Question about Hotpoint WMA76 Front Load Washer
Hotpoint WMA76 Leaking door and soap tray
Just put a load into the washing machine tonight and with only 4 minutes to go it started leaking water from the door and the soap tray. After the cycle had finished, there was still water inside and the door look light came on and won't go off. I have managed to lower the water level in the machine by gently lifting the door and seal. After turning the machine off for a few minutes the lock light has gone out and I can get the washing out...but what happened and why did it leak from both the door and the tray???
Any ideas what could be the matter and how I go about fixing it would be great as I can't afford to buy a new one just yet.
Regards
Lee
Lee
  • Beduff Billy Jan 23, 2008
    Fixed the problem.
    I figured out that the water wasn't draining away, so I thought the filter/strainer might be blocked up. Had to take a small plastic pannel off the back of the washing machine and unscrewed the black plastic gator. Inside there's a plastic cup with a ball and a pair of the wife's pants!!!!
    Cleaned everything down, fitted everything back together and had a test run. No Problems.
    Hope this helps someone else.
    thanks for your help.
You may be using too much detergent, or you have a blockage in the outlet.try putting it on to spin to drain out the water, if it does not drain then check the filter or sump hose for a blockage
Posted on Jan 23, 2008
6ya staff
SOURCE:
Hotpoint WMF720 Aquarius+
Hotpoint WMF720 Aquarius washing machine is leaking This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Dec 28, 2012 | Hotpoint Washing Machines
Hotpoint WMA40 washing machine is leaking from detergent drawer- any suggestions ? Thanks
Hotpoint WMA40 washing machine is leaking This video will show you how to find that leak on any front loading washing machine
Nov 27, 2009 | Hotpoint WMA40 Front Load Washer
Hotpoint wma76 stops and displays ON
Could be rinse water valve ..Faulty Solonoid coil
Nov 10, 2009 | Hotpoint WMA76 Front Load Washer
Water leaking through detergent tray of my Hotpoint WF860
It sounds like the washer is not draining properly.
Remove lower rear cover of washer, locate and remove the large black hose fastened to bottom of tub.
remove plastic filter inside hose, and clean same.
Refit filter and hose, making sure it is on properly.
Be careful when you remove the hose, as there will be water in there.
As an extra precaution, remove soap draw,and thoroughly clean all parts, particularly,the conditioner parts
Please rate my fixya solution.
Thanks.
Feb 01, 2009 | Hotpoint Ultima WF860 Front Load Washer
Water is leaking out of the washing powder drawer
the spray holes in the soap manifold are partially blocked and spraying at an angle. try to reduce the water flow pressure at the feed tap and clean the water holes in the soap tray manifold (above the tray).
Feb 16, 2008 | Whirlpool AWM8143 Front Load Washer
Intermitant water leak.
Put a newspaper under the machine, it will help you to find out from where does the water leaks. Good luck!
Sep 06, 2007 | Hotpoint Ultima WF865 Front Load Washer
Front soap tray leaking
Possible the tray is clogged; you can pull it out to clean it.
Nov 02, 2006 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint WMA76 Front Load Washer Logo
209 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
