofer is through the LFE or Subwoofer output (SUB OUT) of a receiver. Almost all home theater receivers (or processors) and some stereo receivers have a subwoofer output. The LFE (Low Frequency Effects) is a special output for subwoofers and is often labeled 'SUBWOOFER' not LFE. 5.1 channel programs on DVD discs have a dedicated .1 channel output with bass-only content that is best reproduced by a subwoofer. Connect the output of the LFE or Subwoofer jack to the Line In jacks of the subwoofer using a single RCA cable (the two jacks on the left in the photo). A 'Y-Cable' may be necessary to connect the LFE output to both the left and right channels of the subwoofer.
2. How to Connect a Subwoofer to Speaker Level Outputs
Some receivers and amplifiers do not have an LFE or Subwoofer output. In this case you can use the speaker outputs of the receiver to connect the subwoofer. Using speaker wire, connect the left and right channel speaker outputs of the receiver to the left and right channel speaker level inputs on the subwoofer (the speaker inputs on the right side of the photo). Using speaker wire, connect the left and right channel speaker outputs on the back of the subwoofer to the left and right channel front speakers.
Hope it helped..
Apr 20, 2011 | Denon Audio Players & Recorders
Marantz sr6001 amplifier flashing on standby continuously
hi there
check settings for this configuration ......if you have a subwoofer in the settings, for best overall results choose subwoofer yes, and set main/center/surrround to small....if no subwoofer set left/right speakers to large and small to center, if there is no loe frequency effect (lfe) going to the subwoofer it will go into standby....hope this hlps ....shia
May 28, 2009 | Marantz SR6001
Have an existing ts-1100 home theatre infinity speakers
You cannot use this system with one that does not have a Subwoofer or LFE (Low Frequency Effect) output. Unfortunately, this sub doesn't have a line-level (speaker wire) input. Sorry.
Nov 20, 2008 | Infinity TSS-1100 System
I have no amp for jamo 1060 sub
Dual Voice-Coil
The unique Dual Voice-Coil design allows both left and right channel sound from just one speaker. Simply hook up both the left and the right channels to the special terminals on the speaker. Hook up one channel only, if the speaker is to be used in a conventional stereo set-up.
I found this on jamo site hope that will help you
Mar 15, 2008 | Jamo 1060 SW Speaker
Cables
you coudl use a single rca to a left and right rca cable. However most woofers will have a lfe single rca input on the woofer that you connect to a single rca on the receiver.
Are you sure you are not confusing the +/- on the woofer that is used to connect your speakers? ie. my woofer has the +/- so i can connect to my front speakers and my receiver to filter the low frequency sounds via the woofer.
hope this helps
smeags.
Feb 19, 2008 | Sony STR-DE575 Receiver
Subwoofer connection
if this is ao powered sub, that plugs into the wall, there should be no problems, if it is powered solely by the reciever it may work fine but be sure you dont exceed amperage on the subwoofer.
Jan 28, 2008 | Bose 151SE Main / Stereo Speaker
Laow Frequency Effect
UH oh , time for a shop visit. The "finals" are shot...accordianman
Jan 24, 2008 | RCA RT2500 System
RCA RT2500 System Logo
121 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
