Question about Whirlpool GHW9100L Front Load Washer
Washer interupted while running
Child interupted the cycle. now lights flash but washer will not re start
we tried power shutdown but it still will not re start
  • Anonymous Jan 26, 2008
    Just encountered the same problem. My daughter pressed some buttons and now it is completely stuck. I tried to hold down the end of cycle button but that did nothing. I finally shut the washer power down and that seemed to clear it.
  • 1,294 Answers
Try pressing "end of cycle". Then restart your normal wash.
If helped pl rate me................................
Posted on Jan 24, 2008
How do I use the Child Lock option on Samsung WF-B1456GW?
You can use the child lock feature in 2 ways.
1. To prevent operation of the washing machine when no wash cycle is running
To set this feature, switch the machine on using the POWER button at the top-left of the control-panel. Next, press and hold both the SPIN and RINSE buttons for about 3 seconds - until the child lock light indicator on the control panel illuminates. All functions of the washing machine will now be disabled apart from POWER ON/OFF until such time as the child lock is deactivated.
To deactivate the child lock, press and hold the SPIN and RINSE buttons again until the child lock light indicator on the control panel goes out.
2. To prevent any tiny fingers from tampering with the machine while a program is running.
After pressing the START/PAUSE button to start the wash cycle, press and hold the SPIN and RINSE buttons until the child lock light indicator illuminates. All buttons on the control panel will now be disabled until the child lock has been disabled. When the wash cycle has finished, you will need to switch the child lock off again to reactivate the buttons. Once you have finished using the washer, reactivate the child lock again before switching the power off as above.
The feature can also be used when using the delayed start feature, but needs to be set after pressing the START/PAUSE button.
Hope this helps. Please let me know if I can be of further assistance.
Feb 09, 2011 | Washing Machines
Cannot restart washer after cycle was interupted. Intake and drain lights flashing.
Need make and model but first unplug for 10 min. and try again.
Nov 12, 2010 | Washing Machines
Washer won't run. It beeps 3 times and flashes "err" and "LOC".
HI. The term"LOC" will be an indication of the "Child Locking" feature that has been activated either by mistake or intentionally. This is a safety feature to prevent unwanted starts when children are present.
To unlock the controls,press "Options and Select" at the same time and hold for 10 seconds until ”LOC” is no longer displayed.
  • NOTE_ If the release procedure doesn't unlock the unit and the letters LOC continue to appear, this will be a strong indication of a severe fault within the main control board. try to power cycle the unit if this is the case. if the power cycling doesn't produce good results, replace the main control board assembly.
Aug 14, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a front loader HE washer. The lights are
Try unplugging the washer and see if the latch disengages. I'm also wondering if the cycle was interupted (power loss) and a restart is necessary.
Aug 02, 2009 | Washing Machines
Samsung wf337aa front loader
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Jul 13, 2008 | Samsung WF337AA Front Load Washer
Whirlpool Duet's interupted cycle won't restart
unplug, let sit for 2 min, replug and try to put into drain/spin cycle
Feb 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Oven door locked
First check to see if you activated the "child lock-out". See your manual to deactivate.
You could also try unplugging the unit, or trip the circuit breaker in your home which supplies power to the oven. Wait 5 minutes and turn power back on. This will reset the controls.
Jan 26, 2008 | Whirlpool RBS305PDS Electric Single Oven
Control lock light
someone has enable the child lock feature. One of the buttons should say hold 3 secs for control lock under its normal function description. Hope this helps
Jan 01, 2008 | Washing Machines
Whirlpool GHW9100L Front Load Washer Logo
176 people viewed this question
Dan Webster
Dan Webster
Sal De
