Question about Samsung HP-R5072 50 in. Plasma HDTV
Hpt 5054 On some programming I get a flickering of image from light to dark or vice versa.What could be some causes for this
I have been researching this myself and it seems to be an issue with the logic board software. Samsung must replace it. Check on avsforums.com for more info.
Posted on Feb 02, 2008
    Sergeant:
  • 261 Answers
Does this set have an auto IRIS? IF it does turn it off. If not, it could be power supply related. Can you take a picture of it?
Let me know. Have a good day. Thank you Jay
Posted on Jan 31, 2008
64 Chevy electrical problem. Ammeter flutters and lights flicker.
Could be the alternator with a bad or failing diode or a bad phase,there are 3 phases making AC which is converted to DC.
Supply your own field power to the alt with the regulator unplugged.Lights still flickering?replace alt.
Apr 08, 2017 | Chevrolet Cars & Trucks
How to fix faded copying on brother mfc7360
Gradual fading, going from dark to light or vice versa, is usually caused by unequal toner distribution. Just remove the toner cartridge and shake it by rotating 45 degrees to one side along its axis and then back to zero and then the other direction. It's ok for the cartridge to leak a little amount of toner, so it's recommended to use plastic gloves and do it over an old newspaper to avoid smearing toner all over.
Oct 23, 2016 | Brother Mfc-7360
Front Led Lights but No Clicking, Picture or Sound when I Plug it In.
If the front led is lit, the TV is on standby. Did you place the batteries in the remote correctly?
There might only be one button that turns the TV on/off (usually the red one in the top of the remote)
Did you plugin the picture feed cable correctly (VGA, DVI, Antenna etc.)?
Jul 06, 2014 | Samsung HP-T5054 Widescreen 50 Plasma HDTV...
Samsung hp t5054 light comes on but it has no pic, sound and does not click when plugged in
Check that all cables are intact and plugged in correctly. (VGA, DVI, Antenna etc.) Did you place batteries correctly?
There might only be one button that turns the TV on/off (usually a red button in the top of the remote).
Samsung 50" turns off and clicks
Since its a Plasma or seems to be you got this in the wrong area-a glitch on the site here often does this---if a flat screen set--Plasma or LCD post the question with model number in the text under Flat screen Televisions so a expert can assist you.
Dec 16, 2012 | Samsung HP-T5054 Widescreen 50 Plasma HDTV...
Samsung black screen
probably a bad VX or VY card.
If your TV is under warranty... call samsung for solution
Oct 03, 2012 | Samsung HP-T5054 Widescreen 50 Plasma HDTV...
Y dose my the image not apear when i use the av cables (yellow,red,white)
Try this: Power off the ps3 (red light) then hold down the power button until you hear 2 beeps and let go. that should work, you just needed to reset the ps3 to the av cable cause it is set to HD or vice versa
Jan 05, 2011 | Sony Playstation 3 (PS3) Console
Actiontec (GT704WG) Wireless Router Lights
Yes, this is normal. The flickering lights are showing activity - data is being transferred when the light is on, and vice versa. The power light should always be on when the unit has power. The DSL light should be solid as long as your DSL line is connected properly.
Jun 08, 2008 | Computers & Internet
Red screens cause flickering
if normal tv is fine then ,likely the signal from the box is too hot.
if using composite switch to cable ch 3 or vice versa,
or use hdmi cable or change the box .
Apr 22, 2008 | LG 42PX5D 42 in. Plasma HDTV
Samsung HP-R5072 50 in. Plasma HDTV Logo
79 people viewed this question
Jerry Greenberg
Jerry Greenberg
