Question about Black & Decker CTO6300 Toaster Oven with Convection Cooking
Oven does not turn on
When I press on the start button the oven does not turn on. All the settings work fine. I can set the clock, timer, temperature, select toast\bake\convectiuon etc but when I press Start it does not turn on
The oven is just over a year old. My brother bought the very same oven at the same time that I did and his is also doing the same thing,
Both ovens died about the same time
  • chewikar Nov 11, 2008
    my toaster did the same thing. everything works except the start button.
    Scholar:
  • 53 Answers
These ovens have a timer switch that lasts just about a year. Mine did the same thing and you cannot find the timer switch anywhere in the USA. The switch is likely a DKJ/1-60. There is a switch made by Delonghi that will work. The part # is 05XDE5218104600. You can get one at "The Gourmet Depot" website for $10 + shipping.
Posted on May 20, 2010
  • mdooligan Jan 15, 2011
    Nah. Mine has a burnt part on the PCB. It's the spade terminal at the bottom labeled C-L coming from the transformer at the back of the unit. The PCB is blackened all around it and the spade terminal came right off the board when I pulled on it. Why so much heat at that location? I dunno.
    We used this oven constantly. Too bad. Where to get parts? I dunno.
How do I set a farberware t490c commercial tabletop convection oven to work
Try calling or emailing Farberware (distributed by Salton/MAXIM Housewares): faberware-electric@saltonusa.com OR 1-888-881-8101. Ask for Operating Manual
Dec 29, 2014 | Farberware T490C 1500 Watts Toaster Oven...
KCO223 toast function not working
I too have the same KCO223 countertop toaster oven, and the toast function is not working. All other functions work fine, but the blue light won't come on in the TOAST mode setting.
Apr 09, 2014 | KitchenAid 12" Convection Toaster Oven...
How to set the clock on classic 110 oven
Push the clock button. Either use the timer up down to set a time. Push the clock button again. Should lock in the new time..
Oct 30, 2011 | Toaster Ovens
How do i set clock
You can get the manual on the link below page 9
http://www.krupsusa.com/NR/rdonlyres/932350FD-628D-4959-879A-AC006C96E9B9/7106/FBC4FBC5.pdf
• When the oven is first plugged in "12:00" appears on the display.
• Press the "Timer" button twice. The display will begin to blink "12:00".
• Adjust the time in steps of one minute by pressing the "+" or "-"
buttons.
• If you hold the button pressed down for more than 6 seconds, the
time will change quicker.
• Press the "Timer" button to enter the time in the system.
If you do not press the "Timer" button, the time will be
entered automatically after 30 seconds.
Feb 20, 2011 | Krups FBC5 1600 Watts Toaster Oven with...
How do you set the clock on the delonghi DO400 toaster oven
  1. Press for 5 seconds the TEMP./SELECT/CLOCK but- ton (7) (the hours flash on the display).
  2. Press the TIME/TOAST COLOR buttons (8) to the desired time (hours). The time set will begin blinking on the display.
  3. Press the TEMP./SELECT/CLOCK but- ton (7) (the minutes flash on the display).
  4. Press the TIME/TOAST COLOR buttons (8) to the desired time (minutes). The time set will begin blinking on the display.
  5. Press the TEMP./SELECT/CLOCK but- ton (7) to confirm. It is pos- sible to press the button at any time during cooking to display the current time (the display shows the time set).
  • If you wish to change the hour on the display once it has been set, press the TEMP./SELECT/CLOCK but- ton (7) before proceeding to set the new time as described above.
  • It is possible to display the current time even after starting a function, by pressing the TEMP./SELECT/CLOCK button (7) (the time is displayed for 2 seconds).
Oct 14, 2010 | DeLonghi DO400 Toaster Oven with...
ELECTRONICS SEEM TO WORK (ON/OFF; TIMER; CLOCK; OPERATION SELECTIONS [TOAST, BAKE, ETC]) BUT ELEMENTS DO NOT LIGHT UP
check the resistance of the plug by turning the timer and temperature switch, if there's no resistance, open your unit and check the resistance of thermal fuse which is connected to line wire. it is look like resistor..if the thermal fuse is ok then check the resistance of heating element..
Sep 30, 2010 | Krups FBC2 1600 Watts Toaster Oven with...
How to change the lower element on a delonghi AD 699 toaster oven?
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    Setting clock on krups toaster oven
    buttons.
    May 28, 2010 | Krups FBC5 1600 Watts Toaster Oven with...
    I have a new toaster oven and the clock won't set properly
    I would call Cuisinart - this one has a 3-year warranty, and all they would need is a serial number, not the receipt. Do any of the lights turn on? When you pressed clock, did you hold in the hours button?
    -Tha Mp3 Doctor
    Jan 07, 2009 | Cuisinart TOB-175 1500 Watts Toaster Oven...
    Black & Decker CTO6300 Toaster Oven with Convection Cooking Logo
    655 people viewed this question
    Top Black & Decker Toaster Ovens Experts
    Steve
    Are you a Black & Decker Toaster Oven Expert? Answer questions, earn points and help others
