Question about Microsoft Windows Vista Ultimate Edition
Voice on yahoo
On clicking voice button the message is acs connect failure
    Genius:
  • 1,067 Answers
Need to download latest verison then go doanl load java.com then adobe flash shock latest ok then cheak windows update custum scan
Posted on Jan 23, 2008
When i try to make a voice call , Y! messenger shown this error :Your computer is not connected to the network. help me plz
Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
2. Enable the "No network detection" option and then click the "OK" button at the bottom of the window.
3. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
4. Enter your Yahoo! ID and password and click the "Sign In" button.
you may have a registry problem download registry cleaner reginout to fix the issue
Dec 22, 2010 | Yahoo Messenger
My yahoo messenger voice call button grays out and does not appear to work. it works during morning but totally goes off in evening. normal chat works fine
Evening time maximum users log on net for browsing, other work etc. so it's sure that your net speed goes slowest. and if your speed is slowest you will not able to connect yahoo voice server. Please try upgrading your connection speed.
Thanks
Oct 11, 2010 | Yahoo Messenger
Canot open yahoo voice cnference
Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences." 2. Enable the "No network detection" option and then click the "OK" button at the bottom of the window. 3. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button. 4. Enter your Yahoo! ID and password and click the "Sign In" button.
you may have a registry problem download registry cleaner reg in out to fix the issue
Sep 20, 2010 | Yahoo Messenger
Cant sign in
2. Enable the "Firewall with no proxies" option.
3. Select the correct Internet connection type and country from the pull-down menus.
4. Click the "OK" button at the bottom of the window.
5. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
6. Enter your Yahoo! ID and password and click the "Sign In" button.
The above configuration works in most situations. (However, if you connect in this way, you won't be able to use the Voice feature.) If this configuration doesn't work, follow these steps:
1. Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
If neither of the above options work, you're probably behind a firewall or proxy server that requires you to enter its address. Follow these steps:
2. Enable the "Use proxies" option.
3. Enter your firewall or proxy server's address and port number. Contact your network administrator (if you're at work), or your Internet service provider (if you're at home) to determine the correct firewall and proxy settings.
5. Yahoo! Messenger will ask you if you want to sign in with your new proxy settings. Click the "OK" button.
download registry cleaner reg in out to solve the problem easily
Sep 14, 2010 | Yahoo Messenger
I have just down load the new messanger and i cant open it or if it do run it shuts down
There have been many issues and bug with the latest Yahoo Messenger update. So i would suggest that you install the version before the latest.
Aug 17, 2010 | Yahoo Messenger
CANNOT LOG IN TO YAHOO MESSENGER
If you try all of the steps above and Yahoo! Messenger still can't connect, contact your network administrator, Internet Service Provider (ISP), or the person who initially set up your computer to ensure that your firewall and/or proxy settings are correct.
download reginout may solve your problem quickly
Aug 15, 2010 | Yahoo Messenger
I can't signing into yahoo messenger
It may be the server is down, it's been happening a lot lately or your Yahoo! Messenger connection information may be incorrect. Yahoo! will fix it soon. To configure your connection, what you should do? Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences." Enable the "Firewall with no proxies" option. Select the correct Internet connection type and country from the pull-down menus. Click the "OK" button at the bottom of the window. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button. Enter your Yahoo! ID and password and click the "Sign In" button. The above configuration works in most situations. (However, if you connect in this way, you won't be able to use the Voice feature.) If this configuration doesn't work, follow these steps: Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences." Enable the "No network detection" option and then click the "OK" button at the bottom of the window. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button. Enter your Yahoo! ID and password and click the "Sign In" button. If neither of the above options work, you're probably behind a firewall or proxy server that requires you to enter its address. Follow these steps: Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences." Enable the "Use proxies" option. Enter your firewall or proxy server's address and port number. Contact your network administrator (if you're at work), or your Internet service provider (if you're at home) to determine the correct firewall and proxy settings. Click the "OK" button at the bottom of the window. Yahoo! Messenger will ask you if you want to sign in with your new proxy settings. Click the "OK" button. Enter your Yahoo! ID and password and click the "Sign In" button. If you try all of the steps above and Yahoo! Messenger still can't connect, contact your network administrator, Internet Service Provider (ISP), or the person who initially set up your computer to ensure that your firewall and/or proxy settings are correct. Hope it was helpful!
Jun 09, 2009 | Yahoo Messenger
I am using yahoo messenger version 9 everytime i make a call PC-PC,it displays 'connection to voice service'.I tried to re install version 9 again,version 8 also,but there is no change!! please help me,its...
Load the Yahoo home page (see Resources below) and start Yahoo Messenger by signing in using your account information. Sign up for an account by clicking the 'Sign Up' button if you haven't done so already.
  • Step 2 Click on a contact in your Contact List once Yahoo Messenger loads. This will make a number of different contact options appear like sending photos and files, as well as making direct connections.
  • Step 3 Click the 'Call this PC' icon. This causes the other person's computer to alert him or her of your call.
  • Step 4 Check your voicemail by clicking 'Menu' and then clicking the 'Voicemail' option. If you have voice messages, you can easily listen to them here.
  • Step 5 Click on the 'Soundblast' button to choose from a list of different sound effects you can use in your conversation
  • Thank You,
    Your Support Tech.
    Manish Shirsikar
    Fixya.com
    May 17, 2009 | Yahoo Messenger
    Pc to pc dalls
    Usually you get the message: connecting to voice server, for successful connection you should have an high speed internet connection, even then voice server(of yahoo.,, or any other....) have this problem so you have to bare until you get voice connection and sometimes voice quality may be dull.......
    Dec 26, 2008 | Yahoo Messenger
    "The Yahoo! Voice service could not make this call right now." MacG-5,OS 10.5
    better switch back to old version of yahoo or try to use IM messenger or Live messenger they have interconnection  with yahoo.
    Oct 16, 2008 | Yahoo Messenger
    Microsoft Windows Vista Ultimate Edition Logo
    60 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Alun Cox
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
