Cars & Trucks Logo
Posted on Dec 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where do I start looking to see why my rear defroster is not working on my 2002 Chev Cavalier
Tinette Booth
Level 2:
Sergeant:
  • Expert 176 Answers
  • Posted on Dec 20, 2009
Tinette Booth
Expert
Level 2:
Sergeant:
Answers
176
Questions
Helped
56575
Points
513
First check fuse and relays. If none are bad, check wire connections on back window. Then take a good look at the lines in the window, are any cracked or missing sections? If so, they make a repair kit for this issue. Hope this helps.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 14, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
367
Points
There is a conection between the front wiring harnes and rear under the carpet drivers side somewhere. This is a known problem and happened to my car. you'll need to ID the defrost wire larger guage, and jump the harnes connection, use **** crimp connector
1helpful
I have a 1998 chev.cavalier. my question is why my back defroster is not working .wthat is the posible solution?
Most likely cause is the back grid on the glass has a crack in it. There is a fuse and a switch. You will need an ohmmeter to check them all.
2002 Chev,. Cav Back window defroster stopped working
If the fuse is good and the light for the rear defroster works, ie; lights up, then check by the drivers side kick panel/ carpet area. There is a connection where I believe a Purple or Purple/White wire connects to the heavier gauge black wire in a plug. They tend to melt and loose connection. You will have to hard wire them or use **** connectors. Basically they use two different gauge wires at this connection and that seems to cause the problem.
My chevy 2002 cavalier battery died so i replace it but now the radio is lock and non of the odometer is working
If you have the owners manual the code may be printed somewhere. Look under radio for guidance. Otherwise talk to a Chev dealer to learn how to get the code.
2answers
2002 Cavalier - The rear defrost just quit. The light is still on but nothing. Where would I check the fuses or would it be wiring if the light is still on?
I'd guess that if you look closely, and it would have to very closely, you'll see that there might be a break in the "wires" on the window.
1helpful
Back window defrost
there is a break in the defrost lines. should have continuity from one end to the other, but if lines are broken (cracked window, accidentally scraped, etc.) it won't work.
Pcm
dealer only ,factory immobiliser
2002 Chevy Cavalier won't start
have your battery checked at an autoparts store. most do it for free. check your fuses for your defoster.
2helpful
Chev Cavalier 2003 only one rear turn/brake/hazard light
I have a 2002 Chev Cavalier that had the same exact problem. I replaced the bulb harness (purchased from a chevy dealership for around $5) which was fairly easy to do. I have had zero problems with it since.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
