Question about Canon EOS-20D Body only Digital Camera
Canon 20D strong blue cast to pictures
Any idea why P, Tv, and Av modes would suddenly record pictures with a strong blue cast to them? The other modes (auto, portrait, landscape, macro and sports) are continuing to record with correct color tones. No errors, happens with any lens, and I'm not using filters.
    Problem Solver:
  • 15 Answers
You probably have the White Balance set to a setting other a
than "Auto White Balance" (AWB). On the top of the camera, above the exterior LCD panel, there is the "AF-WB" button. Turn the camera on--past "on" to the bent line. Press the AF-WB button once. On the left side of the exterior LCD panel there is a vertical, reticular box with the symbol of the selected setting for WB. Normally, the setting should be set to AWB. If it is not, turn the command dial at the back of the camera until "AWB" is showing. Try shooting again-the color should be better.
In the "auto" modes (green box, portrait, landscape, etc) the AWB is automatically set. In the "advanced" modes (P,Tv, etc) the WB is manually set for whatever light source you are using. The command dial may have been accidently turned to different setting. Hope this helps.
Posted on Jan 23, 2008
We have a digital tv but an anologue vcr so we bought a strong srt 5430 so we can record through our vcr but are having trouble conecting the vcr and set top box
You need a cable to go between the yellow (picture), red and white (sound) sockets on the strong to the VCR.
Those cables will connect to one of the VCRs AV inputs. You then need to use the VCR remote control to switch from the now defunct analogue tuner to the Line or AV input. Put your TV on the channel you use to watch video tapes. Switch on the Strong receiver. Do the switch to the Line or AV input on the VCR. When your VCR is on the correct input then you will see the picture from the Strong receiver on the TV. You can confirm it is the correct source by displaying the Strong's EPG.
When you come to make recordings, the Strong will need to be left on the channel that you want to tape. If your TV already has an aerial feed and isn't relying on the strong for its signal then you can watch another channel on TV.
Aug 27, 2014 | Televison & Video
My PowerShot S30 has suddenly started to produce blue pictures
The white balance is set to something other than "auto WB".
Jul 22, 2010 | Canon PowerShot S30 Digital Camera
My EOS 400D takes blue hued pics
You may have the white balance set incorrectly. If so, set it to "auto white balance".
Sep 25, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Focusing issues with canon 40D when taking sports shots
I believe I have found my problem. I think my image stablizer on my lens is on the brink! I turn it off and got good pictures.
Jun 03, 2009 | Canon EOS 40D Digital Camera
Wont record anything to MiniDV tape and A/D randomly working
Sorry about delayed reply as I just saw it.
Its known problem of ccd imager in Canon ZR85 camcorder and ccd imager needs to be replaced.
Canon will repair your camcorder free of cost as per announced scheme for ccd imager issue.
Click Canon CCD Advisory for details, how to get free repair.
Regarding can't see picture or time code in playback, it is problem of dirty / clogged video heads. Use good quality video head cleaning cassette to clean heads and hope camera will show playback picture.
Good luck.
Nov 19, 2008 | Canon ZR85 Mini DV Digital Camcorder
Canon SD 550-- sensor problem? Bought 3/2006 and have had no problems. Suddenly, LED screen went black--shows nothing and cannot take a picture altho will flash and record black picture. Shooting...
The shutter of the camera is not opening that is why every picture taken is recorded black. It is a mechanical problem and probably has nothing to do with the sensor. Not very expensive
Aug 30, 2008 | Canon Cameras
CF Card Error
Check your memory card to see if its locked!
Jan 03, 2008 | Vivitar ViviCam 3915 Digital Camera
TEAC Television -CT-M809AV -no picture
Maybe it's something with NTSC/PAL settings, or SOURCE SELECT. Check troubleshooting in your manual.
Oct 11, 2007 | Sylvania 6419TE 19" TV
Dark Pictures in Auto setting
Do you have a polarizing filter on the lens?
Aug 07, 2007 | Canon EOS-20D Digital Camera
Recording From An External Device
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder. 2004 - SC-D107 2003 - SC-D5000, SC-D27 2002 - SC-D180 Recording In Player Mode 1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device) 2. Set the power switch of the camcorder to PLAYER mode. 3. Turn on the VCR or TV. 4. Insert the blank tape with protection tab closed into the camcorder. If you want to record from a connected VCR, insert a recorded VHS tape into the VCR. 5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. 6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. "AV IN" and picture appears on the LCD monitor. OUT : Releases the INPUT mode. 7. Press the START/STOP button to set the camcorder to REC PAUSE mode. "PAUSE" appears on the LCD monitor. 8. Select the TV program or playback the VHS tape. 9. Press START/STOP button to start recording. If you want to pause recording for a while, press the START/STOP button again. 10. To stop recording, press the (STOP) button. Notes: * Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed. * If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Canon EOS-20D Body only Digital Camera Logo
173 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
