Question about LG CHOCOLATE VX8500 Cellular Phone
My contacts I have a few random contacts that are red, and the rest (the majority of them) are white. is there a significance to the red ones? What exactly do they mean? and is there a way to change them back to white?
    Problem Solver:
  • 8 Answers
You can erase and input them again
Posted on Jan 26, 2008
I have 4 wires green blue red and white my red is connected to the rh rc with jumper green connect to g blue to y1 and white is connected to w1 my new thermostat has no rc rh or a jumper
Paulette, if your new thermostat has no Rc and Rh thats fine. The Red wire should simply go to the R terminal. The Rc and Rh terminals on the old one was for the old 'two transformer' systems. The vast majority of systems now have no need for the Rc Rh terminal and jumper. The rest of your wires connect as on the old stat also.
Jul 31, 2015 | Heating & Cooling
I WANT TO RPLACE MY RADIO CD PLAYER ON MAY 2007 SUBARU IMPREZA I NEED COLOUR CODE OF WIRES
just buy a wire harness adapter for a few bucks, it will save you a major headache. http://cgi.ebay.com/ebaymotors/_W0QQcmdZViewItemQQitemZ380309094037#ht_1030wt_939 ...but if you must do it the hard way, 2007 Subaru Impreza Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Yellow/Green
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Yellow/Blue
Car Stereo Dimmer Wire: White/Yellow
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Brown/White
Right Front Speaker Positive Wire (+): White/Black
Right Front Speaker Negative Wire (-): Red/Yellow
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Red/Black
Left Rear Speaker Negative Wire (-): White/Red
Right Rear Speaker Positive Wire (+): Red/White
Right Rear Speaker Negative Wire (-): Blue/Yellow
Apr 15, 2011 | Car Audio & Video
Only one channel going to b/w
Not the tv,it the brocasting incoming signal cable have a slice matalic contacting to that procise prequencies problems for that channel.Take another tv used it,with that incoming signal for that channel for a few days.See,if have a same problems have happen to another tv?Yes,than call the Cables,Dishes or Telicoms compannies,change that section of the incoming of broscasting signal cable line.Not,than take a piece of sand paper about 1000 grits,rub the input metal pin a few times,to have it better contact.
Jul 20, 2010 | Jwin Televison & Video
How do i find out if the motorola cliq im going to buy has had water damage?
when you pop the battery off there is a circular dot near the middle near the orange or black rubber thing that helps lock the SIM in and SD card.
The dot is likely either white or red. White should indicate that it is good and red if it had significant moisture/ water contact.
Apr 01, 2010 | Motorola Mobility CLIQ Cell Phone
I have a Maxent MX-50x3 50 inch plasma. built may 2006, bought at best buy in april 2007. Allways has occasional red pixels randomly when switching inputs. Now we have vertical red lines and pixels and...
if you take the back cover off the tv, you will see in a white screw in almost every board, those are called pot. (potentiometer).
if you can get to meter the Ve. Vs. and Vset. start to screw or unscrew those white screw according to what the label says.
usually the ones who gives you the blue and red dots are the white screw on the right of the center panel, and the one on the right of the right panel right under the metal thing to hang on the wall.
Aug 20, 2008 | Televison & Video
Colors off
I have the same problem, would like an answer.
Aug 06, 2008 | Mitsubishi WS48511 48" Rear Projection...
Polaroid tv Wii connection
Your LCD TV should have one of the following types of inputs:
  1. Composite. This is usually a yellow jack, along with red and white jacks for audio.
    If your TV has these, which it should, then the cable that comes with the Wii will plug directly into these jacks. Plug the yellow to the yellow jack, the red to the red jack, and the white to the white jack.
  2. S-Video. This is a flat black jack. There are four little holes, and one "flat" rectagular hole. There should also be a red and white jack that go along with this for audio.
    In order to connect to this input, you will need to purchase an S-Video output cable for the Wii. Most stores that sell Wiis will sell a third-party cable for this.
    This connection will give you a significantly better picture than Composite.
    S-Video does not carry audio, so you still need to plug the red plug into the red jack and the white plug into the white jack or you'll get only video and no audio!
  3. Component video. This is a triplet of Red, Green and Blue jacks. There is usually a set of red and white jacks along with them for audio again.
    This connection will give you the best picture, and you can set your Wii to EDTV (Progressive) mode.
    To connect to this input, you will need to get the Wii Component Video cable. Most stores that sell Wiis will either sell the official Nintendo one, or a third-party cable.
    Connect the red plug to the red jack, the green plug to the green jack, and the blue plug to the blue jack. Also connect the red audio plug to the red audio jack and the white audio plug to the white audio jack.
    Be careful not to get the red audio plug confused with the red video plug!
    If you see a picture, but the colors are wrong, then you either swapped the red and blue, or you connected the red audio plug instead of the red video plug.
Apr 01, 2008 | Nintendo Wii Console
DURABRAND SA51AR
Based on your description, your Television has stereo outputs. Multiple channels may be "encoded" into those outputs, but your home theater system would need to interpret these encoded channels through one of its pairs of inputs.
I would try plugging the 5A51AR's Right/Left (Red/White) "Side Speaker" inputs into the TV's stereo outputs and see if the unit provides output to all speakers. There may be a switch on the unit labeled "Surround-Decode" or similar which needs to be set for this type of operation.
Feb 15, 2008 | Durabrand HT-3915 System
LG CHOCOLATE VX8500 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
