Question about Sony KV-35S26 35" TV
No Power Similar to other folks issues here...no power at all. I took back off and fuse looks to be good and test okay. Other than that nothing looks burned etc. What (and where) are key parts to check for bad solder etc? Tks.
  • 2,336 Answers
Check the power supply for defective Q601 & Q602 and as well a fuse resistor near these transistors. Also check the horizontal transistor for a shorted condition. After repalcing the mention parts, add some new solder to the flyback transformer connections and also to a coil(s) and other components in the horizontal area.
Good Luck.
Posted on Jan 23, 2008
  • 579 Answers
You need to isolate the failure.
first, measure the voltage (called B+ usually) on the biggest elec. capacitor in the power supply. This should be about 130-160 Vdc.
If this isn't here, then the problem is in the power input circuit.
If there, then the high-voltage supply is down. If the set is anywhere near 10 years old, then replace the flyback transformer and its transistor (H.O.T.) and go from there.
The worst case is that a power surge or something has killed the TV's brain chip and you'll have to do a board replacement.
Let me know.
After power outage front display blinking "16".
I had a similar issue where after a power outage, the player would not power up.
I removed it from power and took the cover off looking for a fuse. Could not find anything so I put the cover back on and plugged it in and it worked. My theory is the electronics needed time to fully discharge in the circuits. I would leave it unplugged for about 24 hours. I left mine unplugged for several days. I hope this helps.
Feb 13, 2016 | Toshiba SD-3990 DVD Player
Dishwasher repair. Problem: water in bottom of machine, not draining/ cannot select any mode other than 'Auto'/ usually does not start. What happens when I try to run it: Switch on. On switch lights
I had a similar issue. I took off the drain hose, ran hot water thru it and removed the hose going into the garbage disposal there was some built
build up on the inside, cleanness it good put through houses back together and everything was fine. Hope this
Dec 23, 2014 | Dishwashers
I have a interactive health massage chair model ems-9-s. when you turn the power switch on the back rollers run for 10 seconds or so and it stops. The power light is on in the controller but nothing will...
Hope it is still under warranty. Need new board and possibly more. My parents bought a similar chair and it failed with many issues to fix. Tech replaced all the electronics. Good luck.
Nov 27, 2013 | Interactive Health Ijoy 130 Human Touch...
I have a FLM-2632 and its completely dead, opened it up, checked all capacitors, none seemed bad, just died one day, no warning no nothing. No light, good fuse... I took the power supply board out, it has...
You, re right, the problem is most likely in a power supply. I have a similar set myself, had the same issue.
You can't get a separate supply for the set, only whole system module, what plugs in into the main unit. Too bad, it cost around $450 new, so look at discount used parts on line and find a used working power supply.
Good luck,
Alex's TV Service,
Philadelpiha,Pa,
215-806-5980.
Jan 22, 2010 | Polaroid FLM-2632 Television
EMachines T2824. Does nothing but light on mainboard coming on...
This is a motherboard problem. You'll need to replace it. Although, it may be cheaper just to buy a new PC (eMachines are never very expensive, or well-made for that matter)
Sep 22, 2009 | Computers & Internet
Honeywell T8011R
Check for either an in-line fuse in the heating unit or a fuse on the control board also in the heating unit.
Nov 06, 2008 | Honeywell Programmable Thermostat Heater
No power to display
this response is for folks having issue were the unit is dead no power to display. i have the same unit and it passed on this week.
i took it apart and found the ckt board and the zener diode at location d9 was burnt so was the board.
i replaced that diode with 1 from radio shack it was a zener diode 12 volt. cost 1.39 for 2 now its brewing again.
Apr 29, 2008 | DeLonghi DCM485 Coffee Maker
Televison & Video Logo
128 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
