Question about Toshiba TDP-S8 Multimedia Projector
Two or more black bands appear
When I switch on the Toshiba TDP-S8 two or more black lines appear and as it runs they either grow in width or decrease or sometimes disappear and appear again. This also happens when there is no external input, just the blue default startup screen. It started with the entire screen blacking out but now it has reduced to two lines. The bulb and projector is very new with just about 150 hours of running.
Try resetting all parameters to factory settings. Do it once and then set your personal settings. Then, reset to factory defaults again.
Posted on Feb 06, 2008
6ya staff
SOURCE:
Cant remember password for my toshiba tdp s8
I had a projector toshiba TDP-S8 but it is used when i turned it on it required a password what can I do
thank you
Nov 09, 2009 | Toshiba TDP-S8 Multimedia Projector
Is toshiba TDP-S8 good projector because I bought it today for $ 300.00 used. Thank you
Toshiba's s8. Designed to deliver stunning images in breathtaking XXL format, the TDP-S8 features 2000:1 contrast, the latest DLP technology for brilliant color and sharpness, and 2000 ANSI lumens brightness for top performance. The product retailed for close to two thousand dollars. Due to problems production was discontinued. If it works for you then you got a good deal. Replacement parts are easily available on ebay.com for reasonable prices.
Jul 01, 2009 | Toshiba TDP-S8 Multimedia Projector
It shows no signal
Toshiba TDP-S8 projector cannot communicate from my laptop, it shows no signal. how can i fix it? thank you so much...
Feb 19, 2009 | Toshiba TDP-S8 Multimedia Projector
HOW TO RESET TOSHIBA TDP-S8 LAMP
after installing the new lamp, hold the volume top & bottom key simulteniously, when green light indicate at panel start the projector & go to service there you may found reset lamp ? press yes the lamp will reset.
Feb 01, 2009 | Toshiba TDP-S8 Multimedia Projector
TDP-S8 only run for 20 sec.
Possible filter problem or sensor related to over heat. Might also be a bad bulb or worn out bulb.
Leaning more towards bulb replacement.
Dec 08, 2008 | Toshiba TDP-S8 Multimedia Projector
Toshiba Lamp Reset - How?
Not positive, but I would assume the same as my Toshiba.
With the on, input, and menu buttons held down, insert the power cable.
Hope this helps, NGK
Aug 14, 2008 | Toshiba TDP-S8 Multimedia Projector
No Power to My Toshiba TDP-S8
Console and mainboard not communicating. avalontc.com
Jun 05, 2008 | Toshiba TDP-S8 Multimedia Projector
Toshiba projector tdp-s8
please start your computer first and then the projector- use function key with f4 or f6 or f7 or f5-and select computer from input of the projector.
Dec 29, 2007 | Toshiba TDP-S8U Multimedia Projector
Toshiba TDP S8 projector shuts down suddenly
The reason why the projector is shutting off is so the lamp doesn't explode. It's more of a safety feature on the projector, you can reset the lamp and it might work for another 500hours. If the picture is still pretty bright I can get you the reset procedure, but be warn that when the lamp does eventually blow it could shatter the glass inside, so be careful, it shouldn't hurt the unit.
Dec 09, 2007 | Toshiba TDP-S8 Multimedia Projector
Toshiba TDP-S8 Multimedia Projector Logo
174 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
