Small camcorder dvd stuck in tv/dvd player
I have a Westinghouse tv/dvd player and i put one of my small camcorder dvds in it and it worked but it would not eject. I tried the paper clip thing and turning it off and then back on holding the eject button but still no luck do i have to take it apart?
  • hotlantaga Jul 02, 2008
    I put a small camcorder DVD in a Toshiba 23HLV84 23 in. TV/DVD Combo, and it won't play but won't eject either. It just makes a grinding noise and the screen says Open then Close. I can't see the disk inside the player and have not been able to fish it out. I can put another 12 cm DVD in beside it but it doesn't help with the ejecting
    President:
  • 4,402 Answers
Yes you will have to take it apart and most likely lift the top off the cdplayer to get at it.
Posted on Jan 23, 2008
Hello, my Westinghouse tv/dvd combo will not accept a disc. We had previously, through small children, had three dvds stuck in the dvd slot. But had just gotten them out. We then tried to play a dvd to...
* Check your warranty and call for service. There are no customer replacement parts in this type of "combo" unit.
*** Following is for information only ***
* DVD section is usually a "Snap-Assembly" system when built at the factory. Pulling and prying on this type of device will "Snap open" parts. Your best bet is to have the unit replaced.
* Yes, it's possible to take the DVD apart and reconnect the disassembled part. But in addition to not knowing how it is originally assembled, there is a strong possibility that it won't go back in the correct way.
* There is probable damage to the DVD "reader" and LED "LAZER" device that runs just above the DVD. With the DVD disk spinning at a high rate. It is probable the read head crashed into the disk(s) and caused damage to read head and DVD disk.
* Final; If you can still use the TV portion. Check for alternate A/V input. (Yellow, Red, White, RCA jacks) or HDMI input. There are many "Stand alone" DVD players on the market. The last one I bought 10 years ago was $30 at WalMart. I'm sure they are even cheaper models now. You may also want to look into getting another TV set as most cable TV providers have switched to all Digital "High Def" input and don't support the "Channel 3" or Analog TV system.
Aloha, ukeboy57
PS; If you do get a new DVD player. Be aware that the DVDs have been upgraded to "Blu-Ray" disks. Your old DVD player may not have been able to play these newer disks. I found the following players on line:
https://www.walmart.com/ip/LG-DVD-Player-with-USB-Direct-Recording-DP132/33396346
https://www.amazon.com/Sylvania-Player-Upconvert-Digital-Display/dp/B01GO72M9O/ref=sr_1_7?s=tv&ie=UTF8&qid=1530209541&sr=1-7&keywords=dvd+player&dpID=310oLokaLNL&preST=_SX300_QL70_&dpSrc=srch
Jun 28, 2018 | Westinghouse Televison & Video
PSE ADVISE HOW WE GET DVDS OUT,THEY GET STUCK IN THE TV UNIT ? IS THERE A SAFE WAY TO GET IT OUT ??? THANKS FOR ANY HELP U CAN OFFER, WE LUV OUR GRUNDIG THAT OUR DAD LEFT TO US. ITS A MISURO HD UNIT.
Check near the DVD opening for a small pin sized hole if your lucky it will have one of it does then grab a small paper clip unbend it so it's strait insert in pin hole and put some pressure behind it hope this helps
Nov 22, 2016 | Grundig Televison & Video
I accidentally put 2 dvd's in my Westinghouse combo player, and now they are stuck....ugh! help pls
The DVD player section will have to be un-assembled. If you are not experienced at this get an experienced service tech to do this. The set will have to be opened up, and most likely the DVD module removed to take it apart.
There is a slight change the DVD unit may have been damaged, and require replacement.
When I was working doing TV and DVD service, I have seen this done before. There is maybe a 30% change the drive will have to be replaced.
Sep 26, 2014 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
5 yr old Westinghouse TV w built in DVD player. DVD player won't play. Tried several different movies, none will play.
First thing I would check is that you are playing regular DVDS and not BluRay. Your TV may be old enough not to accept BluRay. If it doesn't work with a regular DVD then you most likely have a bad reader which can be replaced but you will have to take the tv apart to get to it.
Dec 12, 2013 | Westinghouse Electric SK-32H570D 32 in....
Camcorder DVD stuck in TV
get a small paerclip and straighten it, You will find a small hole. Insert the paperclip there and the tray should pop out. PLAN B: Bring it to a shop to retrieve the disk. happened on my PSP UMD.
Sep 21, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Using Verbatim DVD-R DL on Canon Camcorder 310 DVD
Some computers will not play mini dvds. You will need to check with the computer manufacture to be sure.
Jan 18, 2009 | Canon DC310 DVD Camcorder
Two dvd's stuck in player thanks to a busy toddler
I had the same problem... my DVD took one in even though it already had one in there... Tweezers did not work until we used a pie server covered in masking tape with the DVD attempting to eject and then grabbed one DVD out. The DVD player works too!
Nov 11, 2008 | Rosen CV7080D Portable DVD Player
Westinghouse 42"lcd dvd player
We got a disk stuck in our Westinghouse also. After aticking toothpicks and butter knifes in there trying to get it out, we were told to unplug the power and plug it back in and try. When we did we could hear the DVD trying to come out. We stuck the butter knife in there and got it to pop up and out. We havent tried to put another one in but when we do we know how to get it out now.
Feb 09, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Tranfer mini cd to a normal cd?
put the CD back in the casmcorder, and hook up the camcorder to your tv. put a blank disc in your dvd player and play the small disc through the camcorder on the tv. while the camcorder is playing the recorded stuff, press record on the dvd player and it should burn the stuff onto the blank cd.
Jan 10, 2008 | Panasonic VDR-D200 DVD Camcorder
My dvd always shows "system error" and won't play commercial copyright dvds, only recorded ones.
I had the same problem with my recorder except that it wouldnt play any discs at all.. I finally unplugged the recorder and left it unplugged for 16 hours. Now it is fine. I am not getting any error messages.
Nov 23, 2006 | Toshiba D-VR4 DVD Recorder/VCR
Televison & Video Logo
137 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
