Question about Uniden TRU8885 Digital Answering Machine
Uniden PowerMax 5.8 phone
One of my handsets has stopped functioning except for being able to dial out, and people dialing in. No caller ID, no menu, no redial, etc. Help! The other handset works fine.
  • 2 more comments
  • BigMac42 Aug 08, 2008
    read manual. Fussed with base station settings. Can't access menu on handset.  Get series of beeps instead.
  • Anonymous Sep 06, 2008
    Same problem here. I reset phone, but no good...
  • tamannaluvu Sep 21, 2008
    In my phone Line one has a dial tone and line 2 does not functioning at all. Even line 1 has a dial tone I can only make a call from that line but I am totally unable to receive any call at all.
  • Anonymous Dec 20, 2008
I removed the battery from the phone for about 15 seconds then reconnected it. I can now access the menu.
Posted on Sep 06, 2008
I have a Uniden Power Max 5.8 and once in a while the phone will ring but I can't hear the party on the other end of the line. Does any one else have this problem? If so is there any way to correct this problem?
Posted on Oct 16, 2008
How I set my voice message for the answering machine on the 5.8?
Posted on Mar 25, 2008
Uniden phone stuck at searching, not getting a dial tone
One thing to try is deregestering your phone and registering it with the base again.
Hole the # and 'End' key on the handset until the next menu appears (about 5 seconds). Select deregister phone (use the 'Menu' button). Do it again, but select "base unavailable". After that, set them in the base (not the handset charger) and they should register with the base.
This works on most Uniden model phones.
Jan 29, 2013 | Uniden DECT 6.0 Cordless Telephone...
Uniden cordless phone caller id quit working
Using the Caller ID and Redial Lists
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information.
Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
Dec 02, 2012 | Uniden Cordless Phone
Caller id not working in India
the caller id has not been activated for your number.dial the helpline numberr and get ur caller id activated.if not works,then go for call options in the phone.
Dec 04, 2009 | Uniden DECT 6.0 Cordless Telephone...
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Aug 16, 2009 | Uniden Cordless Phone
My phone is stuck on rotary dialing. My handset had all the options but the dial mode. After caller id setup it went straight to languages and then started back over with ringer volume.
1) When the phone is in the standby mode, press menu/mute.
2) Press - to move the pointer to “Dial Mode”.
3) Press select/ch and the display will show the current setting.
(The initial setting is Tone.)
4) Press + or - to change the selection.
5) Press select/ch and a confirmation tone will sound.
6) Press end to exit.
Customer Help line for UNIDEN 1-800-297-1023
May 30, 2009 | Uniden TRU 448-2 Cordless Phone
Swicth from tone to pulse
1) When the phone is in standby mode, press and hold the caller id/menu key.
2) Press the vol/ / key three times to select Dial.
3) Press the select key to toggle between Tone and Pulse.
4) Press the end key or return the handset to the base unit to complete the setting. The handset returns to standby mode.
This phone also has a feature that allows you to use Pulse dialing to make calls, but allows you to switch to tone dialing for automated systems (like “Please Press 1 for English) here are the steps for that:
Initially make your call with the pulse dialing mode. Once your call connects, press
the */tone key. Enter the desired number. These digits will be sent as tone dialing.
Once the call ends, the tone mode is canceled and pulse dialing mode resumes.
Apr 06, 2009 | Uniden Cordless Phone
Uniden PowerMax 5.8 - system busy error comes up & no dial tone
Unplug the power supply to the base of the main handset, wait 10 seconds and plug back in.
Mar 27, 2009 | Uniden TRU546 Remanufactured Dual Handset...
No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Sep 25, 2008 | Uniden 2.4 GHz Cordless Phone System
Uniden PowerMax 5.8
To make the message light go away when there are no messages - remove the handset from the base and press and hold the "find handset" key for 5 seconds. Resets it!
Aug 04, 2007 | Uniden TRU8885 Digital Answering Machine
Uniden TRU8885 Digital Answering Machine Logo
677 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
