Question about Lexmark Optra M410 Laser Printer
ERROR 921 SERVICE ERROR
  • 167 Answers
921 Fuser Error Indicates that the fuser is below standby temperature when the printer is idle.
Error codes 920, 921, and 922 may display for a cold fuser failure. A 920 error caused by low line voltage can sometimes be cleared by turning the machine off and then on again.
Service Tip: Set the Fuser Temperature to NORMAL before starting this service check.
Manually spin the fan and check that
it rotates freely. Check the cable
connection to the engine board, J13
for correct installation.
Posted on Jan 25, 2008
PC 921 toner light on. Replaced toner cartridge, light still on: won't function.
You see these machines needs to be kept very well.
1. the machine is not sensoring your toner.
a) need for the machine to be serviced it probably has a lot of spill toner inside.
b) toner empty sensor is not positioned properly.
b) the toner empty sensor is not functioning properly and needs to be changed.
Jul 14, 2011 | Canon PC-921 Black and White Copier
What is the fix for a 921 service fuser error?
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $300, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
Feb 09, 2011 | Lexmark Optra M410 Laser Printer
922 service fuser error
  • 921 Fuser Error and 922 Fuser Error messages indicate that the fuser unit failed to reach the standby temperature.
    • If this is the first time you have seen the error, turn the printer off and on. Leave the printer off for at least 10 seconds before turning it back on. This gives the printer's engine board a chance to reset.
    • If this is an intermittent error, you may want to check how the printer is plugged in, even if it has worked on this surge device for months. Make sure the printer is plugged straight to the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in your printer which can trigger a false fuser error.
    • If this does not help or if this error appears every time the printer is powered on, you will probably need service on the machine.
    Nov 10, 2010 | Lexmark T522 Laser Printer
    The 921 service fuser error indicates the fuser indicates that the fuser unit failed to reach the standby temperature. This usually requires service. But here's a couple of things worth checking:
    • Unplug printer from power source, replug after 30 seconds. Make sure to plug the printer straight to the power outlet in the wall. Bypass any surge devices or power strips as they can cause low amperage resulting to false fuser error.
    • Check Maintenance kit count. Go to Configuration Menu by pressing Select and Return while powering on the printer. If count value reached 300,000, maintenance kit should be replaced.
    If error continues, don't hesitate to contact Lexmark technical support or your authorized service provider for assistance.
    Aug 30, 2010 | Lexmark Optra T612 Laser Printer
    921 service Fuser error
    921 Fuser Error indicates that the fuser unit failed to reach the standby temperature. Leave the printer off for at least 10-15 seconds before turning it back on. This gives the printer's engine board a chance to reset. Make sure printer is plugged in straight to the wall, bypass any surge device or power strips as this can cause a low amperage problem in your printer which can trigger a false fuser error. If this does not help, you'll probably need service on the machine since it deals with the LVPS, the fuser and the system board.
    May 19, 2010 | Lexmark Optra M410 Laser Printer
    Canon PC-921 copy machine error message "P"
    Load paper.If there is paper in the tray,there is a problem with the paper pick up.Try to use the Manual feed try.
    Oct 26, 2008 | Canon PC-921 Black and White Copier
    Re: 4037 5e lexmark laser printer printer is showing 921 service what does this mean and how do i fix it
    Here's some info:
    Oct 16, 2008 | Lexmark Office Equipment & Supplies
    I have a Lexmark Optra M410 and I have an error message which reads "921 Service Fuser error". What should I do?
    Looks like a hardware failure. Googling "lexmark optra m410 fuser" it appears you can buy a new one for around $100, but I don't know how difficult it is to install. A call to Lexmark tech support couldn't hurt.
    Sep 10, 2008 | Office Equipment & Supplies
    Lexmark Optra M410 Laser Printer Logo
    1,255 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
