The water in your sump pit needs to be no more than 2-3 inches, this is enough to keep your pump happy and make sure it works properly when you need it to. Equally, the pump should start to work when the water level is still 6-7 inches below the level of your floor. https://www.homoq.com/proper-sump-pit-water-level/
the unit is low on charge and has a refrigerant leak...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
If the unit is titled forward at all, the "full bucket" "trip switch" will not trigger off as it should. Be sure the unit is on a flat, level surface, or leaning backward slightly--this also aids drainage through the drain tube, if that's your set-up.
Hi, It could be a bad compressor, circuit board, or maybe even a sensor or dehumidistat... Here is a tip about dehumidifiers that run but do not extract water from the air..
