Question about Kenmore 94223 Electric Kitchen Range
The burner when u turn the front burnner on to med the it will rise to a point where the pan will catch fire also the burner caught fire the other night
The control relay related to that burner is damaged. The only way to unplug the input power to that relay by openning the back side of the stove and unplug the relay commander to the specific burner.
At least you can use other burners until the service guy or ordered part arrives.
Posted on Nov 20, 2008
Toyostove Laser 73 heater will not run, and the low/med/hi lights flash on and off?
Remove front grille by taking out two screws at lower right and left front sides of stove. slightly pull botom front of grille toward you and lift up and off. Look for two red wires going into burner chamber, the wires will be incased in a gray plastic sheath as they enter chamber. Push on buton like you are trying to start the heater. While it is going through start up process hold the gray plastic sheath with two fingers and see if the sheath does not get warm in a short period of time the igniter is bad and will need to be replaced. This can be cause by water getting into the burner chamber and causing the igniter to crack.
Jan 05, 2013 | Rinnai Toyostove Direct Vent Heater:...
Low flame on left front burners high flame onright front burnners
That is food/grease buildup. Clean the holes. TURN OFF GAS to stove, then just clean the holes in the burners with a soft wire brush. Then turn gas back on and immediately relight pilot lights. If that sounds scary, call your gas company, they might come out and help.
Dec 09, 2012 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have all new burner element, starter and thermometer,,,because I had a MAJOR fire from deteriorating fire unit Now I used grill to rotisserie a chicken, cleaned everything and when using it to grill...
When you cooked the chicken on the rotisserie, did you remove the cooking grates and place a disposable drip pan on the flame tamers below the chicken? This will prevent the grease from dripping down into the bottom of the grill when you use the rotisserie. The bottom of the unit needs to be kept clean so the grease will run to the drip pan and not get caught in the bottom of the unit. When you are done cooking, if you will close the lid and turn the grill on high for 10 to 15 minutes it will help to burn off any grease build up and prevent fires in the future.
Jun 11, 2011 | Dynasty DBQ-30 (LP) Grill
Fire burns good for a while then wants to go out
Flame sensor at furance burrner conpartment needs to be cleaned. Flame sensor is located at the left of the burnner compartment fsarthest burner tube from ignitor. Remove and clean with very fine grit sand paper 400 grit works best.
Jan 26, 2011 | Heating & Cooling
The pilot will light but the burnner won't ignite. A pool guy said to turn the theromstate control real slow to a higher tempature and then the burnner will ignite. That worked a few times but now that has...
More likly you have a dirty filter. Or a plug in a line. Test this by jumping your pressure switch. You can also check thr roll out switch the wire that rung along the fire wall just above the burners. It will have a black cover about two inches long on it that has a switch that is cased in wax if the fire rolls out the front of the cabnet the wax melts and shuts the heater down. Check this by jumping also. I hope this helps.
Sep 02, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Should my broiler turn on when I am preheating my oven this does not seem right to me and my oven caught on fire last night
Yes the broiler will often turn on to help preheat the oven.
If it caught fire, it is not because of that, but because you have too much run over food in the oven. That is what caught fire. You need to clean it an NOT with the self clean!!
hetaman101
Aug 18, 2010 | Hotpoint Ovens
The hose to the regulator caught fire and burnt off. I bought a regulator with hose, but it doesn't seem to attach.
Keep in mind that LPG valve threads are reversed (left to tighten and right to loosen). In addition tank valve and regulator fittings change causing confusion and problems.
Apr 25, 2010 | Fiesta Blue Ember Gas Grill
Back burner caught fire
If the water has been dried up, it was most likely the drip pans. Water is non flammable, sorry i couldn't help myself. If water was the problem there would be sparks and buzzing noises first.
Jun 17, 2009 | Kitchen Ranges
Baking Element Caught fire
this a common complaint when the element burns out it is scary to see but all you need to do is replace element
Apr 21, 2008 | GE Profile 30" Free-Standing 5 Burner Self...
Kenmore 94223 Electric Kitchen Range Logo
93 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
